Old 05-02-2018, 05:23 AM   #239
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Originally Posted by Harey View Post
Because it keeps going
There are so many high powered 86s out there running awesome lap times. How do they do increase power and keep it handling well is all im really asking.
Lap times do not necessarily indicate good handling. Handling is entirely subjective. A Geo Metro on R compounds and a massive turbo will turn awesome lap times for a Metro, but according to a lot of people it won't handle well.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Spuds (05-02-2018), Tcoat (05-02-2018)
Old 05-02-2018, 11:10 AM   #240
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Mine handles great. Here is what I did:
Suspension and Steering
TRD lowering springs
TRD sway bars
Yoshihara D5C 18x8 +40 rims w/Michelin Pilot Super Sport tires
Heavy Duty Steering Rack Bushings
STI Upgraded Steering Rack Bolts
Anti-Lift/Caster Bushing Kit
Front Control Arm Rear Bushings
Rear Trailing Arm Bushings
Front Toe Arm Bushings
Inner Lower Rear Control Arm Bushings
roll center adjuster set
Engine & Drivetrain
Jackson Racing Supercharger
Jackson Racing Oil Cooler
Jackson Racing Aluminum Neck Filler/Radiator Cap
DW 700CC injectors
DW 300c Fuel Pump
Delicious Tuning Flex Fuel MK1+ Kit
Custom Tune by William Knose of Delicious Tuning
TRD exhaust
South Bend Stage 2 Daily clutch
Velox Billet Shift Fork and Pivot
TRD Japan short shifter
DSS Carbon Fiber Driveshaft
Rear Sub frame Insert bushings
Rear Differential Inserts
Transmission Bushing Insert
Brakes
DBA 4000 drilled and slotted rotors
DS2500 Ferodo brake pads
Perrin master cylinder brace
Mann Engineering Stainless Steel Brake Lines
Harey (05-02-2018), mrg666 (05-02-2018)
Old 05-02-2018, 02:09 PM   #241
NOHOME
Drives: RAVEN
No secret there.
They spend more $$$ than what it cost to buy the car
They give up reliability
They give up comfort
They give up resale value
They go into denial about all of the above.
NOHOME is offline   Reply With Quote
The Following 3 Users Say Thank You to NOHOME For This Useful Post:
funwheeldrive (05-02-2018), PhyrraM (05-02-2018), Vic4uf (05-02-2018)
Old 05-02-2018, 02:28 PM   #242
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by NOHOME View Post
No secret there.
They spend more $$$ than what it cost to buy the car (it does cost to play)
They give up reliability (not really)
They give up comfort (depends on your setup. Mine is setup for street so quite comfy)
They give up resale value (seriously? Yea, non modded cars are worth a fortune)
They go into denial about all of the above. ( envious much?)
Lol
mrg666 (05-02-2018)
Old 05-02-2018, 02:57 PM   #243
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I missed seeing this until niki was kind enough to bring it up.
:b
Yes, agreed these things can be measured but that does not define a car as "ruined" or not. There are still some that will prefer one aspect over another and will say the guy that likes something else is dead wrong. That is why I don't think you will ever get a black and white answer to a very gray question.
The question is how you can modify without ruining too much or even at all of how the car came from the factory. It is like improving the details of something that was already good and not trying to change it entirely. Some don't care about the latter and they'll swap the engine or install a turbo to get 300+ hp or strip the interior or whatever, but then you have something entirely different from what you had in first place.
Old 05-02-2018, 03:00 PM   #244
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Originally Posted by nikitopo View Post
:b
....but then you have something entirely different from what you had in first place.
And that's ok. Still not ruined.
Tcoat (05-02-2018)
Old 05-02-2018, 03:04 PM   #245
:b
That is just it. There is no definition of "ruined". What one will say is the worst thing ever somebody else will think is the best. If we are talking keeping it as intended from the factory then even changing the tires could be classified as "ruining" it. The people that have done major modifications do not think they ruined anything. Well... most don't at any rate.
mrg666 (05-02-2018), Sapphireho (05-02-2018)
Old 05-02-2018, 03:09 PM   #246
Exactly!
Yours is probably one of, if not the best, jobs I have seen as far as adding power and doing all the work required to support that power. Is it "ruined" in my mind? Most certainly not. Is it what I would want for myself? Again most certainly not. Different goals, plan of use, driving conditions and even styles mean each person needs to decide what they want but these wants and needs "ruin" nothing about the car. They just change it.
Old 05-02-2018, 03:26 PM   #247
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
People would get it easier if they lived in a country that has rules of what you can change and what not. A car is supposed to be driven on public streets, to be safe and in general comply with regulations. Otherwise, it can be a weapon and it can even kill.
Factory provided many modifications on special edition models etc. There are a lot of options without going too aggressive or breaking the law ...
The Following User Says Thank You to nikitopo For This Useful Post:
Old 05-02-2018, 05:53 PM   #248
Sapphireho
Famous Potatoes
Sapphireho's Avatar
No, I totally get that you do not get it.
My car is 100% safety and smog legal.
Any car in the hands of an idiot can kill people.
Living in a country with an oppressive government doesn't have anything to do with the subject.
You are really reaching now.
funwheeldrive (05-02-2018), olsonpg (05-02-2018)
Old 05-02-2018, 05:54 PM   #249
NOHOME
Drives: RAVEN
Lol
What exactly am I supposed to be envious of?
Old 05-02-2018, 06:03 PM   #250
Sapphireho
Famous Potatoes
Sapphireho's Avatar
You tell me? Why else would you post of your self diagnosis of someone else's "denial"?
Old 05-02-2018, 06:56 PM   #251
mrg666
pessimistic skeptic
mrg666's Avatar
So, did guys decide if my car is ruined? So curious!
Old 05-02-2018, 07:03 PM   #252
Impureclient
Drives: 2015 FR-S
So 18 pages later, is there any kind of consensus here? The engineers over at Toyota/Subaru can't wait forever for this to have some kind of conclusion so they can move forward.
Impureclient is offline   Reply With Quote
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
olsonpg (05-02-2018), Tcoat (05-02-2018)
CNET on 86: More power would ruin it Guru Woodman FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 52 03-04-2017 06:19 PM
I don't want to ruin my dream car. TruthfulDeception Engine, Exhaust, Transmission 28 03-23-2016 11:40 PM
Wheels that won't ruin the ride Rudiger Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-21-2012 04:40 AM
Will FI Ruin the Balance of FRS/BRZ? ZmZMWagon Other Vehicles & General Automotive Discussions 8 04-13-2012 12:19 AM
Why govt ruin everything 1660 Off-Topic Lounge [WARNING: NO POLITICS] 11 12-27-2009 04:52 PM
