Old 10-02-2013, 01:38 PM   #225
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Originally Posted by nguyen_er View Post
Is the no lift shifting already activated when you flash the ecu?
u have to set the rpm in the pro tuner. i tried it really undriveable the way the clutch switch is setup
IG-Joey_Soul
Old 10-02-2013, 02:28 PM   #226
nguyen_er
nguyen_er's Avatar
Drives: 2013 Raven FR-S
Oh alright thanks! I'm so noob to tuning.. It took me forever to flash it too haha fail...
nguyen_er is offline   Reply With Quote
Old 10-02-2013, 09:00 PM   #227
akyp
Drives: 2012 86
Originally Posted by cnk View Post
The nice thing is that you can open the stock rom you pulled before flashing and compare it to the new one to see the differences.
Sent from my SAMSUNG-SGH-I717 using Tapatalk 4
I have yet to purchase it (waiting for RHD support). So are the stock and tuned throttle mapping different?
akyp is offline   Reply With Quote
Old 10-02-2013, 09:03 PM   #228
cnk
Drives: '13 DGM BRZ Limited
You don't have to purchase it to look at the maps. Just go to their site and download the maps and the TunerPro software and you can open and do a stare and compare.
Did a quick compare of my stock and Stg 1.1 map. I'm still new to all this, but if the throttle map is the Accel Pedal - Torque Request table, then yes, there are differences. It starts at 3600 rpm and goes to redline. No changes under 3600 rpm. Using the compare tool to determine all differences between the 2 maps shows multiple differences to a bunch of maps so the tune is not just a modified throttle input map.
cnk is offline   Reply With Quote
Old 10-02-2013, 10:07 PM   #229
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Correct. Most of the effective differences between the v1 and v1.1 are in the VVT maps. Just some changes that improved torque in in the 2800-3400rpm range.
Old 10-02-2013, 10:08 PM   #230
Shiv@Openflash
Drives: 2013 FRS
We now support RHD (non-US) cars. You will have to email me your ROM after you read it with the OFT. After that, I will create a map for you and email it back for you to load into the OFT and write to your ECU.
Cheers,
Shiv
Old 10-03-2013, 01:57 AM   #231
akyp
Drives: 2012 86
Cheers,
Shiv
Thanks. One more question: My ROM's version is 00. Should I go to the dealership to ask for an update to 01, or does it not matter?
Old 10-03-2013, 02:18 AM   #232
cuddefred
Drives: Black 86 GT
Can this be used yet by those of us who have previously flashed the ECU with Ecutek?
cuddefred is offline   Reply With Quote
Old 10-03-2013, 02:28 AM   #233
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
I don't see why it couldn't. My question would be for those who've already used Ecutek, will the tablet permanently backup the Ecutek tune instead of the factory tune? Doesn't it write the current map to ROM storage the first time it's hooked up to the car as a safety backup? What if that person wants to flash back to stock for a visit to the dealership? Can the factory tunes be downloaded?
None of this actually applies to me, I'm just curious.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 10-03-2013, 03:49 AM   #234
Shiv@Openflash
Drives: 2013 FRS
It won't hurt to ask for the newest software since it incorporates the DI seal fix. But all our tuned ROMs already have this fix to it really makes no difference.
Old 10-03-2013, 03:52 AM   #235
Shiv@Openflash
Drives: 2013 FRS
The problem with an Ecutek flashed ECU isn't with read the ECU (by the OFT) but rather writing on top of the Ecutek flash (with the OFT). The Ecutek flash employs some kind of write protection which makes it impossible to write on top of. This is why Ecutek users should flash their ECU with the stock ROM that Ecutek provides upon request. Unfortunately, this means that you need to have the Ecutek programming cable (or access to one) or need to re-visit the tuner who flashed your car (if you don't have a cable).
Shiv
Old 10-03-2013, 04:24 PM   #236
cnk
You guys will like the stage 2 map. In fact, I'll be incorporating a lot of the stuff I've learned into a new release of the stage 1 map. Been testing it for the past several says and really happy with it. It looks like the partial throttle knock sensitity issue (2700-3200rpm) that even the stock tune has (which drops the IAM) has been sorted. As well as the issue with long term fuel trims creeping up. Just going to test it for a few more days before releasing it
Any updates on the updated Stage 1 map you mentioned above?
Old 10-03-2013, 05:43 PM   #237
cuddefred
Drives: Black 86 GT
Thanks Shiv, much appreciated.
Shiv
Old 10-03-2013, 05:49 PM   #238
Shiv@Openflash
Drives: 2013 FRS
Yep.. we will be releasing an updates Stg1 map along with the new Stg2 map (for cars with catless headers) sometime during the next few days
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
