Old 07-24-2015, 06:37 PM   #211
mid_life_crisis
Drives: FR-S 10 #103 AT
Lift off throttle afr is 20. Is that normal?
Old 07-24-2015, 09:05 PM   #212
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Yes
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 07-24-2015, 10:13 PM   #213
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Originally Posted by xsnapshot View Post
Wayno, can you comment on this? If someone is hitting a load above 1.2 in the RPM range you modified, then they ARE running more timing.
You said not to adjust timing without a dyno. Did you dyno to verify this increase in timing resulted in a corresponding increase in torque.
I'm not sure why you would've said you did not increase timing at WOT when you did (from what I can see on the UEL E85 tune)
Thanks
It's not exactly more timing, it's just smoothed to have the same curve as the 1.2 g/rev load column. You'll only be in those cells under certain conditions on AT, and never on most MT's - which is what the tune was created on.
http://datazap.me/u/shivvishnu/stage...9-958&mark=861
0.35 timing removed at 4400 in v80.
Old 07-25-2015, 05:49 PM   #214
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
OFT noob here, so I just copy your 98 Ron maps to my OFT stage 1 91 tune? I didn't see a 91 map in the files haha
jaorocks1 is offline   Reply With Quote
Old 07-25-2015, 05:58 PM   #215
ATaraxias
Drives: 1994 Geo Metro Hatchback
Hi Wayno,
I was running your Stg2 E85 v67A B01D rom and am trying to upgrade to the newest version of your tune to correct some knock I observed leading to IAM reduction to .76/.88 on occasion. Also, P291A CEL on occasion. (Bank1 AFR inbalance? GS intake causing this, turned it off in RR?)
Openflash manager is saying that the v80 version is not compliant. I copied changed tables in the change log in romraider to make it into a B01D version. Right?
Thank you!
ATaraxias is offline   Reply With Quote
Old 07-25-2015, 06:27 PM   #216
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
What CAL ID are you? I just did a B01D rom and can post it
Old 07-26-2015, 04:42 AM   #217
Wayno
Wayno's Avatar
Originally Posted by ATaraxias View Post
Hi Wayno,
Thank you!
If you get IAM drop on E85, you have a serious hardware problem or different hardware (example: intake spacers) that you need to customize the tune for. You'll knock as much on a later version. You shouldn't drop IAM on E85, period.
Old 07-26-2015, 05:23 AM   #218
steve99
Hi Wayno,
Thank you!
+1 on on what @Wayno said.
Dont ever turn off cel codes when you dont know what the issue is. Those codes are their to warn you of serious problems
You likely have an intake leak or an exhaust leak , 02 sensor or maf problem etc
have a look at your long term fuel trims and your "commanded afr" against AFR (measured by 02 sensor)
That code means their is a large imbalance between what the AFR the ECU is asking for and what the 02 sensor reading is.
If your getting knock as well its likely running way lean.
as wayno said it likely a hardware issue highly unlikely to be tune related unless you missed/altered some tables like Port injector scaling or Direct Injector fuel pressure target tables or your running a petrol tune on E85
Old 07-26-2015, 10:59 AM   #219
jaorocks1
jaorocks1's Avatar
Drives: 92 Prelude
D00C bruthaaa
Old 07-26-2015, 12:13 PM   #220
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
D00C bruthaaa
Sorry I can't help you out without spent about an hour double and triple checking my copy and paste skills lol. There should be a decent link in another thread on how to copy tables between tunes in RomRaider. It's just tedious AF
Old 07-27-2015, 12:23 PM   #221
mid_life_crisis
I swapped over most of Wayno's modified tables. I didn't do the warmup ones as the noise doesn't bother me and my neighbors are already awake when I'm starting my car.
The response feels "crisper", I guess is the word. My question is, since Wayno wrote these tables for the lousy fuel he has available, and out here on the east coast of the U.S., I have access to good 93 octane fuel, I have to be leaving some power on the table. Which of the timing tables should I swap back, or is it that simple?
Old 07-27-2015, 05:40 PM   #222
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
I haven't gone through it, but I would start by identifying the tables that are different in Shiv OTS 91 vs 93. I don't know how to "Wayno" them
Old 07-27-2015, 05:58 PM   #223
Bergen23
Drives: '15 Halo FR-S
Much advice. So wow. Such engineer.
Bergen23 is offline   Reply With Quote
Old 07-27-2015, 06:20 PM   #224
Wayno
Wayno's Avatar
Before you change anything you should familiarise yourself with the differences in the OTS tunes by comparing:
91 vs 93
EL vs UEL
Stg1 vs Stg2
petrol vs E85
The answers to most of these questions would be obvious after that.
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
