Old 02-11-2015, 05:41 AM   #239
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
I tried it once too, and was pretty sure I hit the rev limit, so I don't think mine was turned on by default either. It doesn't help that it revs so much faster under boost, but I was thinking that we needed a lower limit like around 5500 for the ESC. We don't have max torque at the top end like a super/turbo, so for acceleration I think it would be better to drop down a little more into our power band.
Old 02-12-2015, 10:56 PM   #240
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Originally Posted by DAEMANO View Post
Should be enabled by default. Paging @Shiv@Openflash
I think I know why there's confusion. I just opened up the e85 map and it has FFS set to a 1000 by default. I'm assuming you are always on e85 now huh lol.
l0aded is offline   Reply With Quote
The Following User Says Thank You to l0aded For This Useful Post:
DAEMANO (02-13-2015)
Old 02-13-2015, 04:02 AM   #241
DAEMANO
Time Traveller
Yup
Old 02-15-2015, 11:39 AM   #242
BadHabit
Drives: 2013 FRS
Updated the Google Sheet. See below dyno images!
Thanks again @shif7i7down.
Stock with K@N Vs. OFT Tune
Stock with K@N Vs. ESC & OFT Tune
Note: A/F didn't seem to jive with what was seen in car and on other runs. Still need to compare to the OFT logs.
Stock with K@N Vs. ESC turned off & OFT Tune
Had to wrap up so took some quick pics. Plan to update with better images.
OFH UEL is now installed and plan on going back to the Dyno in a couple weeks.
2013 FRS Phantom ESC, OFT, K&N "SOLD"
2002 Z06 Tune, Bolt Ons
1995 Z28 STS Turbo, Meth, N2O, 700rwhp 740rwtq "SOLD"
2000 Audi B5 1.8T "SOLD"
BadHabit is offline   Reply With Quote
The Following 7 Users Say Thank You to BadHabit For This Useful Post:
DAEMANO (02-16-2015), predator800 (02-15-2015), raven1231 (02-15-2015), shif7i7down (02-15-2015), Shiv@Openflash (02-16-2015), Sojhinn (02-15-2015), Target70 (02-15-2015)
Old 02-15-2015, 01:11 PM   #243
raven1231
Bring some corn!
Old 02-15-2015, 05:20 PM   #244
shif7i7down
Erected Member
Drives: frs
Dang 209whp, impressive. I got 210 with e85. I bet when you go e85 its gonna be bad ass.
I'm willing to bet that with e85 and some sticky tires, your in the 13s easily
shif7i7down is offline   Reply With Quote
The Following 3 Users Say Thank You to shif7i7down For This Useful Post:
BadHabit (02-16-2015), DAEMANO (02-16-2015), raven1231 (02-15-2015)
Old 02-15-2015, 08:50 PM   #245
Target70
Target70's Avatar
thanks for the pics. Now that DR is gone, It shows that we really need an ESC intake bypass. I would like to see it in a single valve, but I think 3 separate 1" 1 way valves, running between the metal sleeve that ties the esc to the throttle body, to the connector between the esc and the intake box would really alleviate the drag in off boost situations. Now that I have gotten a lot more time with the system, I have noticed that DR kicks on for me all the time. A bypass would really help with our already weak mid throttle power.
I can't really find any larger valves, but this is kind of neat. [ame="https://www.youtube.com/watch?v=DG6own141z0"]How To Make a One-Way Check Valve - For Cheap!! - YouTube[/ame] maybe one large enough to fit a ping pong ball would flow well enough, or two/three smaller ones. I am just stuck on how to tap onto either the metal sleeve and/or the silicone coupler.
Old 02-16-2015, 02:03 AM   #246
DAEMANO
Time Traveller
209 without a header or e85 is solid. Great post man.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
BadHabit (02-16-2015), raven1231 (02-16-2015)
Old 02-16-2015, 05:14 PM   #247
shif7i7down
Erected Member
Drives: frs
all this on a ots canned tuned! I bet @shiv can probably squeeze out another 15+whp if anyone is willing to pay for an etune.
The Following User Says Thank You to shif7i7down For This Useful Post:
Old 02-16-2015, 05:28 PM   #248
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Great results. With the OFH installed you'll pick up some good power on top of that.
We are also 2-3 weeks away from having our Procede ESC controllers ready
The Following 6 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (02-16-2015), l0aded (02-18-2015), predator800 (02-17-2015), raven1231 (02-16-2015), SOAZ (02-16-2015), Sojhinn (02-16-2015)
Old 02-16-2015, 06:05 PM   #249
DAEMANO
Time Traveller
Definitely let us know about this. Thanks Shiv.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 02-16-2015, 06:09 PM   #250
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Let us know what we need to do.
Installed Mods:
Old 02-16-2015, 07:08 PM   #251
Shiv@Openflash
Drives: 2013 FRS
Absolutely guys. I'll be looking for a ESC equipped Frs/BRZ to visit us for testing in a few weeks. Should only take a few hours. Anyone?
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (02-16-2015), raven1231 (02-16-2015), Sojhinn (02-16-2015)
Old 02-16-2015, 07:09 PM   #252
Sojhinn
Sojhinn's Avatar
Phantom FTS Electric Supercharger Owners Thread
What weekend? I might be able to. @Shiv@Openflash
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
