#2577 |
Drives: blue
Thank you for that, besides taking their word at face value, is there a visual setting that they show you on the tablet that shows its unmarried?
#2578 | |
Sent from my SM-G930V using Tapatalk
Invidia catless FP & Q300. Enkei TS-10s. Conti ExtremeContact Sport tires. Hawk HPS pads. Centric Rotors.
#2579 |
Drives: blue
Thats fine, I will just do some research once i know there is a way to tell. lol Must be a pic or thread on the topic somewhere.
#2580 | |
Sometimes I'm wrong.
Drives: '13 FR-S/'96 240SX
http://www.ft86club.com/forums/showthread.php?t=103825 |
#2581 |
Drives: Subaru BRZ
had uel+op+cbe, already running oft stg2 uel 93
just installed catless fp w/ resonator, i believe the same map applies. do i have to reflash/reinitialize anything or will the ecu relearns over time? thanks |
#2582 | |
I recommend crusing at highway speeds for about 100 miles with the cruise control set, so the ECU will learn faster. Otherwise, it'll take about a tank of the same gas with normal around town driving. Sent from my SM-G930V using Tapatalk
#2583 | |
Drives: Subaru BRZ
along with a k&n filter, is it worth the jump to ecutek and have it custom tuned if i stay NA? never dyno'd it so idk where it currently sits, and idk how much ecutek will gain. |
#2584 | |
Drives: FT86
Theoreticly on an NA car you will get same results with oft or ecutek with a conpetent tuner. Cusrom tuning on NA cars often yeilds very little gains. Just log you tune check the fueling mainly, if your fuel trims are fairly low 5% anc you afr and commanded afr are close duribg wot, then custom runing is going to yeild you very little if your on 93 fuel. |
#2585 |
Drives: 2013 86
Hi all,
New to the forum thing and am not here for a good reason sadly.. I received an open flash tablet today and plugged it in asap. I chose the stage 1 stock tune and followed the steps to the tee, and got to the last part where it says turn off ignition and then turn engine on and let idle for 45 secs.. however the car ticked over for 1 sec and gave up. I tried to start it again and got no response, so naturally i sh*t my pants and reflashed back to the original file and tried to start it again and the car didnt start.. i tried to start it a couple of times and the battery seemed to be getting flat as the air con wouldnt turn on nor could i lock the car via key fob. Ive emailed open flash but i live in australia so im not expecting a reply for awhile, can anyone give me some troubleshooting advice!? Stressing hardcore. Cheers Mac Sent from my iPhone using Tapatalk |
#2586 | |
Drives: FT86
Id say you may have a battery problem. Put a charger on battery and see if the car will start. Its not good to flash cars with low or suspect batterys but i think your ok. Have a read of link below If your ecu flash failed the car would not even try to start, and if ecu was bricked the oft would complain about being unable to talk to ecu. I think its jist flat battery hopefully if your a 2013 car on original battery it was probavly on its last legs http://www.ft86club.com/forums/showthread.php?t=99171 . Last edited by steve99; 07-10-2017 at 10:20 PM. |
#2587 | |
Drives: 2013 86
Hey mate, Really helpful, thank you! Im gonna chuck a charger on it tomorrow and will get back to you. Fingers crossed. Mac Sent from my iPhone using Tapatalk |
#2588 |
Drives: GT86 2013
Any chance there will be a 93 octane map for EU-cars like there is for US?
For my particular car (ZA1J700I) there is only one Stg2 UEL-map available. I'm guessing its for 91, i always fill up with 93 regardless, and it would be nice to unlock the extra power. |
#2589 |
Drives: 2013 Scion FRS
Wut up! I just replaced my dead battery with new and reglashed my EL E85 tune on the OFT.Now my a/c don't work and my ABS/Traction Control light is on...any thoughts would be kindly appreciated!
#2590 |
Did you let the battery charge all the way before you flashed?
| Tags |
| cat overtemp |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 01:19 PM |
| FBM Tuning fixed my issue, FA20 and Visconti didn't work as well | whitefrs | Forced Induction | 253 | 08-19-2013 12:39 PM |
| Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
