Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-06-2022, 03:35 PM   #225
soilent
Drives: 2022 BRZ Premium
Originally Posted by Panda Grahams View Post
Picked the car up from the dealership last night. Immediately swapped the stock wheels/tires to a set of RPF1s 18x8 +35, with winter tires in 225/40r/18. I am thrilled with how it turned out. Zero rubbing, and plenty of clearance to the front strut tower. I plan to lower the car modestly, eventually. Cheers!
This looks perfect! Thanks for posting. I plan to go with this exact setup, just with a 17" wheel. Seems like 8" wheel with +35 and maybe a 1" drop would be the perfect OEM+ set up.
soilent is offline   Reply With Quote
Old 01-06-2022, 05:00 PM   #226
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Originally Posted by timurrrr View Post
That's news to me! Can you share more details?
(Nervously looking at the RLCAs I already purchased)
I put my SPC RLCA for a pre '22 on my '22 today. Here's what I found.
Firstly, they fit! Now the shock bolt hole is about half a hole or so inboard of the stock arm. The shock ends up sitting a bit more upright. Now I don't know if this was the same on the pre '22 models.
Old 01-06-2022, 05:45 PM   #227
sds
Drives: '22 BRZ Limited 6MT
First I've heard of this--interesting. This would change the wheel rate of any spring...
sds is offline   Reply With Quote
Old 01-06-2022, 07:28 PM   #228
Chris_f
Drives: 2022 GR86
Looks great, thanks for the detailed photos. will be even better with some lowering and and a little bit more negative camber.
Your photos make me think that something like an 18x8 +45 would work well on a car that won’t be lowered, or lowered with OEM camber maintained.
Chris_f is offline   Reply With Quote
Old 01-06-2022, 07:50 PM   #229
dsc_pat
Drives: Too fast
Amazing info. Thanks for sharing.
I am pretty sure the cam bolt should be into the frame side...not at the trailing arm end.
dsc_pat is offline   Reply With Quote
Old 01-06-2022, 08:26 PM   #230
dragoontwo
dragoontwo's Avatar
It might slightly change it, but will it be enough to really make a difference?
The cam bolt is installed correctly.
Old 01-07-2022, 09:17 AM   #231
dsc_pat
Drives: Too fast
You are right, it goes in the slotted hole.
Old 01-07-2022, 10:40 AM   #232
CZ6T
Drives: 2022 crystal white BRZ
Hey guys, bit the bullet and bought some wheels/tires for the cold weather.
Apex Arc-8 17x9 ET42 with Sumitomo HTR A/S P03 in 245/40/17. it's an 8" tread width so narrower than some other tires.
They'll uhhh... *technically* fit and clear the struts on stock suspension. No rubbing full lock turning. I haven't been able to drive enough to see if it will rub under high compression but my gut says it shouldn't.
The first photo is with a 3mm spacer, and the second photo with the tire mounted is no spacer at all. little too much poke with the space for my liking.
Coilovers have been moved to the top of the "next thing to mod" list.
CZ6T is offline   Reply With Quote
Old 01-07-2022, 10:43 AM   #233
beat1
beat1's Avatar
Drives: 2022 BRZ
Did you install ARP extended studs? I got the same wheels and realized yesterday that I was "only" getting 8 full turns when tighting the lug nuts and thats with no spacers.
beat1 is offline   Reply With Quote
Old 01-07-2022, 11:28 AM   #234
CZ6T
No studs, still using the factory ones. I didn't think about counting the turns since I wasn't using a spacer, but I also didn't count the turns with the stock wheel either. I'd be curious to see what it is on a stock wheel with no spacer.
Old 01-07-2022, 02:04 PM   #235
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Any camber?
Old 01-07-2022, 02:07 PM   #236
CZ6T
Any camber?
Only whatever camber is provided by the stock suspension as set by Subaru, which I presume to be little or none.
It would definitely look better with -2.0 degrees to tuck the wheel into the fender a bit more.
Old 01-07-2022, 04:17 PM   #237
jvincent
jvincent's Avatar
Your bottom picture looks very reminiscent of what my first gen looked like with 18x8.5 +48 before I put coilovers on.
Nothing ever rubbed at the track when I ran it so I'm hoping that the same will be true for the new car since I'm planning on keeping the suspension stock.
Old 01-08-2022, 03:12 PM   #238
Strat_FRS
Drives: 2015 FRS for daily and track use
I have the same SPC arms we will try on our 2022 when putting in the coilovers. Did you happen to measure the distance between the subframe attachment point and the shock and knuckle attachments points between the SPC and 2022 arms?
Strat_FRS is offline   Reply With Quote
Rear wheel alignment issues... HELP! Rambo305kid Issues | Warranty | Recalls / TSB 10 07-05-2020 10:05 PM
Wheel Fitment Issues. Need help. hay_frs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 04-06-2020 06:09 PM
Fitment issues Neal86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-07-2019 07:08 PM
Tire/Wheel fitment (rear) rikixass Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-17-2018 04:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
