#239 |
Drives: SWP BRZ
when i read "Electric", i was like "another ricer" and read all posts --> WOW!!!
#240 |
Drives: FR-S 10 #103 AT
What a concept. Why can't you be contagious?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#241 |
This is a good question. Is the compressor wheel dependent on the motor's driveshaft? That could be a wear problem down the road. I don't remember how long the previous installations have been running. Any kind of longevity tests done either methodically or just by being out there in customer cars?
#242 | |
The system has been on a couple cars for over 40,000 km daily driven and they are doing just as good as the day they were installed. The key here is that the turbo is internally lubricated and honestly we are spinning it at its lowest efficiency rating. |
#243 |
I wonder what the compressor itself is made of. Would investing in the lightest material available help reduce battery drain and let it run longer and/or allow the use of a larger turbine to help with that upper end boost?
#244 |
Or twin setups for different rpm ranges
Sent from my SCH-I535 using Tapatalk 2 |
#245 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
#247 |
Drives: 2013 Scion Frs(Scarlet)
Or even a little pull to 60 or 80 to see how it runs...give us something lol...if this thing ends up costing 2000 or less ill buy it
#248 | |
![]() Could do a simulated one maybe? |
#249 |
#250 | |
Drives: '13 GBS Subaru BRZ
LiFePO4 batteries also have very good peak current characteristics, and longer cycle lifes (i.e. they can be charged/discharged more times before failing).
#251 |
Drives: Viper, Mustang, FD RX7, FFR GTM
Edmonton is not far.... 2.5 hours. We go all the time. It's at 2500 feet static elevation, so for the numbers to mean anything, you could make 2 na runs and the 2 supercharged runs.
Since this thing adds mostly at the bottom, I would say zero to 60 is where it will shine best. ...if it hooks up lol. |
#252 |
That Guy
Drives: 2013 asphalt FRS MT
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
