Old 04-18-2016, 02:15 PM   #2283
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by DocWalt View Post
We got 5 runs yesterday with 146 drivers. Could easily have had 6, we were on track to finish by 2:30 until a timing system issue in the last heat and a bunch of newbs working course at the same time delayed things. I was riding with someone and we got to a section of course with cones everywhere except for where they belonged... Same issue for the car in front of us, and they stopped to get a re-run too.
Yeah, we had a few instances where cars had to be held at the start line to reset the timing because a corner worker ran in front of the finish boxes.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 04-18-2016, 02:29 PM   #2284
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
That seems to be "normal" as it's REALLY easy to forget that, lol.
The Following User Says Thank You to DocWalt For This Useful Post:
Shark_Bait88 (04-18-2016)
Old 04-18-2016, 03:53 PM   #2285
cjd
cjd's Avatar
Drives: 2017 BRZ
Just got an email from RCE. They'll be able to send me a new set of camber plates in about 3-4 days. I want to try to sort out the spring perch situation too before installing them though.
I'm definitely looking forward to this season. I think you and I should have a pretty good time battling back and forth, and hopefully Jeremy and Jim start hitting more cones. lol
Sorry, I plan to leave you in the dust
The Following 2 Users Say Thank You to cjd For This Useful Post:
DocWalt (04-18-2016), Shark_Bait88 (04-18-2016)
Old 04-18-2016, 04:38 PM   #2286
Shark_Bait88
We'll see about that!
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
cjd (04-18-2016)
Old 04-19-2016, 05:25 PM   #2287
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
It will be fun when all of the IL STX drivers come up to play in Milwaukee.
2superblus is offline   Reply With Quote
Old 04-19-2016, 05:35 PM   #2288
Shark_Bait88
Oh, I know that I've got no shot up there. You guys are too fast. haha
Doesn't mean I won't come play around when there's a weekend without conflicting events though.
My friend who placed 1st at the Chicago region event might offer some decent competition though.
2superblus (04-20-2016)
Old 04-19-2016, 06:49 PM   #2289
cjd
cjd's Avatar
Drives: 2017 BRZ
I'll be there again all season, except for the opener which conflicted with Chicago
2superblus (04-20-2016), GeorgeJFrick (04-21-2016)
Old 04-20-2016, 01:28 PM   #2290
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
What have people done for lightweight seats/mounts, etc to get to the 25# weight limit for STX?
I just put together my Sparco EVO seat with Sparco base/slider/side mounts and the damn thing weighs 37.4# all together, about a ~5# savings over stock, argh.
It worked out good in my e36, with Sparco Sprint V seats and base/sliders. I didn't need side mounts though and those seats weighed in at 27# total. The passenger seat which was mounted directly to the base was right at 25#.
justinco is offline   Reply With Quote
Old 04-20-2016, 02:42 PM   #2291
xwd
Get rid of the sliders? Those typically add a lot of weight. Very few people use race seats in STX in these cars, even at the pointy end, since the stock ones are fairly light and way more comfortable.
Old 04-20-2016, 02:43 PM   #2292
cjd
cjd's Avatar
Drives: 2017 BRZ
I still drive to events. I'm not removing safety equipment, so stock seats are staying in my car.
Old 04-20-2016, 07:19 PM   #2293
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
I'd say the sliders are the lightest of the bits, the base weighs a "ton" and the side mounts are heavy too. Supposedly the Buddy Club mount/slider kit is much lighter.
Yea this experience has me thinking about putting the stock seat back in. Mostly because of what xwd mentioned above (stock seats being already fairly lightweight) and I have a Schroth harness which keeps me in secure enough that the race seat doesn't really make much difference there.
Old 04-21-2016, 12:15 AM   #2294
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
For others reference, I took my seat out to make adjustments tonight and weighed the mount kit by itself (Sparco base/slider/side mounts). All together those parts weighed in at 19.2lbs.
Old 04-21-2016, 01:49 PM   #2295
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I figured I'd post here with the the update. The throttle closing is apparently "normal" in lower gears, it seems like the soft limiter in OFT tunes isn't enough to fully control revs so the ECU starts closing the throttle instead of just turning off fuel or retarding ignition timing. Doesn't seem to be an issue in 3rd gear, and doesn't happen all the time in 2nd. 1st gear it starts closing the throttle within ~0.25 seconds because the revs start climbing a little beyond what it thinks is acceptable. I guess I'll make the soft limiter a little harder to prevent it from closing the throttle.
On another note, car setup wise. I picked up a Whiteline 20mm front bar. It became apparent that I need less oversteer as I've been pushing the car much harder as my comfort level has gone up. Install should happen this weekend, then I should be doing a couple of events in the next couple of weeks so I can see how it behaves. I'm expecting it to be even better in slaloms and I'll be able to use the throttle more aggressively mid-corner.
edit: I want to clarify, this isn't an OFT issue, just that the OTS tune has a limiter that's a little bit too soft for the abuse of autocross. It's easy to change it and reflash.
The Following 3 Users Say Thank You to DocWalt For This Useful Post:
cjd (04-21-2016), GeorgeJFrick (04-21-2016), smg1138 (04-21-2016)
Old 04-21-2016, 04:50 PM   #2296
cjd
cjd's Avatar
Drives: 2017 BRZ
I'm curious about this. I wonder if I need understeer now, but will later need to dial it out again; matching the car to current capability seems smart when I think about it that way, and for some reason I hadn't before.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
