#2283 | |
Drives: 2013 Firestorm FR-S
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
#2284 |
Drives: '22 BRZ
That seems to be "normal" as it's REALLY easy to forget that, lol.
| The Following User Says Thank You to DocWalt For This Useful Post: | Shark_Bait88 (04-18-2016) |
#2285 | |
Drives: 2017 BRZ
| The Following 2 Users Say Thank You to cjd For This Useful Post: | DocWalt (04-18-2016), Shark_Bait88 (04-18-2016) |
#2286 |
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | cjd (04-18-2016) |
#2287 |
Drives: 13 BRZ WRB
#2288 | |
Doesn't mean I won't come play around when there's a weekend without conflicting events though. My friend who placed 1st at the Chicago region event might offer some decent competition though.
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | 2superblus (04-20-2016) |
#2289 |
Drives: 2017 BRZ
| The Following 2 Users Say Thank You to cjd For This Useful Post: | 2superblus (04-20-2016), GeorgeJFrick (04-21-2016) |
#2290 |
btr.life
Drives: 2022 GR86
What have people done for lightweight seats/mounts, etc to get to the 25# weight limit for STX?
I just put together my Sparco EVO seat with Sparco base/slider/side mounts and the damn thing weighs 37.4# all together, about a ~5# savings over stock, argh. It worked out good in my e36, with Sparco Sprint V seats and base/sliders. I didn't need side mounts though and those seats weighed in at 27# total. The passenger seat which was mounted directly to the base was right at 25#.
#2291 |
Get rid of the sliders? Those typically add a lot of weight. Very few people use race seats in STX in these cars, even at the pointy end, since the stock ones are fairly light and way more comfortable.
#2292 | |
Drives: 2017 BRZ
#2293 | |
btr.life
Drives: 2022 GR86
Yea this experience has me thinking about putting the stock seat back in. Mostly because of what xwd mentioned above (stock seats being already fairly lightweight) and I have a Schroth harness which keeps me in secure enough that the race seat doesn't really make much difference there.
#2294 |
btr.life
Drives: 2022 GR86
For others reference, I took my seat out to make adjustments tonight and weighed the mount kit by itself (Sparco base/slider/side mounts). All together those parts weighed in at 19.2lbs.
#2295 |
Drives: '22 BRZ
I figured I'd post here with the the update. The throttle closing is apparently "normal" in lower gears, it seems like the soft limiter in OFT tunes isn't enough to fully control revs so the ECU starts closing the throttle instead of just turning off fuel or retarding ignition timing. Doesn't seem to be an issue in 3rd gear, and doesn't happen all the time in 2nd. 1st gear it starts closing the throttle within ~0.25 seconds because the revs start climbing a little beyond what it thinks is acceptable. I guess I'll make the soft limiter a little harder to prevent it from closing the throttle.
On another note, car setup wise. I picked up a Whiteline 20mm front bar. It became apparent that I need less oversteer as I've been pushing the car much harder as my comfort level has gone up. Install should happen this weekend, then I should be doing a couple of events in the next couple of weeks so I can see how it behaves. I'm expecting it to be even better in slaloms and I'll be able to use the throttle more aggressively mid-corner. edit: I want to clarify, this isn't an OFT issue, just that the OTS tune has a limiter that's a little bit too soft for the abuse of autocross. It's easy to change it and reflash.
| The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
#2296 | |
Drives: 2017 BRZ
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 03:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 07:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 02:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 12:02 PM |
