02-08-2015, 10:04 PM | #2465 |
Drives: Raven 6MT
Two questions:
1. When going into a turn that requires you to downshift two gears, is it better to go through each until you reach the desired gear or to just slow down enough then place it in the desired gear? I would heel/toe regardless.... 2. I was at CMP this weekend and changed tires at the track. The installer informed me that i have two bent wheels, but to my eye i can't tell. He was able to balance them out just fine but is it a good idea to replace them immediately, or can i potentially be fine for a while? I honestly can't tell a difference when driving and because I really only drive to and from the track, this could have happened almost a year ago when I installed the wheels. ...
Goodridge SS brake lines//ProjectMu 999's//Motul DOT 5.1 brake fluid//GrimmSpeed master cylinder brace//Jackson Racing Oil Cooler//Whiteline camber bolts//Raceseng CamCas plates//Kosei K4R 17x8//BFGoodrich Rivals 225/45
02-08-2015, 10:27 PM | #2467 |
02-08-2015, 10:29 PM | #2468 | |
2. If they balance fine, and aren't leaking, keep using them. Keep in mind that they won't be as strong since the structure is now compromised. |
02-08-2015, 10:35 PM | #2469 |
Drives: 2012 Toyota 86
02-08-2015, 11:54 PM | #2470 |
Drives: GT-86
02-09-2015, 12:15 AM | #2471 |
It's a bit more, but you get a lot more helmet for your dollar. I've used both extensively at some driving schools, and the HJC is just flat out better built, and will last you a lot longer.
The Following User Says Thank You to CSG Mike For This Useful Post: | acro (02-09-2015) |
02-09-2015, 02:05 AM | #2472 |
I used a HJC SI-12 for a long time and it was really great.
One comment with any helmet though: use a head sock / balaclava. It helps reduce the wear on the chin pads. I ended up wearing through my chin pads and had to send my helmet off for warranty service. HJC was great about getting it fixed, but I would have liked it better if I didn't have to deal with any warranty stuff.
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next! |
02-09-2015, 11:34 AM | #2473 |
I have a question on track etiquette.
This weekend I was working on my line into the fastest corner on the local track, slight right hander coming up over a hill. I had always late apexed it, mainly out of fear because there is not a ton of room to run off on the left side of the track, and was always pinching the corner and scrubbing speed. I was working on apexing earlier and carrying more speed through the corner, I was able to add about 5 mph. The first lap of the next session I ended up apexing a bit too early and went four off just outside the track and the guy behind me followed me and went two off. We have been at several events together and have become acquaintances. He came up after the session and told me I threw some rocks up when I went off that cracked his windshield. I felt pretty bad and apologized. He seemed to be fishing for me to pay for the windshield, but I had always heard that each driver is responsible for the damage to their car on track regardless of whose fault. What are your guys thoughts on the situation and how would you handle it? Video added - because who doesn't like seeing others mistakes. Sorry for the poor quality. [ame="https://www.youtube.com/watch?v=dyP910TAEhE"]Ricochet - YouTube[/ame] Last edited by Jonsey; 02-09-2015 at 01:35 PM. |
The Following User Says Thank You to Jonsey For This Useful Post: | acro (02-09-2015) |
02-09-2015, 12:14 PM | #2474 |
IANAL, but your description sounds like a "racing incident", ie. the kind of damage that just happens on a track. The key point of liability, to me, is when negligence comes into play. Since going four off is something that happens and is accepted (and should be avoided), I personally wouldn't expect that rocks being kicked up in the process to be seen as extraordinary conditions worthy of any liability on your part.
02-09-2015, 12:22 PM | #2475 | |
Now if there had been an incident that was 100% your fault, then you may want to consider helping out the other party, but in this case, a cracked windshield is nobody's fault; it just happens. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Jonsey (02-09-2015) |
02-09-2015, 12:45 PM | #2476 | |
i'm sorry, what?
Drives: Canada
lol, fuck him. unless you threw those rocks at him yourself, out the side window while flipping the bird, then it's just tough luck. And if anything, more his fault than yours, seems like he was following you so close that he made the same mistake in corner entry... that's like one of the biggest no-no's in racing/lapping, don't let the driver in front of you zone you into a tunnel. It sucks that his glass got scratched but it ain't your problem.
02-09-2015, 01:41 PM | #2477 | |
In the future, it would be better if you went to zero lock a tad bit sooner to get the weight off the outside wheels; you don't want to have them dig in and roll the car.
02-09-2015, 01:48 PM | #2478 |
You are right, I should have gone zero lock a tad bit sooner, however, it never felt close to a spin or out of control. Perhaps I am missing something, but I don't see it in the video either.
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
