Old 04-13-2016, 04:05 PM   #239
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Originally Posted by shadoken View Post
I would like to use something that has a slightly bigger screen and less buttons.
Kinda like this
https://www.carjoying.com/newest-joy...rror-link.html
But it looks like the dimensions are different , anyone on here tried other Universal Joying units? What brackets would I need to use?
You can use some rav4/mr2/?yaris? Covers for double din and orginal brackets. Only a bit sanding on the covers
Ralle109 is offline   Reply With Quote
Old 04-17-2016, 01:19 PM   #240
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
So I finally got around to trying update again. Luckily this time it took the update without any issue. I think the file might of been corrupted the first time I tried.
Rican_D is offline   Reply With Quote
Old 04-17-2016, 07:16 PM   #241
socal_48
socal_48's Avatar
Drives: '15 FR-S RS 1.0
What is the model number of that 7" HU? Also, did you need to buy a specific harness for it to work with the FR-S/BRZ?
socal_48 is offline   Reply With Quote
Old 04-18-2016, 10:55 PM   #242
armstrom
Drives: none
has anyone looked into this harness? https://www.carjoying.com/joying-har...ess-cable.html
It lists the BRZ as a supported model and seems to have most of the stock connectors broken out. It also includes the radio antenna adapter (blue wire is connected also, not sure what that wire does). It looks like the only extra harness required is the USB connector.
Thoughts?
-Matt
armstrom is offline   Reply With Quote
Old 04-19-2016, 04:29 AM   #243
socal_48
socal_48's Avatar
that looks like too many unused connectors to just hid behind the radio.
Old 04-19-2016, 05:09 AM   #244
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
Thoughts?
-Matt
I own a gt86 Toyota, but I think it would work for frs/BRZ to.
I used a Toyota to iso adapter, and for antenna I think a Skoda fakra to iso.
You only need the two standard Toyota plugs. What I read, so every scion had a amplifier for audio? I would pin it out and connect it to the amp cable from the HU.
Reverse signal is the single green cable that goes behind the cluster.
Old 04-19-2016, 02:05 PM   #245
Surge
JY-UQ124
same one I have and it's awesome.
Surge is offline   Reply With Quote
Old 04-19-2016, 06:34 PM   #246
Devante
Crescent fresh at best.
Devante's Avatar
Drives: 2016 Scion FR-S - Asphalt
Originally Posted by Surge View Post
JY-UQ124
THat one looks nearly perfect! (would rather have a next/prev button instead of navi/source)
Couple of questions.
1) Anything you don't like about it?
2) How hard is it to get to work with 2016 FRS stock reverse camera?
3) Are the LED colors adjustable?
4) Does it have a screen auto-off mode?
Thanks!
Devante is offline   Reply With Quote
Old 04-19-2016, 08:53 PM   #247
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
I think it's possible to bind buttons new with a custom Rom.
There is also a 7" version with GPS and a source button
Yeah, some little things, but mostly android 4.4.4 related.
For example "long" loading time for USB stick (still plugged in)
Or the app that you bind with the GPS button mutes all other sounds the hole time.
OEM apps not always what I lock for, simply exchange with regular market apps( Google now launcher, power amp, vlc....)
I had a non oem rear cam on my tas300 Toyota head unit. You ned a video cinch, power for the cam from backing light or from head unit
Yes RGB
Latest oem firmware has a screen off button in the status bar.
Maybe simply install a standard android locks screen?
Old 04-20-2016, 09:07 PM   #248
armstrom
Drives: none
so, I pulled the trigger on the toyota specific version of this head unit. Install went great for me. I only had to file down the lower locating pins on the stock brackets. The top pins had appropriate holes. I also didn't need to slot the holes as others have mentioned, my trim went back on just fine. I might still slot the holes slightly to seat the unit a bit farther back in the dash but it's working fine for now.
One interesting thing I noticed, there are two RCA cables in the stock dash wiring that are capped and taped up in the back of the dash cavity... I'm assuming they're for a subwoofer option or something. Does anyone know where the end up in the car? Do they have RCA connectors at the other end as well?
Also, does anyone know which antenna is located on the metal bracket behind the stereo? It's either the XM radio or the GPS antenna but I'm not sure which.
I'm now off to XDA forums to look for a new ROM
Old 04-20-2016, 10:06 PM   #249
Rican_D
Rican_D's Avatar
Welcome to the club. I didn't notice those capped RCA wires when I installed mine. Now I'm curious lol.
Old 04-21-2016, 09:43 AM   #250
armstrom
Drives: none
Yeah, here's a picture (not mine, found on the forum) that I've annotated. The red circle shows the capped RCA connector tucked away at the back of the cavity (there are left and right connectors, only the red one can be seen in this picture.
The antenna I was talking about is the black box in the green circle. I'm assuming it's the XM antenna. You can follow the short lead from that box that's covered in the grey foam. It leads to the green coax cable in the foreground. I didn't pay attention to where it plugged in on the stock head unit so or I would know for sure if it's GPS or XM.
Old 04-21-2016, 03:32 PM   #251
Ralle109
Ralle109's Avatar
Drives: Toyota GT86
The german/Europe gt86 is almost completely different in those parts, GPS is behind the gauge cluster, no external amp,..... Only the two old Toyota plugs maybe the same haha
Old 04-21-2016, 08:59 PM   #252
Rican_D
Rican_D's Avatar
I can't believe there's no amp.
Another Android Head Unit Starscream15 Electronics | Audio | NAV | Infotainment 57 08-23-2015 12:41 AM
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. junglizste Audio/Visual, Electronics, Infotainment, NAV 3 01-08-2015 11:55 AM
Ca-Fi Dashlinq4 Android head unit universal Toyota phanguy Audio/Visual, Electronics, Infotainment, NAV 4 11-19-2014 11:57 AM
FS: T7019A Android Head Unit pheoxs Audio/Visual, Electronics, Infotainment, NAV 4 08-26-2013 05:05 PM
Android head unit drei Electronics | Audio | NAV | Infotainment 21 07-16-2012 02:42 AM
