Old 02-11-2015, 02:21 AM   #2325
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
Quick question, when I try to edit the 2.0 files with the 2.0 XML files I get two checksum errors rather than 1. Is it still OK to edit and flash? Also what are people using for the delta values for FFS?
l0aded is offline   Reply With Quote
Old 02-11-2015, 09:37 AM   #2326
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by Celadrielas View Post
But there is one thing confirmed... Stock box is restrictive so replacing it is a must for the extraction of the most power.
I have to disagree with this statement based upon 3 years of testing with 5 different aftermarket intakes, excluding Grimmspeed.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-11-2015, 10:31 AM   #2327
Koa
Originally Posted by tracerit View Post
I'm close to getting an uel header for the primary purpose of getting rid of the 4k vvt noise, would it be safe to load the uel e85 tune whole I'm still on stock header and e85 for about 2 minutes and Rev past 4k to see if the noise is gone or minimized at least. Then I'll flash back to the correct tune for my setup.
I've read reports of the uel tune getting rid of the sound but I just want to make sure before I drop $800 for a header.
little picky aren't ya
First off, don't load the UEL E85 tune on your stock EL header. Use the E85 EL OTS tune.
The stage 2 OTS map doesn't need such aggressive VVT crossover, thus yes, the sound will be dimished or gone completely.
Old 02-11-2015, 10:35 AM   #2328
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
I respect the disagreement. I, sadly, don't have anything to "back" my statement with shy of what I've consistently read on this forum, but I would absolutely love to hear your findings, if you'd be willing to share.
I'm all for correcting my information
Old 02-11-2015, 12:17 PM   #2329
tonystewart
Celadrielas,
Perrin CAI, FA20club CAI, Airaid, Injen CAI, Greddy, fail when it comes to MAF placement/priority (in my opinion/experience). They seemed to forget what the factory and Grimmspeed understand, the MAF housing and the air straightener are extremely important.
I've bought and sold alot of intakes. Save your money for a Grimmspeed or improve the factory airbox , like I did for my daughters car.
All specs are in signature
Old 02-11-2015, 12:46 PM   #2330
wootwoot
Drives: FRS
Celadrielas,
Don't forget about the skunk2 intake. It has good MAF placement and air straighteners as well.
wootwoot is offline   Reply With Quote
Old 02-11-2015, 01:48 PM   #2331
RFB
RFB's Avatar
Drives: FRS
I tend to agree with independent tests.
An intakes primary function is to supply CLEAN air to the motor.
Since the air cleaner is for cleaning air, a larger surface area reusable filter means less dirt, less cleaning, as long as it does not restrict more than stock.
I got the original TRD for that reason, not that the team reported extra ponies because of the intake (wouldn't the ribs in the intake hose cause turbulence, slow down volume ? or not).
RFB is offline   Reply With Quote
Old 02-11-2015, 02:09 PM   #2332
tracerit
Drives: '13 SSM BRZ Limited 6MT
I'd rather have the torque dip then this noise tbh. It's annoying to have a 4k rev limit reminder always on :/ But hopefully I won't have to deal with it too long, just decided to get an UEL header. Now time to see if any OFH are in stock.
tracerit is offline   Reply With Quote
Old 02-11-2015, 02:38 PM   #2333
tonystewart
Skunk2 Intake, I haven't had the opportunity
Old 02-11-2015, 02:40 PM   #2334
Koa
I love my OFH.. highly recommend.
If you're pretty impartial though, try picking up a reputable header in the members classifieds. got my never installed OFH for $400 free shipping.. couldn't beat that
Old 02-11-2015, 03:55 PM   #2335
qoncept
qoncept's Avatar
Wow, that's is exactly the opposite conclusion I came to. The GS intake, based on THEIR claims, adds a statistically insignificant amount of power. You can (and anyone with "dyno tested" 5hp gains certainly do) play with the smoothing levels on the dyno and gain more than 5hp.
In any case, aftermarket intakes give you almost no bang for your buck.
qoncept is offline   Reply With Quote
Old 02-11-2015, 04:07 PM   #2336
steve99
not all oft roms are checksum corrected. so you will get checksum errors from romraider
check the tables look ok
oft will correct the checksum anyway.
Old 02-11-2015, 04:43 PM   #2337
Koa
doesn't smoothing dyno plots defeat the purpose?
Who smooths dyno plots?
Old 02-11-2015, 05:20 PM   #2338
qoncept
qoncept's Avatar
I'm no expert but a raw dyno plot is pretty rough. This one has about a 10hp swing between ~5900 and 5950rpm.
http://smg.photobucket.com/user/DLSJ...s_EVO.jpg.html
I assume the way it works is the dyno gets instantaneous load readings, and it's not terribly precise. If you ran that same car on the same dyno you could absolutely see those points shift enough that you see a 10hp loss or gain at any given rpm. Smoothing tries to compensate for that while adding its own error.
Everyone. Particularly if they're going to show it to anyone else (customers or potential customers).
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
