Old 10-26-2022, 03:08 AM   #225
pope
has a funny hat
Drives: 2014 BRZ Limited
The termites most likely have moved on, it looks like they ate up most of the good stuff -
If only.
Unfortunately, it was an active infestation extending about 4ft to the left, 2.5ft to the right, and 6ft vertically in the studs nearest the door.
So far I’ve replaced the sill plate and rim joist. Rebuilt the landing, replaced the threshold (because I bent the original during removal), and re-laid the laminate flooring on the landing.
Tomorrow, I’ll reframe the wall and hopefully get sheetrock hung to patch the holes where the 60 year old plaster collapsed.
And I’ve had the exterminator out to treat the soil around the perimeter of the house to kill the colony and prevent future termites incursions.
pope is offline   Reply With Quote
The Following 4 Users Say Thank You to pope For This Useful Post:
humfrz (10-26-2022), soundman98 (10-26-2022), Tcoat (10-26-2022), Wally86 (10-26-2022)
Old 11-02-2022, 01:39 AM   #226
pope
has a funny hat
Took longer than anticipated, but finally finished replacing/repairing termite damage and was able to complete the insulation project that revealed the damn termites.
I’ll get the sheetrock up over the coming days, re-trim the door, mud/sand/paint the interior wall, finish removing the obnoxiously odd sized concrete step and replace it with an equally spaced two step entry, and (hopefully) get the garage cleaned up and usable again before winter arrives.
The Following 8 Users Say Thank You to pope For This Useful Post:
Dadhawk (11-02-2022), NoHaveMSG (11-02-2022), Sapphireho (11-04-2022), soundman98 (11-02-2022), Spuds (11-02-2022), Tcoat (11-02-2022), Wally86 (11-02-2022), wolffbite (11-03-2022)
Old 11-04-2022, 10:47 AM   #227
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Well, our well is finally fixed. One year, one engineering report, 4 pressure tanks, one pump, 185 feet of pipe, 10,000 phone calls, one inspection, one water test, and $43,000 later we are up and running.
JD001 (11-06-2022)
Old 11-04-2022, 11:27 AM   #228
It is times like this that I am very glad I live within pipe distance of the Great Lakes!
soundman98 (11-04-2022)
Old 11-04-2022, 11:47 AM   #229
Sapphireho
Famous Potatoes
Sapphireho's Avatar
You still have to pump it to your house.
Old 11-04-2022, 11:54 AM   #230
I don't have to pump anything. It just shows up. I have to pay for it of course but for $43K I could have water for around 50 years.
Old 11-04-2022, 12:00 PM   #231
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Thankfully I split that cost with 22 other homes.
soundman98 (11-04-2022), Tcoat (11-04-2022)
Old 11-04-2022, 12:08 PM   #232
I split the cost with about 200,000 other homes!
Old 11-04-2022, 12:29 PM   #233
Sapphireho
Famous Potatoes
Sapphireho's Avatar
In SJ I split it with about 1.5 million other homes, and it still cost me $250 a month.
Old 11-04-2022, 06:17 PM   #234
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Sometimes you just have to pay for it to be pumped into a water tower. Then gravity gets it to your house.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread"
Old 11-06-2022, 02:33 PM   #235
cjd
cjd's Avatar
Drives: 2017 BRZ
Started a leaky toilet repair. I think this just turned into a floor repair Screws which should be securing the flange are just spinning, and some were in the wrong place - turns out when it was installed they broke some (thin drywall screws used) so just shot a screw next to the right place (but not countersunk...) I think plumbers putty was used along side a wax ring, too... not at all confidence inspiring.
Floor repair means I get to learn how to do tile work. How much tile work depends on if I break tiles trying to pull them (probably) and/or can find similar replacements.
Or it might just be time to pay someone to do all the work.
I'm now worried the other toilets are just as horribly installed. None of those have turned into drywall work like this one. Yet.
Old 11-06-2022, 04:12 PM   #236
JD001
JD001's Avatar
Drives: Subaru BRZ
What's the payback period?
Old 11-06-2022, 04:21 PM   #237
Sapphireho
Famous Potatoes
Sapphireho's Avatar
We don't make money with the wells. All 23 homes own our little water district. Now both our wells are in good shape.
JD001 (11-07-2022), soundman98 (11-06-2022)
Old 11-07-2022, 12:22 AM   #238
dpfarr
Drives: BRZ ts
Does anyone have a good garage work bench/table? Feel free to show it off. I’ve been looking for used and new work surface and shelving.
dpfarr is offline   Reply With Quote
diy, home, living
Brought my BRZ home today Smokinbuffalo Northwest 8 06-01-2012 12:49 AM
WRB-Got it home!!! jaytaurus BRZ First-Gen (2012+) — General Topics 28 05-29-2012 12:33 PM
#64 brought home today. FujiwaraTofuShop Scion FR-S / Toyota 86 GT86 General Forum 8 05-24-2012 10:04 AM
