Old 04-10-2016, 08:40 PM   #2227
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Originally Posted by cjd View Post
That seems to be closer to the stock behavior (at least, that's my memory of how stock worked.) You sure the tune you're running has a soft limit?
It has a soft limit. Wasn't an issue two weeks ago at the other two events I've done.
Old 04-10-2016, 08:48 PM   #2228
cjd
cjd's Avatar
Drives: 2017 BRZ
Someone pranking you by loading a stock tune? Do you happen to have logs? My next best guess is that something else prompted a sudden timing pull from knock or ... well, who knows. I've never encountered something like that on an OFT tune, and I've had a couple events where I had to sit on it for a bit.
One other possibility - how are you disabling traction control? I've had that trigger a response like this.
Old 04-10-2016, 08:50 PM   #2229
Kostamojen
Originally Posted by nisti View Post
Question for those using the SPC front camber bolts.
I naively(?) installed the front SPC bolts precisely according to their instructions.
According to the instructions, the SPC bolts go in the lower hole.
After install, camber appeared to not change at all.
So since then, I have referred to the internet, and am now reading that many either:
1. Install the SPC bolt in the top hole.
2. Install the SPC bolt in the bottom hole, then swap the oem lower bolt to the top hole.
What has everyone else done?
Pretty sure I can't achieve -1.75 front camber according to SPC's instructions.
I think you will need both crash bolts up top plus the SPC bolts in the bottom to get -1.75.
So, wtf is going on with my car? The ECU is just cutting throttle when I hit the limiter sometimes, like at 0:36. I was foot flat to the floor and it was just coasting along. It did it again immediately before the finish, as well as other short sequences during the run.
Just curious, how much fuel was in the tank?
The Following User Says Thank You to Kostamojen For This Useful Post:
nisti (04-11-2016)
Old 04-10-2016, 09:10 PM   #2230
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I was essentially only logging the bare minimum for Track Addict as I was having some bizarre issues with it today. I've been on the limiter plenty before, this was the first time it behaved like this. I guess it didn't like the bumps.
That run was pedal dance, IIRC. Last event was just 5 second TCS press.
~1/4 tank.
Old 04-10-2016, 10:08 PM   #2231
Kostamojen
~1/4 tank.
There have been minor fuel starvation issues with this car. Not as bad as like with my old Impreza where I had to keep over 1/2" a tank for autox, but that might be a possibility.
The pedal dance could be why as well.
Old 04-10-2016, 10:14 PM   #2232
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Odd. I didn't have issues on track even with the fuel light on for ~6-10 laps.
I posted on facebook and everyone there had the same opinion, too low on gas Oh well.
Why do you think the pedal dance could cause it?
Old 04-10-2016, 10:21 PM   #2233
Kostamojen
Track is a lot different than autox when it comes to the fuel tank.
Pedal dance causes my car to be all funky... I have no idea why it would cause it but maybe it might lol
DocWalt (04-10-2016)
Old 04-11-2016, 08:59 AM   #2234
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
On another note, the Ohlins are still great, lol. I ended up at 5 clicks front, 6 rear. I dropped tire pressures throughout the day and I like 32 psi front, 28 psi rear.
The tire pressures made a HUGE change in car behavior. It feels fantastic at the limit now, very neutral. Going a click stiffer in the rear loosened the car a little on exit which was much appreciated coming from a hot FWD car, haha. It was a little bit more prone to entry oversteer in a couple of places and if I was too aggressive on the throttle mid-corner it would step out.
I'm still debating if I want to do a front bar or not. The car feels so great that I want to just drive it and work on the driver mod.
Old 04-11-2016, 10:39 AM   #2235
xwd
I've never had the car fuel starve in autocross even with the light on.
I don't use the pedal dance at all, I've only found it to increase the chance of the ABS freaking out.
Old 04-11-2016, 10:58 AM   #2236
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Nah, stock will bounce off the revlimiter like it's stupid all day long.
ineedyourdiddly
Old 04-11-2016, 11:08 AM   #2237
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Yeah, I'd heard that about the fuel light too which is why I wasn't concerned about it being a fuel issue.
Had no issues with the pedal dance on the brakes this event, but I did at NNJR. Tried it one run and it pretty much halved my braking power because it was freaking out. I figured it would be worse yesterday because it's a LOT bumpier, but it behaved the same with or without pedal dance.
Old 04-11-2016, 11:58 AM   #2238
Tbor
Drives: Firestorm FR-S
Hi Everyone! I competed for the first time in STX yesterday. While I had a ton of fun, I'm not really happy with the results. My best/clean run was 79.442, while first place got 69.XXX. Just about a 10 second difference.
What else can i do to my car to make myself more competitive?
What I have done:
Running on all seasons, this will be the first thing I will change
Full exhaust: OFT Header, Nameless over/front pipe combo with high flow cat, Q300
OFT with stage 2 tune, have not modified the tune. just what comes from Shiv
Eibach Pro springs on stock shocks
What are some other things I can do?
RS3's? Pulleys? Drive shaft? would it make sense to get new shocks or save up for coils?
Also here is the video of my run, Any criticism/advice is greatly appreciated!!
Tbor is offline   Reply With Quote
Old 04-11-2016, 12:21 PM   #2239
e1_griego
e1_griego's Avatar
Drives: Many
Seat time. Seat time. Seat time.
Also don't underhand the wheel.
e1_griego is offline   Reply With Quote
The Following 2 Users Say Thank You to e1_griego For This Useful Post:
Silver Ignition (04-12-2016), Tbor (04-11-2016)
Old 04-11-2016, 12:21 PM   #2240
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
-Proper summer tires will gain a LOT of time when you learn to drive with the new grip. I'd say to not waste time on the RS3s, but realistically there's a lot to learn going from all seasons to full on FAST tires like the RE-71Rs.
-Upgraded driveshaft isn't allowed in STX, I don't remember if pulleys are allowed.
-I'd save for coilovers, but your current suspension will still let you have a lot of fun.
-You're not likely massively down on power, so don't worry about chasing that for now.
I can't watch the video here, but it's likely tires and driver mod that will gain you the most time.
Supposedly SJR has some good drivers, but I've yet to make it down there myself to really see how they compare to the guys I'm used to. I plan to at least once this year Do you plan on making any Philly region or BMC events this summer?
The Following User Says Thank You to DocWalt For This Useful Post:
Tbor (04-13-2016)
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 02:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 06:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 01:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 11:02 AM
