#197 | |
You have to reset the value to what you want...I think by default the FFS set point is right at the rev limiter (delta=0). In RomRaider open that value and reset it for about 600 or so...remember that it is a delta value, meaning the actual set point will be the rev limit (7600) minus your delta value. So, an input of delta=600 will give you a FFS set point of 7000 rpm
Ultramarine 2013 Scion FR-S 6MT
| The Following User Says Thank You to CaptainSlow For This Useful Post: | Readytoxplod (07-28-2014) |
#198 |
Drives: Asphalt FR-S
@Shiv@Openflash I have flashed the 1.5x tune stage one on my FRS, and especially in 3rd gear, when I hit ~4k RPM there is a loud noise almost like a vibration somewhere but I see nothing that is vibrating. Please help! I am flashing it back to stock until I hear from you. Definitely a bad sound...
And Jezza spake unto them and proclaimed that he who shall be last, shall be sideways and smiling.
#199 | |
APEXHNTR
Drives: 10 Series FR-S #1867
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
#200 |
That was my thought too but it was loud!
#201 |
I had a 2001 Celica GTS and its VVT-Li was loud but this was much louder almost sounded like a knock. The sound would go away after ~4.5k so it wasn't loud for long, but it scared me. lol
#202 |
Yeah it was loud on that tune...much quieter now
#203 |
What tune are you on now?
#204 | |
Drives: 2013 FRS
I don't typically use FFS myself. But when I do, I set the value to 1000rpm. This means that whenever the clutch is pressed the fuel is cut until revs fall below 7600 (rev limit) - 1000 or 6600rpm. This means that you need to shift well above 6600rpm for this to work properly. Which make sense since you are looking for max acceleration when using FFS. So shift around 7500rpm and you will be happy with the result. If you set the FFS RPM value to big, it may start to interfere with normal driving because all it takes is a little pressure on the clutch to enable the switch. Cheers shiv |
| The Following User Says Thank You to Shiv@Openflash For This Useful Post: | Readytoxplod (07-28-2014) |
#205 | |
#206 | |
#207 |
This seems common if you have the sound tube, but I don't. Any other thoughts?
#208 | |
http://www.ft86club.com/forums/showt...t=intake+noise There's nothing to fix, so the beta tune won't "fix" anything. The noise is just resonance in the intake tract, and isn't anything bad. The stock tune makes the same noise, just not as pronounced.
| The Following User Says Thank You to wparsons For This Useful Post: | Venator (07-28-2014) |
#209 |
Drives: FR-S Whiteout
I wish there was a way to compare the older roms to the new one with different .xml in romraider. I've spent many many hours tweaking some of the tables with the old xml. Wish I could just copy and paste in the new v2.01b.
#210 |
Drives: 2014 SWP BRZ
So far so good. I hate the dead pedal feel for a while.
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 01:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 06:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 11:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 05:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 09:45 PM |
