#211 |
Drives: JAWS
I'm going to be changing my diff fluid every 15k, and tranny every 20-30k. I don't believe in "lifetime" fluid on parts that are going through that much stress and operation constantly. I care about my car too much to not do proactive maintenance.
#212 | |
Drives: fast
![]() I don't know where you got that they'll never change your trans or diff fluid but that inspection is to determine when to change the fluids. It's not touted as lifetime fluid is what I'm getting at. If your service department is not competent enough to recognize fluid needing change or skimps on their fiduciary responsibility to take care of your vehicle, find a new dealer. |
#213 |
Drives: 2013 WRB Subaru BRZ 6MT
#214 | |
Turning is for Nerds
Drives: 35 characters is not enough
As for the diff, the "inspection" is fluid level only, not quality. ![]() For me, I'll be changing both out biennially as a preventative measure. I don't personally trust the service department to make my car last much longer than the warranty period as they have already demonstrated their alarming lack of knowledge regarding this platform. My Toyota dealer mistakenly filled my coolant reservoir with washer fluid, and my local Subaru dealer gave me a bottle of STI GL-5 transmission fluid for my car and insisted that "it's what the techs use when BRZ owners request a transmission fluid change" |
#215 | |
Drives: 2013 frs
#216 |
Drives: fast
amen ^
I don't know why I'm splitting hairs over this.. motul 300 is in mine and will be there to stay, ha |
#217 |
Drives: white-out FR-S
Motul 300 how is it when cold shifting?
#218 |
Drives: Yes
Sometimes doesn't want to go into 1st or R if it's very cold. No issues once you get moving though
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
#219 |
Drives: 2013 frs
#220 |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
#221 | |
Drives: GT86
Impressions compared to stock fluid: -shifts are less crunchy (2nd gear) -2nd gear still refuses to go in when cold (below 0°C), even more than with the stock fluid -slight resistance in all gears during shifting after fully warmed up Overall conclusion: Gearbox feels marginally better than with the stock fluid...search for the perfect transmission fluid for 86/fr-s/brz still continues... Motorcraft fluid should be available at least from Ford dealers. |
#222 |
Mr. Cranky Pants
Try redline MT90 or Motul Gear300. I really like the Gear300 in mine.
#223 |
Also interested in where you guys are purchasing OE manual trans fluid GL3/4 as I went to both my local Subaru and Scion dealership neither of them could sell me individual quart sizes. They said no one purchases it from the dealer. When a customer brings in the car they just apparently order a gallon size... That was quite surprising.
I did find the GL5 Subaru diff oil on Amazon but not the trans GL3/4. |
#224 |
Drives: WRB Limited BRZ
Motul Gear 300 75w90 for the tranny and Diff
| DIY - Transmission / Diff Fluid Change Reference Guide | F1point4 | DIY (Do-It-Yourself) Guides | 295 | 05-13-2023 02:34 AM |
| Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 07:55 PM |
| What transmission fluid are you using? | Chillz | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 04-06-2013 10:45 PM |
| Transmission and Differential Fluid Change LINK | Amadeus | DIY (Do-It-Yourself) Guides | 1 | 12-23-2012 06:01 PM |
| topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) — General Topics | 51 | 05-04-2012 07:54 PM |
