04-10-2016, 08:40 PM | #2227 |
Drives: '22 BRZ
It has a soft limit. Wasn't an issue two weeks ago at the other two events I've done.
04-10-2016, 08:48 PM | #2228 | |
Drives: 2017 BRZ
One other possibility - how are you disabling traction control? I've had that trigger a response like this. |
04-10-2016, 08:50 PM | #2229 | ||
Drives: 1993 Impreza w/ WRX Swap + FWD!
The Following User Says Thank You to Kostamojen For This Useful Post: | nisti (04-11-2016) |
04-10-2016, 09:10 PM | #2230 | |
Drives: '22 BRZ
That run was pedal dance, IIRC. Last event was just 5 second TCS press. ~1/4 tank.
04-10-2016, 10:08 PM | #2231 |
04-10-2016, 10:14 PM | #2232 | |
Drives: '22 BRZ
I posted on facebook and everyone there had the same opinion, too low on gas Oh well. Why do you think the pedal dance could cause it?
04-10-2016, 10:21 PM | #2233 | |
Pedal dance causes my car to be all funky... I have no idea why it would cause it but maybe it might lol |
The Following User Says Thank You to Kostamojen For This Useful Post: | DocWalt (04-10-2016) |
04-11-2016, 08:59 AM | #2234 |
Drives: '22 BRZ
On another note, the Ohlins are still great, lol. I ended up at 5 clicks front, 6 rear. I dropped tire pressures throughout the day and I like 32 psi front, 28 psi rear.
The tire pressures made a HUGE change in car behavior. It feels fantastic at the limit now, very neutral. Going a click stiffer in the rear loosened the car a little on exit which was much appreciated coming from a hot FWD car, haha. It was a little bit more prone to entry oversteer in a couple of places and if I was too aggressive on the throttle mid-corner it would step out. I'm still debating if I want to do a front bar or not. The car feels so great that I want to just drive it and work on the driver mod.
04-11-2016, 10:39 AM | #2235 |
I've never had the car fuel starve in autocross even with the light on.
I don't use the pedal dance at all, I've only found it to increase the chance of the ABS freaking out. |
04-11-2016, 10:58 AM | #2236 |
Nah, stock will bounce off the revlimiter like it's stupid all day long.
04-11-2016, 11:08 AM | #2237 | |
Drives: '22 BRZ
Had no issues with the pedal dance on the brakes this event, but I did at NNJR. Tried it one run and it pretty much halved my braking power because it was freaking out. I figured it would be worse yesterday because it's a LOT bumpier, but it behaved the same with or without pedal dance.
04-11-2016, 11:58 AM | #2238 |
Drives: Firestorm FR-S
Hi Everyone! I competed for the first time in STX yesterday. While I had a ton of fun, I'm not really happy with the results. My best/clean run was 79.442, while first place got 69.XXX. Just about a 10 second difference.
What else can i do to my car to make myself more competitive? What I have done: Running on all seasons, this will be the first thing I will change Full exhaust: OFT Header, Nameless over/front pipe combo with high flow cat, Q300 OFT with stage 2 tune, have not modified the tune. just what comes from Shiv Eibach Pro springs on stock shocks What are some other things I can do? RS3's? Pulleys? Drive shaft? would it make sense to get new shocks or save up for coils? Also here is the video of my run, Any criticism/advice is greatly appreciated!! |
04-11-2016, 12:21 PM | #2239 |
Drives: Many
The Following 2 Users Say Thank You to e1_griego For This Useful Post: | Silver Ignition (04-12-2016), Tbor (04-11-2016) |
04-11-2016, 12:21 PM | #2240 |
Drives: '22 BRZ
-Proper summer tires will gain a LOT of time when you learn to drive with the new grip. I'd say to not waste time on the RS3s, but realistically there's a lot to learn going from all seasons to full on FAST tires like the RE-71Rs.
-Upgraded driveshaft isn't allowed in STX, I don't remember if pulleys are allowed. -I'd save for coilovers, but your current suspension will still let you have a lot of fun. -You're not likely massively down on power, so don't worry about chasing that for now. I can't watch the video here, but it's likely tires and driver mod that will gain you the most time. Supposedly SJR has some good drivers, but I've yet to make it down there myself to really see how they compare to the guys I'm used to. I plan to at least once this year Do you plan on making any Philly region or BMC events this summer?
The Following User Says Thank You to DocWalt For This Useful Post: | Tbor (04-13-2016) |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
