Old 05-04-2011, 06:27 PM   #225
Giccin
Giccin's Avatar
Originally Posted by Ryephile View Post
This thread has devolved into us finding out that fatoni doesn't know much about suspension or aero because he tracks a kart, which has neither.
Back on topic?
Yes, they're both 2 door FR coupes, but with a big price delta, different powertrain style, and likely a 2+2 vs. 2-seater configuration, are these cars comparable in the real world? To the uneducated buyer, I say yes. To the informed enthusiast, I say no.
Wow. The size is actually pretty close to that 350(?)z. o_O
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 05-04-2011, 06:30 PM   #226
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
But should hopefully be close to 900lbs lighter.
tranzformer is offline   Reply With Quote
Old 05-04-2011, 06:39 PM   #227
Dragonitti
Amen to that.
Old 05-04-2011, 06:39 PM   #228
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
Originally Posted by old greg View Post
...the distance from the lower control arm pivot to the center of force of the contact patch does affect wheel rate. ...
You are honestly factoring the bending of the hubs into your wheel rate calculations?
If you put the wheel on the end of a 10 foot pole extending out from the hub, you will still have the exact same total stroke, thus the same wheel rate, as if the wheel was tucked in. Yes, the pole will bend, but that's because a 10 foot pole is going to bend.
You can see the car will be a few inches shorter pretty much the entire length of the profile. Factor in a lighter engine, not huge wheels & brakes, and take out Nissan's affinity for BMW-esque bulk and 2700 pounds sounds reasonable.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 05-04-2011, 06:47 PM   #229
Giccin
Giccin's Avatar
Definitely.
Could shead a few pounds too~ I'd take out the factory seats and throw in some racing seats~~
I'm still pretty curious to know what those wheel sizes are going to be. I also hope that the tiny window in the back isn't going to be a problem when checking for blind spots. I have that issue with my Yaris.
Btw, anyone else planning to change to a short shifter and shorter clutch-engager thing? lol I'm still learning. :P
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Old 05-04-2011, 07:11 PM   #230
Dragonitti
Sticking with the stock shifter. If they make shifter bushings then I will chage those, but sticking with the stock shifter.
Old 05-04-2011, 08:40 PM   #231
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
A short shifter might be one of my first mods if some reputable make a nice one. Especially if the stock piece is in any way lacking.
Avoiding sloppy shifts preserves the trans.
chulooz is offline   Reply With Quote
Old 05-04-2011, 09:04 PM   #232
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
900? More like any ballpark range of 400-600, or 2600-2800 FR-S curb weight. Honestly if they got this car under 2600lbs I'd....I'd...well, I'd be ecstatic beyond belief.
OldSkoolToys is offline   Reply With Quote
Old 05-04-2011, 09:14 PM   #233
OldSkoolToys
Is a Monster
Drives: AE86, MA70
edit edit: Damn technicalities. In any case, the Z IS a Grand Tourer, so the weight should be implied to be a bit on the heavy side. Honestly, 3200lbs is a pretty good figure for a car in that category.
Since the FR-S is not a GT car (at least, I hope Scion doesn't try to spin the car that direction...I suppose they could), it should be much lighter.
Editx3: I practically just sealed the thread in that statement. For so long, for some reason, that fact had escaped my mind. But people are comparing a GT class sports car to just a basic sports coupe. The very fact that the 370z is a GT car would imply that certain luxuries and gizmo's should be standard and expected, not to mention a fat robust engine.
Old 05-04-2011, 09:33 PM   #234
tranzformer
Drives: Zoom Zoom
Sorry. I read a bad link on wiki stating the 350 weighed 3600lbs. My bad.
Old 05-04-2011, 10:45 PM   #235
Ryephile
Hot Dog
Ryephile's Avatar
I'm with OldSkoolToys in hoping Toyota/Scion keep the car minimal and don't go over-insulated with a GT philosophy. Hopefully we'll be pleased since Toyota keeps yammering on every press conference about a light weight philosophy.
Old 05-05-2011, 08:37 AM   #236
old greg
Rocket Surgeon
Drives: PSM GGA OMG
That isn't it at all. Picture an SLA suspension with unequal length/non-parallel arms. Sum the forces about the lower ball joint and you will see that the reaction force from the upper control arm has an upward component. Lower offset will cause higher reaction forces in the lower and upper control arm, and by extension increase the upward component of force acting on the upright.
The tire is pushed upward by normal force, and the upright is pushed upward by the upper control arm. Both of these forces must be reacted by the lower control arm and/or spring/damper.
As I said before, though less clearly perhaps, this upward force from the upper control arm isn't likely to be significant, but it does exist. There's something similar going on with MacPherson struts as well, though I can't really explain it only express it mathematically.
old greg is offline   Reply With Quote
Old 05-05-2011, 09:53 AM   #237
Dragonitti
Meh...don't make any difference anyway cause I want be running some crazy low offset.
Old 05-05-2011, 11:00 AM   #238
Ryephile
Hot Dog
Ryephile's Avatar
We'll have to agree to disagree until you provide proof. The primary reactive force from the upper control arm is laterally outward, not upward. This is why upper control arms can be so delicate; their main stressor is compression. You're describing a bending force, which is very much in the noise.
fanboi, lame
Nissan 370Z thread S2KtoFT86 Other Vehicles & General Automotive Discussions 116 04-07-2017 11:40 PM
FT 86 & 370Z similarities blur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 10-05-2010 01:39 AM
