Old 05-10-2018, 09:46 AM   #239
Originally Posted by new2subaru View Post
From what I've read you get a dash light when the tire(s) are 25% low.
(25% LOW ON AIR)
What are the point of these things again?
I have had mine go off with as little as 3 or 4 PSI below the 35 that they are set for. Even had them triggered by a cold night but when they warmed up they were bang on 35 so not sure where this 25% number came from.
Old 05-10-2018, 09:59 AM   #240
churchx
churchx's Avatar
Drives: 2014 GT86
Too lazy to search manuals and in manual (my, made in late 2013, has no TPMS, so probably also newer manual needed), but is TPMS light triggered by absolute pressure? Wasn't it "if tire pressure is lower then in other tires"?
Old 05-10-2018, 10:22 AM   #241
Vital
Drives: 2015 BRZ
Not sure about other countries, but in USA its required to have TPMS now. Yes, TPMS is triggered by pressure being low generally when tires are 25-26psi. It can also be triggered when temperatures get very low.
Vital is offline   Reply With Quote
Old 05-10-2018, 12:50 PM   #242
wparsons
wparsons's Avatar
I find the magic number on mine is ~28psi. I typically drop my tire pressure at track days to about 28psi cold and don't get the light all day until the drive home when the tires are actually cold again.
They're always triggered by pressure being too low, temperature does not trigger them directly. Temperature dropping will cause the pressure to drop though.
flickr
Old 05-10-2018, 01:01 PM   #243
DarkSideFRS
Drives: 2013 pearl white FR-S
can we go to a track if the low air indicator is on? getting my rims soon and debating if i should transfer over the TPMS. I am leaning to no
DarkSideFRS is offline   Reply With Quote
Old 05-10-2018, 09:54 PM   #244
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by Yoshoobaroo View Post
To keep people from driving around on 10PSI, which I see regularly on my commute still.
Some cars give you a readout on the on board computer for each wheel. Why we can't have that in every car is beyond me. BMW even got rid of individual readouts around 2010, apparently people were too confused
lol I would sign up for those! They make sense and it would be a fantastic tool.
Old 05-10-2018, 09:56 PM   #245
new2subaru
Weight Weenie
Drives: 15 FR-S
Read it on the net. I thought 25% was the magic number?
Old 05-10-2018, 09:57 PM   #246
Maybe some are. I don't know. All I know is that mine will come on well under 25%
Old 05-11-2018, 09:51 AM   #247
wparsons
wparsons's Avatar
Why wouldn't you be able to go on a track with the light on? The sensors are a requirement because people (in general) suck and will drive around with like 15 psi in a tire and not notice. If you're that unaware on a track, you probably shouldn't be on it in the first place.
I run my current tires at about 34 PSI hot (AD08R's seem to love lower pressures), which typically means ~28psi cold. At the start of the day or when I'm driving home I'll have the light on.
flickr
Old 05-11-2018, 03:00 PM   #248
DarkSideFRS
i have never been on a track, but i want to.. i know some have exhaust db limitations and some check for CELs... and since some check for CELs, i figured low air light as well... just making sure...
Old 05-11-2018, 03:49 PM   #249
The tire light is not a CEL so all is good.
Old 06-21-2019, 05:22 AM   #250
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Just to give folks more ideas / options, want to share my experience.
When I ordered my wheels at America's Tire, they said they can clone the IDs from my TPMS sensors to a set of new TPMS sensors, and then I can swap between sets of wheels with no problems.
The line on the receipt says
SCH 33520 TQ12 T10 315/433 EZ TPMS SENS SNAP IN 33520
— I presume these are Schrader EZ-sensor.
They used Bartec Tech400Pro to do the ID cloning.
Sadly, I couldn't confirm if the sensors worked afterwards, since the wheels didn't fit, but that's a different story.
timurrrr is offline   Reply With Quote
TPMS Sensors.. Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 31 04-08-2014 02:22 PM
Subaru TPMS Nonsense Grimlock BRZ First-Gen (2012+) — General Topics 67 10-07-2013 04:15 PM
TPMS Sensors ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 78 05-24-2013 05:24 PM
Auto Parking Sensors? Swancoat Scion FR-S / Toyota 86 GT86 General Forum 84 02-18-2012 03:01 AM
