01-06-2022, 03:35 PM | #225 | |
Drives: 2022 BRZ Premium
This looks perfect! Thanks for posting. I plan to go with this exact setup, just with a 17" wheel. Seems like 8" wheel with +35 and maybe a 1" drop would be the perfect OEM+ set up. |
The Following User Says Thank You to soilent For This Useful Post: | Panda Grahams (01-06-2022) |
01-06-2022, 05:00 PM | #226 | |
Drives: 22 BRZ limited
Firstly, they fit! Now the shock bolt hole is about half a hole or so inboard of the stock arm. The shock ends up sitting a bit more upright. Now I don't know if this was the same on the pre '22 models. |
The Following User Says Thank You to dragoontwo For This Useful Post: | dsc_pat (01-06-2022) |
01-06-2022, 05:45 PM | #227 | |
Drives: '22 BRZ Limited 6MT
The Following User Says Thank You to sds For This Useful Post: | dsc_pat (01-06-2022) |
01-06-2022, 07:28 PM | #228 | |
Drives: 2022 GR86
Your photos make me think that something like an 18x8 +45 would work well on a car that won’t be lowered, or lowered with OEM camber maintained. |
The Following User Says Thank You to Chris_f For This Useful Post: | Panda Grahams (01-06-2022) |
01-06-2022, 07:50 PM | #229 | |
Drives: Too fast
I am pretty sure the cam bolt should be into the frame side...not at the trailing arm end. |
01-06-2022, 08:26 PM | #230 | |
The cam bolt is installed correctly. |
01-07-2022, 09:17 AM | #231 |
Drives: Too fast
You are right, it goes in the slotted hole.
01-07-2022, 10:40 AM | #232 |
Drives: 2022 crystal white BRZ
Hey guys, bit the bullet and bought some wheels/tires for the cold weather.
Apex Arc-8 17x9 ET42 with Sumitomo HTR A/S P03 in 245/40/17. it's an 8" tread width so narrower than some other tires. They'll uhhh... *technically* fit and clear the struts on stock suspension. No rubbing full lock turning. I haven't been able to drive enough to see if it will rub under high compression but my gut says it shouldn't. The first photo is with a 3mm spacer, and the second photo with the tire mounted is no spacer at all. little too much poke with the space for my liking. Coilovers have been moved to the top of the "next thing to mod" list. |
The Following 2 Users Say Thank You to CZ6T For This Useful Post: | Pete (01-07-2022), PNW Shaggy (01-07-2022) |
01-07-2022, 10:43 AM | #233 |
Drives: 2022 BRZ
Did you install ARP extended studs? I got the same wheels and realized yesterday that I was "only" getting 8 full turns when tighting the lug nuts and thats with no spacers.
01-07-2022, 11:28 AM | #234 | |
No studs, still using the factory ones. I didn't think about counting the turns since I wasn't using a spacer, but I also didn't count the turns with the stock wheel either. I'd be curious to see what it is on a stock wheel with no spacer. |
01-07-2022, 02:04 PM | #235 |
Drives: 2022 GR86
01-07-2022, 02:07 PM | #236 |
01-07-2022, 04:17 PM | #237 | |
Nothing ever rubbed at the track when I ran it so I'm hoping that the same will be true for the new car since I'm planning on keeping the suspension stock. |
01-08-2022, 03:12 PM | #238 | |
Drives: 2015 FRS for daily and track use
I have the same SPC arms we will try on our 2022 when putting in the coilovers. Did you happen to measure the distance between the subframe attachment point and the shock and knuckle attachments points between the SPC and 2022 arms? |
Similar Threads | ||||
Rear wheel alignment issues... HELP! | Rambo305kid | Issues | Warranty | Recalls / TSB | 10 | 07-05-2020 10:05 PM |
Wheel Fitment Issues. Need help. | hay_frs | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 8 | 04-06-2020 06:09 PM |
Fitment issues | Neal86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-07-2019 07:08 PM |
Tire/Wheel fitment (rear) | rikixass | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 01-17-2018 04:09 PM |
Fitment Issues | Silp3 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2013 03:34 PM |
