Old 07-28-2014, 09:12 PM   #211
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Things I noted about the new tune (stage 1 93 octane) after 2 days of Blue Ridge Parkway runs:
(Have cat-back, tune, pulley, and filter btw)
+Smoother power band, little better response. Also feels like a tiny bit more torque for longer (still a slight difference but great overall)
+3rd gear feels like it pulls stronger
+Quieter idle
+Change in sound and volume slightly, more of an inline sound than a boxer, quieter for sure with a little less drone (on a V1 non-resonated)
+More torque when engaging next gear, 2nd to 3rd at high rpm just feels more instinctive and a quicker change
+Easier driveability, just feels smoother! I really like normal driving and it's smoothness, and driving fast is great!
-Less induction noise and growl
-Less of a surge at 4k rpm+ (not a bad thing, needle speed is more progressive and even)
-Less low end torque (1.5-4k), but maybe better mid range torque? not sure yet
-Valve train noise still prevalent (vvt "tin can noise" after 4krpm, especially on hills) but less than off-the-shelf tune.
-Slightly harder to get going, easier to stall? (could be crazy), had a rough start that almost stalled for the 1st time ever.
-Couldn't chirp 2nd
Overall I'm satisfied. Quicker speeds (maybe acceleration,) smoother car and feels like there is slightly more usuable power. I tried to focus on before/after changes but take my analysis with a grain of salt. Thanks Shiv for the awesome tune!
Readytoxplod is offline   Reply With Quote
Old 07-28-2014, 09:13 PM   #212
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by MstrSHAKE View Post
So far so good. I hate the dead pedal feel for a while.
Cure for dead pedal. After you flash it tells you to key off and disconnect. Key off and disconnect. Now key on, but do not start the car. Slowly depress and release the pedal 10 times. Fire it up and enjoy. It will continue to get sharper but this helps tremendously. Don't forget to let the car idle for a few minutes until the cams unlock as well.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 07-28-2014, 09:19 PM   #213
ML
ML's Avatar
Drives: 13 White MT FR-S
Originally Posted by solidONE View Post
I wish there was a way to compare the older roms to the new one with different .xml in romraider. I've spent many many hours tweaking some of the tables with the old xml. Wish I could just copy and paste in the new v2.01b.
I did exactly that. Moved my MAF scale, fan temp settings, and timing over .
Old 07-28-2014, 09:44 PM   #214
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
Smoother and faster is what I'm experiencing (Stg 1
91 ) It seems to have less peaky power and more usable torque spread out resulting in a quicker take off - curious see some 0-60 times compared to before - just to see if it's actually faster.
I really like the refined feel of the engine now - "instinctive" is a good word as readytox said
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 07-28-2014, 10:25 PM   #215
SilverFoxBRZ
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
OK, Stg 2 EL E85 A01C flashed, some noticeable improvements and refinements buuuut...now I am getting a P0463 CEL. Reset it and it just comes back. Did not happen with previous tanks of E85 and OFT OTS tunes. Shiv? Anyone? Buehler?
SilverFoxBRZ is offline   Reply With Quote
Old 07-29-2014, 12:08 AM   #216
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
So you just saved the old tables as excel file then pasted into the new rom and xml?
Also the target AFR table is wayyyy richer, I noticed.
Old 07-29-2014, 12:38 AM   #217
steve99
that code is for faulty fuel level sensor for fuel tank gauge. Does not appear to be related to tune.
Is you fuel gauge reading correctly ?
Old 07-29-2014, 12:39 AM   #218
steve99
good pickup- noting is ever easy :-), probably going to be a start from scratch again senario.
Old 07-29-2014, 12:56 AM   #219
solidONE
solidONE's Avatar
Bahhh...Humbug
Old 07-29-2014, 01:34 AM   #220
driftu
driftu's Avatar
Drives: 13 FR-S: Raven
Files question...
Bought my OFT a few weeks ago. Came with A01C files installed. Yet OFM indicates CAL ZA1JA00C. The v2.01 Beta only accepts A00C files to the tablet. A01C and all others are not compatible. This is all new for me so forgive my ignorance. Any insight would be much appreciated. Thanks
driftu is offline   Reply With Quote
Old 07-29-2014, 02:22 AM   #221
Kodename47
Kodename47's Avatar
Drives: UK GT86
Can you not open 2 ROMs in Romraider? I'm sure you can, and be able to compare them. Then it's just a case of copy and paste. I'll have a play in a bit.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-29-2014, 03:09 AM   #222
DriftHappens
Drives: '14 FRS White
Yes, you can open two roms at once in romraider.
DriftHappens is offline   Reply With Quote
Old 07-29-2014, 03:15 AM   #223
steve99
yes you can do that , but the tune changed quite a bit and altered many dependent parameter and tables, so if you just copied in your maf scale for example it will probably mess up what the tuner intended especially on the E85 tunes with no flex fuel sensor.
Old 07-29-2014, 09:06 AM   #224
ML
ML's Avatar
I'm still seeing high 11's in AFR after moving the scale. but no, it let me open the new tune with the old xml i was using, so I opened the old tune, and the new, and just copy and pasted the tables. After that I opened it with the new xml, and adjusted LC and FFS.
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
