Old 06-28-2013, 11:40 AM   #239
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
when i read "Electric", i was like "another ricer" and read all posts --> WOW!!!
Old 06-28-2013, 11:51 AM   #240
mid_life_crisis
Drives: FR-S 10 #103 AT
What a concept. Why can't you be contagious?
Old 06-28-2013, 11:59 AM   #241
mid_life_crisis
Originally Posted by FT_Monk View Post
To the OP, how is the motor attach to the compressor wheel of the turbo? Does it only turns the turbo shaft and needs oiling or the motor is attached directly to the compressor wheel?
Thanks.
This is a good question. Is the compressor wheel dependent on the motor's driveshaft? That could be a wear problem down the road. I don't remember how long the previous installations have been running. Any kind of longevity tests done either methodically or just by being out there in customer cars?
Old 06-28-2013, 12:07 PM   #242
fenton
I cant speak to the connections specifically but i can get the info from the designer. I believe it is a package unit as the tolerances are VERY important in a system that spins at 50,000 rpm. You dont want to be willy nilly swaping motors back and forth.
The system has been on a couple cars for over 40,000 km daily driven and they are doing just as good as the day they were installed.
The key here is that the turbo is internally lubricated and honestly we are spinning it at its lowest efficiency rating.
fenton is offline   Reply With Quote
Old 06-28-2013, 12:18 PM   #243
mid_life_crisis
I wonder what the compressor itself is made of. Would investing in the lightest material available help reduce battery drain and let it run longer and/or allow the use of a larger turbine to help with that upper end boost?
Old 06-28-2013, 12:25 PM   #244
Yruyur
Yruyur's Avatar
Or twin setups for different rpm ranges
Old 06-28-2013, 12:29 PM   #245
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Or four electric superchargers; one for each intake runner via a custom manifold.
Old 06-28-2013, 12:40 PM   #246
CBR600RR
Drives: Raven Black
@fenton
What are the chances of you running the quater mile to see how this E-charger has improved accelleration?
Old 06-28-2013, 12:43 PM   #247
brichard0625
brichard0625's Avatar
Drives: 2013 Scion Frs(Scarlet)
Or even a little pull to 60 or 80 to see how it runs...give us something lol...if this thing ends up costing 2000 or less ill buy it
brichard0625 is offline   Reply With Quote
Old 06-28-2013, 12:44 PM   #248
fenton
Originally Posted by CBR600RR View Post
@fenton
Official 1/4 mile is not likely, they shut down our race track this year
Could do a simulated one maybe?
Old 06-28-2013, 12:45 PM   #249
fenton
Oh dont worry im going to come with lots of that stuff this weekend once i get a go pro.
Old 06-28-2013, 12:48 PM   #250
neutron256
neutron256's Avatar
Drives: '13 GBS Subaru BRZ
Originally Posted by jamesm View Post
no one with half a brain is going to put rapidly charging and discharging lipo batteries in their engine bay. that is a recipe for disaster. there are way too many variables that could cause the thing to incinerate everything around it. i've seen lipos explode from light impact, overcharging, excessive draw, just about anything can make them light up like a christmas tree. i have no experience with LiFePO4, so they may or may not be more stable. in any case, lipos are simply not safe for use in that type of environment.
here's an example:
LiFePO4 batteries don't experience thermal runaway so are basically immune to lighting on fire like this. They are no where near the power density but of LiPO batteries but the are a nice stable middle ground. I used them for the electric bike I built and they worked great.
LiFePO4 batteries also have very good peak current characteristics, and longer cycle lifes (i.e. they can be charged/discharged more times before failing).
Old 06-28-2013, 12:51 PM   #251
Toma
Drives: Viper, Mustang, FD RX7, FFR GTM
Edmonton is not far.... 2.5 hours. We go all the time. It's at 2500 feet static elevation, so for the numbers to mean anything, you could make 2 na runs and the 2 supercharged runs.
Since this thing adds mostly at the bottom, I would say zero to 60 is where it will shine best. ...if it hooks up lol.
Toma is offline   Reply With Quote
Old 06-28-2013, 01:11 PM   #252
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by fenton View Post
Next up, AFR's STOCK vs STOCK with super:
First off, incredible gains! Thanks for sharing the development of this, thus far.
What's going on with the AFR's here, the pic is a little hard to read? Did the stock car start off WAY lean?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
