Old 01-26-2015, 12:41 AM   #2451
CSG David
CSG David's Avatar
I have these drain plugs fitted to gearbox and diff housing. It was difficult to get the diff plug in because the magnet is so strong it kept on grabbing the housing. They made the oem plugs look so wimpy by comparison.
http://www.drainplugmagnets.com/
The OEM is still pretty good though so I wouldn't discount the legit-ness of the unit. I've always seen aftermarket ones. Some seem to be really good, but I can't figure out the usefulness of them especially since seeing large particles just generally means you're effed already. LOL
Old 01-26-2015, 01:14 AM   #2452
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by CSG David View Post
What's the reason with going with the 16s instead of the 17s?
I had read in amongst the internet noise that 16 inch were better but for the reasons I gave above I couldn't really see much advantage except for the 2kg saving. I think my wallet will tell me no on this one and I suspect I will listen.
Old 01-27-2015, 05:28 AM   #2453
Junkwipe
Drives: Toyota Gt86
Hi guys. Is turbo kit a must be for doing time attack or just intake, exhaust, ecu tuning and coulovers are ok for compete with the others?
Junkwipe is offline   Reply With Quote
Old 01-27-2015, 10:35 AM   #2454
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Racing is all about class rules.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Campo (01-28-2015)
Old 01-27-2015, 01:31 PM   #2455
CSG Mike
CSG Mike's Avatar
It all depends on the rules of your local series.
The less modified the car is, the more reliable, and generally, the easier it is to drive.
If you have a link that's in english, I can help you decide on a class.
Old 01-29-2015, 09:56 AM   #2456
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Hey, guys! I've decided I'm going to run ZII Star Specs on my CS car this year, but am having trouble deciding on size. I'm going to run either 235/40 or 235/45, but I'm unsure if one will give me an advantage in gearing over the other. Can you guys shed any light on this? Thanks!
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-29-2015, 10:15 AM   #2457
Junkwipe
Drives: Toyota Gt86
Thanks a lot. This was just a curiosity about the best use of the car on a track
Old 01-29-2015, 12:06 PM   #2458
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
Depends on course design. If you tend to have huge parking lots with over 55 or 60 mph top speeds, the taller tire is the better choice.
If you tend to have short, tight courses, either could work.
FWIW, I was running 235/45 R-S3s last year and was perfectly happy with that size. The speedo is only off by a few mph and actually "more correct" because the safety factor built into the speedo is neutralized by the taller tire.
bimmer635csi is offline   Reply With Quote
Old 02-07-2015, 08:51 AM   #2459
troek
troek's Avatar
Drives: 2012 Toyota 86
project mu racing 999 vs racing 777. Anyone have any experience with the differences? Ive outgrown the HC+/HC-CS range sadly.
troek is offline   Reply With Quote
Old 02-07-2015, 10:49 AM   #2460
CSG Mike
CSG Mike's Avatar
Yes!
999 has more bite and is friendlier to disks, but the 777 lasts longer. The 777 also has a smaller temperature range; it likes to be at a higher heat range to be consistent.
Unless you have a specific need for longer pad life (long sprint races), you probably want the 999.
troek (02-07-2015)
Old 02-07-2015, 01:14 PM   #2461
troek
troek's Avatar
Yes!
999 it is. Im ordering some motul 300 from you guys, i wish i was getting the pads too, but as the originate in japan, it just makes more sense for me to get them locally. Actually having issue now with the FPO AP address on your site, any ideas? @CSG Mike @CSG David
Old 02-07-2015, 10:43 PM   #2462
CSG Mike
CSG Mike's Avatar
Shipping Motul to Japan is going to be REALLY expensive.... I hate to turn business away from CSG since they let me drive their cars, but you're probably better off getting it locally...
Old 02-07-2015, 11:11 PM   #2463
troek
troek's Avatar
no i have a usps address, it ships to san francisco, then the military picks it up from there. im assuming the site is set up to work with UPS, and i can only use USPS.
The Following User Says Thank You to troek For This Useful Post:
CSG Mike (02-08-2015)
Old 02-08-2015, 12:28 AM   #2464
acro
Drives: GT-86
I am looking for a helmet
I narrowed it to the Racequip sportmod vs Zamp FSA-2 vs zamp RZ 34
There are no shops that sell helmets anywhere near me so it will have to be an interenet order. Thanks in advance
acro is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
