#225 | |
has a funny hat
Drives: 2014 BRZ Limited
Unfortunately, it was an active infestation extending about 4ft to the left, 2.5ft to the right, and 6ft vertically in the studs nearest the door. So far I’ve replaced the sill plate and rim joist. Rebuilt the landing, replaced the threshold (because I bent the original during removal), and re-laid the laminate flooring on the landing. Tomorrow, I’ll reframe the wall and hopefully get sheetrock hung to patch the holes where the 60 year old plaster collapsed. And I’ve had the exterminator out to treat the soil around the perimeter of the house to kill the colony and prevent future termites incursions. |
| The Following 4 Users Say Thank You to pope For This Useful Post: |
#226 |
has a funny hat
Took longer than anticipated, but finally finished replacing/repairing termite damage and was able to complete the insulation project that revealed the damn termites.
I’ll get the sheetrock up over the coming days, re-trim the door, mud/sand/paint the interior wall, finish removing the obnoxiously odd sized concrete step and replace it with an equally spaced two step entry, and (hopefully) get the garage cleaned up and usable again before winter arrives. |
| The Following 8 Users Say Thank You to pope For This Useful Post: | Dadhawk (11-02-2022), NoHaveMSG (11-02-2022), Sapphireho (11-04-2022), soundman98 (11-02-2022), Spuds (11-02-2022), Tcoat (11-02-2022), Wally86 (11-02-2022), wolffbite (11-03-2022) |
#227 |
Famous Potatoes
Drives: '15 ultramarine
Well, our well is finally fixed. One year, one engineering report, 4 pressure tanks, one pump, 185 feet of pipe, 10,000 phone calls, one inspection, one water test, and $43,000 later we are up and running.
| The Following User Says Thank You to Sapphireho For This Useful Post: | JD001 (11-06-2022) |
#228 |
It is times like this that I am very glad I live within pipe distance of the Great Lakes!
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (11-04-2022) |
#229 |
Famous Potatoes
#230 |
I don't have to pump anything. It just shows up. I have to pay for it of course but for $43K I could have water for around 50 years.
#231 |
Famous Potatoes
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | soundman98 (11-04-2022), Tcoat (11-04-2022) |
#232 |
I split the cost with about 200,000 other homes!
#233 |
Famous Potatoes
#234 |
The Dictater
Drives: '13 Red Scion FRS
Sometimes you just have to pay for it to be pumped into a water tower. Then gravity gets it to your house.
Also: "Build Thread" |
#235 |
Drives: 2017 BRZ
Started a leaky toilet repair. I think this just turned into a floor repair
Screws which should be securing the flange are just spinning, and some were in the wrong place - turns out when it was installed they broke some (thin drywall screws used) so just shot a screw next to the right place (but not countersunk...) I think plumbers putty was used along side a wax ring, too... not at all confidence inspiring.Floor repair means I get to learn how to do tile work. How much tile work depends on if I break tiles trying to pull them (probably) and/or can find similar replacements. Or it might just be time to pay someone to do all the work. I'm now worried the other toilets are just as horribly installed. None of those have turned into drywall work like this one. Yet.
#236 |
Drives: Subaru BRZ
#237 |
Famous Potatoes
| The Following 2 Users Say Thank You to Sapphireho For This Useful Post: | JD001 (11-07-2022), soundman98 (11-06-2022) |
#238 |
Drives: BRZ ts
Does anyone have a good garage work bench/table? Feel free to show it off. I’ve been looking for used and new work surface and shelving.
| Tags |
| diy, home, living |
| Brought my BRZ home today | Smokinbuffalo | Northwest | 8 | 05-31-2012 11:49 PM |
| WRB-Got it home!!! | jaytaurus | BRZ First-Gen (2012+) — General Topics | 28 | 05-29-2012 11:33 AM |
| #64 brought home today. | FujiwaraTofuShop | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 09:04 AM |
| Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
