Old 10-25-2013, 01:53 AM   #2409
jpit
Drives: Subaru BRZ
No aftermarket radio. How would that help?
jpit is offline   Reply With Quote
Old 10-25-2013, 01:55 AM   #2410
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Tie into the power antenna connector. Therefore every time the head unit is on (only drawback) esc is on.
Installed Mods:
Old 10-25-2013, 02:04 AM   #2411
Sojhinn
Sojhinn's Avatar
What fuse box are you trying to hit btw?
Installed Mods:
Old 10-25-2013, 02:17 AM   #2412
jpit
Drives: Subaru BRZ
The one in the engine compartment. I wouldn't have any trouble finding one in the fuse box under the left side of the dash. Rob had recommended the fuse box right by the controller.
Old 10-25-2013, 02:29 AM   #2413
Grantmac
Drives: 2001 NB MX-5
12v from the DRL relay maybe? Always on unless the ebrake is pulled.
-Grant
Grantmac is offline   Reply With Quote
Old 10-25-2013, 03:32 AM   #2414
asher187
Drives: 2013 FR-S, 1995 Civic Coupe
http://www.ft86club.com/forums/showthread.php?p=1166113
maybe the fuse for the Radiator fan? I've only done light research found this thread about wiring.
asher187 is offline   Reply With Quote
Old 10-25-2013, 08:15 AM   #2415
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Yes, the DRL would work perfectly as it is a switched output. Make sure you use the protected side of the fuse.
BTW the circuit is always on with the ignition, it is a relay that turns off the DRL with the ebrake.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 10-25-2013, 09:17 AM   #2416
Sojhinn
Sojhinn's Avatar
Should we use a fuse tap on there? Two days and I already left the switch on once.
Installed Mods:
Old 10-25-2013, 10:45 AM   #2417
Gary in NJ
Gary in NJ's Avatar
OK, I just did some poking around in the engine compartment fuse box to find a fuse circuit that was switched with the ignition. Unfortunately DRL is not available in the engine compartment fuse box. Many of the circuits that I thought may be fused (like washer, wiper, mirror defogger...) are only active when the device is powered. But I did find one that is switched with the ignition yet is always active. Circuit number 28, ECU (a 15A breaker) is switched with the ignition and active.
Sojhinn, I would use a fuse tap. I would also recommend using an in-line 5A fuse as the fuse for the ECU will not protect the control line for the ESC. Further, I wouldn't want a dead short in the ECU control line to bring down the ECU circuit.
@Robftss, if we use the DPDT relay as shown in post #2399, will it still fit through the sound tube hole in the firewall? If not this will have to be soldered in place or we will need to fashion some type of connector in the harness so the DPDT relay can be removed to feed the wire and then inserted once in place.
Old 10-25-2013, 11:20 AM   #2418
jpit
Drives: Subaru BRZ
Gary,
I show circuit 28 to be an EFI fuse. Is this the one you are referring to?
Old 10-25-2013, 11:26 AM   #2419
rusty959
Drives: DGM BRZ limited
Is the cigarette lighter outlet in the glove box switched? I'm guessing it is, and the glove box/behind the glove box would be a fine place to stash a relay.
rusty959 is offline   Reply With Quote
Old 10-25-2013, 11:37 AM   #2420
mid_life_crisis
Drives: FR-S 10 #103 AT
With this in mind, even a 5 amp fuse is excessive. The relay contacts are rated at 5 amps. The coil draw is ~70 milliamps. A one amp fuse is plenty.
Old 10-25-2013, 11:44 AM   #2421
jpit
Drives: Subaru BRZ
Gary,
When I test #28 I get 12V readings from both sides with the ignition off.
Old 10-25-2013, 11:53 AM   #2422
HunterGreene
Hail Magnet
HunterGreene's Avatar
I know the cig lighter is switched
It has priests in it?
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
