Old 02-22-2012, 12:16 PM   #197
TRDGT86
TRDGT86
Drives: 86
Originally Posted by Dark View Post
I hope for TRD edition instead of buying the whole thing which will cost a lot of money.
TRD edition wont be released until 2014 ..... if you want that, you will have to wait
TRDGT86 is offline   Reply With Quote
Old 02-22-2012, 12:21 PM   #198
TRDGT86
TRDGT86
Drives: 86
I think TRDUSA will make a supercharger for US spec
Old 02-22-2012, 02:25 PM   #199
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Originally Posted by serialk11r View Post
Lightweight pulleys do not cause significant friction reduction...and flywheel horsepower is after all the engine's mechanical friction is accounted for. The car does not lose 15% to the wheels, it loses ~10% and then the dyno sees another missing 5% because the rotating mass is absorbing kinetic energy as it accelerates, and the 1% or so of energy that the tire is absorbing.
The 2ZZ-GE has .2L less displacement, but also revs higher to make up for it. The difference in revs is big enough that the FA pulls in about the same amount of air at peak power.
Anyways, I highly doubt you can hit 300 without swapped internals. Most I'd bet on is being able to match 2ZZ numbers.
i did state that i was going to swap internals, new valves,springs,retainers,cams, lighter pistons and rods, change the redline to 8500, then i would be able to rev just as much as my current car...
the 2zz-ge was limited by its head design and intake manifold design , it didnt flow like a k20, the most anyone ever got out of a 2zz-ge Na was about 250 WHP, k20 got about 300+ whp
if the head does flow better, which i imagine it does because of the torque numbers, we will see better gains than the 2zz-ge
if you ask anyone who has seriously tinkered with a 2zz-ge would know that, its not the best flowing engine out there, DDprefomanceresearch made a new intake manifold that yielded some pretty crazy numbers, i think it was like 30hp untuned and 50hp with a tune
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 02-22-2012, 05:12 PM   #200
serialk11r
Drives: '06 AM V8V Coupe
Okay cool, I look forward to seeing what you do. But you first said 300hp with intake/header/exhaust/supercharger, which is never going to happen on pump gas.
Old 02-22-2012, 05:23 PM   #201
carbonBLUE
Reverse Burnouts
it ll be a build in progress while im in japan ill post pics when i find a place i can work on it/store it
(wont forget you)
2011 Infiniti G37x
Old 02-23-2012, 06:57 AM   #202
TRDGT86
TRDGT86
Drives: 86
it is very easy to get 300HP with these mods on it
Old 02-23-2012, 08:01 PM   #203
serialk11r
You have proof? As it stands, the engine is capable of sucking in the same amount of air as the 2ZZ, and is a little bit more efficient. That won't make a magical 20% extra power appear from nowhere.
Old 02-23-2012, 09:14 PM   #204
carbonBLUE
Reverse Burnouts
so you're saying 9whp is impossible to gain from an engine that flows better and has 0.2L more? whats the company you bought the rock from, ya know the one you live under...
(wont forget you)
2011 Infiniti G37x
Old 02-23-2012, 10:01 PM   #205
serialk11r
Sorry if I missed something, but you said the most anyone got from a 2ZZ naturally aspirated was 250hp...is this with stock displacement and rev limit? If so, then sure, 300 is possible.
But to make 300hp on this engine without changing rev limit, you have to give it at least 50% more air, which is more than .5 bar boost due to heat of compression. And this is while performing more work during compression cycle at low lambda values, and doing less expansion.
If I'm not mistaken, the Exige S makes a bit under .5 bar boost stock, but only picks up <15% more torque/power. And you're telling me that you expect 50% more with under 1 bar boost among other mods? 20% on top of 200hp is 240, you don't simply pick up 60hp from a cat/muffler delete. If the exhaust caused that much restriction manufacturers would've gotten the whole active noise cancellation thing going a long time ago. I don't believe that a stock engine could have enough detonation headroom built in to withstand 1 bar boost, no matter how well it's intercooled.
Old 02-24-2012, 08:53 PM   #206
carbonBLUE
Reverse Burnouts
you do realize that the exige is on a conservative tune for reliability reasons right? no car manufacture would put as aggressive as possible on a factory car and sell it? it just wouldn't be reliable...
this is a basic tune on a exige with no other changes other than ecu mapping
this is WHP and it shows before and after the tune
this 7psi 11.5:1 comp, completely stock
EDIT: every car manuf runs a conservative tune thats why you're always able to tune more out of a stock engine....
(wont forget you)
2011 Infiniti G37x
Old 03-08-2012, 08:01 PM   #207
NERO
Drives: 2012 Honda Ruckus
I really love the look of those brakes, but I don't think I would spend that much money for them. Even a brembo kit just like that for the STI is nearly $7,000. You can buy a set up of STI brakes and at the same time swap out the hubs for about $3,000 brand new. Just pay a little bit of money to have them powder coated and you're set for much less and you still have a perfect brake set up for the car.
NERO is offline   Reply With Quote
Old 03-12-2012, 03:08 AM   #208
catharsis
Drives: honda civic si 08
I think depending on the how the motor handles it you could reach close to 300 whp with a supercharger and supporting mods. I'm guess it'd take about 10psi to get there though.
catharsis is offline   Reply With Quote
Old 03-13-2012, 12:41 AM   #209
FT-86
Future 86 Owner
Drives: Toyota 86 (Very Soon!)
Sorry for my ignorance as I have never bought any TRD kit (or any aftermarket parts) before but I am liking the TRD kit a lot.
My questions is whether it would be better to get the car now and add the kit later or wait til the kits are out and get them then?
Will the dealer take into consideration that since I will not be using the stock parts (i.e. wheels, seats and etc), the prices for the kits will be lower compared to the later add-ons?
Your input will be very much appreciated.
FT-86 is offline   Reply With Quote
Old 03-27-2012, 02:12 AM   #210
fatoni
not that i care or really even know anything about the subject at hand but the compression ratio seems kinda like a limiting factor. on the other hand the rotrex charger is probably more effecient than anything that has been on an mr2
trd 86, trd fr-s, trd frs, trd scion fr-s
Scion FR-S OFFICIALLY REVEALED (Details, Specs + Live and Press Photos) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 857 05-30-2012 04:57 PM
Cusco Parts Announced JSC Speed Scion FR-S / Toyota 86 GT86 General Forum 46 04-13-2012 05:13 PM
UK Price officially announced!!! DkHachiroku Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2012 09:13 AM
Tom's parts announced for 86 Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 36 02-04-2012 06:21 AM
Lexus IS-F parts wish list aspera Engine, Exhaust, Transmission 21 08-18-2011 02:59 PM
