Old 04-16-2015, 03:22 PM   #211
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by brzcountsright View Post
First of all, no way is the design of that plug in the glove box an accident! It's clearly designed to fit that rubber firewall opening, isn't it?
More importantly, I am sure glad I found this forum! First time I drove an FRS it had the TRD exhaust, so I was sure I was going to get that. Because of this forum I now have the OFH/OFT and the free sound tube plug, instead. For less than the cost of the TRD exhaust I have a car that runs MUCH better, inside the car sounds better, and outside the car is quieter!
The was an interesting comment about the plug in the glove box fitting.
I met Tada San the Toyota 86 engineer when he was in NZ so sent him the following question:
"Hi Tada san - we met when you were in New Zealand.
I wondered if you might answer a question for me.
Did you design the accessories 12V plug in the glove box to perfectly fit into the sound tube entry in the fire wall or is it just a coincidence that it fits exactly?
Kind regards
Paul"
His reply - "I did it!"
nzer is offline   Reply With Quote
The Following 3 Users Say Thank You to nzer For This Useful Post:
Icanfaptothis86 (08-07-2015), notout86 (04-16-2015), Tcoat (04-16-2015)
Old 04-16-2015, 03:35 PM   #212
Kind regards
Paul"
He must have misunderstood your question since the receptacle plug is the same size all makes have used for decades.
I am sure he thought you said "Did you design the tube so the plug will fit it?".
Old 04-16-2015, 03:37 PM   #213
The car with the TRD exhaust, OFH/OFT and no sound tube would rock your world!
Old 04-16-2015, 04:41 PM   #214
nzer
nzer's Avatar
I may have asked the question the other way around but pretty sure he got what I meant. Tube design rather than plug design.
The Following User Says Thank You to nzer For This Useful Post:
Tcoat (04-16-2015)
Old 04-16-2015, 08:15 PM   #215
notout86
Drives: GTS 86 auto
Kind regards
Paul"
BRILLIANT research nzer.
An immediate TSB (TechnicalServiceBulletin) for this matter should be issued
to the dealer service departments and an amendment to the User Manual sent to all owners.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 04-16-2015, 08:35 PM   #216
notout86
Drives: GTS 86 auto
nzer ..... I note that you have a 2015 VW Golf R. How do you rate its steering, in particular with the variable ratio compared to the '86?
Old 04-17-2015, 06:20 AM   #217
nzer
nzer's Avatar
I didn't really notice that the steering was different as the whole car is really a different feel. On track steering is great but does feel like the Golf rolls around the corners like a high sided van compared to the 86.
I wrote a comparison here http://www.ft86club.com/forums/showthread.php?t=78034
notout86 (04-17-2015)
Old 04-17-2015, 08:56 AM   #218
notout86
Drives: GTS 86 auto
Where I was coming from is our previous was a 1998 Nissan 200SX turbo (Australian) rwd which had variable ratio steering. Maybe it was also the much smaller turning circle but it seemed to turn into parking spaces between cars much more easily. Even after 2 years with the '86 I am still overshooting. I keep wanting to nudge the tail around with my hip.
All of which has nothing to do with the track work you are doing of course.
I enjoyed reading your comparison thanks. I took a VW Golf GTI for a spin and loved the power & torque like we had in our 200SX but lack in the '86. I liked the interior etc etc but I found it was no fun. There's a bit of magic in the '86.
Old 04-17-2015, 04:26 PM   #219
nzer
nzer's Avatar
Sounds like our taste in cars is similar. Pre my 86 I had a 2000 200SX Spec R.
Old 06-02-2015, 04:12 PM   #220
FRSwag2014
FRSwag2014's Avatar
Drives: 2015 BRZ Limited CWP
Send a message via AIM to FRSwag2014
Lowe's definitely had the part. Harware isle, Long drawers don't know if they're all uniform but it was in K6 locally.
thanks for the write up!
FRSwag2014 is offline   Reply With Quote
Old 06-14-2015, 12:05 AM   #221
notout86
Drives: GTS 86 auto
Has anyone tried coupling the vibrations from the sound tube to (for instance) the dead pedal or steering wheel ? The idea is that you don't have noise from the hole but you get the tactile feel to keep you in tune with the car.
I tried sealing a length of plastic tube in the hole and touching the end here and there but couldn't feel a thing.
I tried tapping on the dead pedal with a screwdriver and can feel that through my shoe. I tried tapping on the steering wheel itself and also the steel of the steering column but got hardly anything via the fingers.
I think the idea has merit in theory but any ideas to make it truly effective?
Also, when I peer into the hole I see yellow foam. Is that normal or something I shoved in to change the tone and have forgotten about?
Old 07-06-2015, 07:43 PM   #222
f1fan
Drives: Halo White 6 Speed
Great Mod
Thank you for your post. For 65 cents my car is better. The engine sound inside the car is better and not annoying like it was before I capped the Noise Tube.
f1fan is offline   Reply With Quote
Old 07-07-2015, 04:17 AM   #223
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
This was an awesome fix and still sort of is even after I have installed the TRD intake gives me something to plug that interior hole with
Sent from my A0001 using Tapatalk
Old 01-31-2016, 07:32 PM   #224
Maverickdy
Drives: 2014 Scion FRS
thank god i found this, definitely helps with my long commute. Just some warning to anyone who does this and rely's on engine noise to determine rpm/speed, you need to adjust your expectations after this. First time on the highway and i was going a lot faster than i thought i was :-3
Maverickdy is offline   Reply With Quote
enouf is a damned genious, plug, sound tube, toyoburu kazoo banned.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 11:48 PM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 06:56 PM
