| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#239 |
I have had mine go off with as little as 3 or 4 PSI below the 35 that they are set for. Even had them triggered by a cold night but when they warmed up they were bang on 35 so not sure where this 25% number came from.
#240 |
Drives: 2014 GT86
Too lazy to search manuals and in manual (my, made in late 2013, has no TPMS, so probably also newer manual needed), but is TPMS light triggered by absolute pressure? Wasn't it "if tire pressure is lower then in other tires"?
#241 |
Drives: 2015 BRZ
Not sure about other countries, but in USA its required to have TPMS now. Yes, TPMS is triggered by pressure being low generally when tires are 25-26psi. It can also be triggered when temperatures get very low.
#242 | |
They're always triggered by pressure being too low, temperature does not trigger them directly. Temperature dropping will cause the pressure to drop though.
| The Following 3 Users Say Thank You to wparsons For This Useful Post: |
#243 |
Drives: 2013 pearl white FR-S
can we go to a track if the low air indicator is on? getting my rims soon and debating if i should transfer over the TPMS. I am leaning to no
#244 | |
Weight Weenie
Drives: 15 FR-S
#245 |
Weight Weenie
Drives: 15 FR-S
Read it on the net. I thought 25% was the magic number?
#246 |
Maybe some are. I don't know. All I know is that mine will come on well under 25%
#247 | |
Why wouldn't you be able to go on a track with the light on? The sensors are a requirement because people (in general) suck and will drive around with like 15 psi in a tire and not notice. If you're that unaware on a track, you probably shouldn't be on it in the first place. I run my current tires at about 34 PSI hot (AD08R's seem to love lower pressures), which typically means ~28psi cold. At the start of the day or when I'm driving home I'll have the light on.
#248 | |
#249 |
The tire light is not a CEL so all is good.
| The Following User Says Thank You to Tcoat For This Useful Post: | wparsons (05-11-2018) |
#250 |
Drives: 2022 GR86
Just to give folks more ideas / options, want to share my experience.
When I ordered my wheels at America's Tire, they said they can clone the IDs from my TPMS sensors to a set of new TPMS sensors, and then I can swap between sets of wheels with no problems. The line on the receipt says SCH 33520 TQ12 T10 315/433 EZ TPMS SENS SNAP IN 33520 — I presume these are Schrader EZ-sensor. They used Bartec Tech400Pro to do the ID cloning. Sadly, I couldn't confirm if the sensors worked afterwards, since the wheels didn't fit, but that's a different story. |
| TPMS Sensors.. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 04-08-2014 01:22 PM |
| Subaru TPMS Nonsense | Grimlock | BRZ First-Gen (2012+) — General Topics | 67 | 10-07-2013 03:15 PM |
| TPMS Sensors | ashtray | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 78 | 05-24-2013 04:24 PM |
| Auto Parking Sensors? | Swancoat | Scion FR-S / Toyota 86 GT86 General Forum | 84 | 02-18-2012 02:01 AM |
