#197 |
That Guy
Drives: 2013 asphalt FRS MT
I was hoping someone would come up with a mount for that location as it shouldn't interfere with may other mods, the hoses would remain short, and there might even be room for a fan.
#198 |
#200 |
Drives: GT86
#201 | |
Drives: Matte Black STI
Also the 10psi pulley didn't make much more power?? Again, that is NOT correct. ![]() It for sure makes more power and Lance at Vortech found on the 91oct fuel, it made about 15HP more across the board. It made more on our 92oct fuel (much better fuel than the Cali 91) because we can run more timing. REgarding knock up top? Define knock? Like pulling a degree, pulling 5 degrees, audible knock..... The tunes I have sent out (very few so far) have had nothing like this. The only one that ever had some "knock" (ECU pulling 2 degrees, nothing crazy) was a car in 91octane land at higher elevation. I just want to be clear on those things as I don't want misinformation spread. |
| The Following 3 Users Say Thank You to PERRIN_Jeff For This Useful Post: |
#202 |
Jeff, that's great. But I've personally seen different. I've seen a 91 map make X power, then everything was tuned for 93 octane on the same car... it made similar power (maybe 2-3 whp difference). I think knock might be a strong word. I'm referring to the timing being pulled up top on the 3 cars phasetek did causing the roller coaster power curve. The ECU pulled timing for a reason. I'm curious as to what it was.
My experience was also on a mustang dyno, rather than a dynapack... if that makes a difference. I think given the... generous... nature of a dynapack, then that would make sense. If you'd like the charts, I'll have to see if I can get them. Mustang dynos don't give you runfiles like dyno jets. I only got a printout at the time. It was a little while ago, so I'm not sure if they even still have the runs stored on their computer. Last edited by 2forme; 03-14-2013 at 01:29 PM. |
#203 |
That Guy
I doubt 2forme and Visconti are lying, or trying to spread misinformation. I also believe that both Jeff and John can tune an engine. So there's got to be more to this then just, Jeff is right or John is right.
As Jeff mentioned the 92 was much better Gas. I'm wondering if there's more to this then just the octane rating. Could the additive packages and oxygenation be causing some of these differences? |
| The Following User Says Thank You to Calum For This Useful Post: | 2forme (03-14-2013) |
#204 | |
I'm not sure what gas John used. It appears that Perrin uses known good gas. |
#205 | |
Here is a run at 13psi of boost........... ![]() The drag of the SC is the limiting factor?? Not sure how that is. This supercharger in its stock form will run say an additional 40-100HP more. That is a ton! And that doesn't include a future bigger SC'er. Once people start building their engines, I will bet my BRZ that they will offer something that will run 14-20psi of boost! I have said before though, the stock engine and 12psi is a good limit for pump fuel. From 10-12PSI there isn't a ton of top end HP to gain, but there is tons of low end to gain. I am speaking in general terms here, not SC related or turbo related. Pump gas and 10psi is where I started to see diminishing returns. People have to remember that E85 isn't the normal for people. They also havet to remember that this thing is 12.5 CR and that is a lot of boost for the stock engine.... Here is a run where my car made almost 300WHP (forgot to save on dyno so Iphone pic is the only proof). It was not the final tune, as I left it running more like 285WHP and of course no crazy drop off. ![]() Here is the boost curve from one of the runs previous.....
#206 |
Jeff I'm sorry, but why does one well known tuner say that there isn't much room past a certain threshold and you say completely different? I went back and reread Visconti's post and it wasn't necessarily fuel limited, but knock limited. So I apologize for misremembering. Either way, knock isn't safe.
http://www.ft86club.com/forums/showp...&postcount=249 Unless you're running a different compressor, I don't see how you get vastly different results. John has never posted anything that wasn't reproduceable by third party customers. Something isn't being said here. It just doesn't line up, I'm sorry. |
#207 |
2forme, I wasn't saying you were lying either. Sorry if it came off that way. I have the logs from one of those cars and there is ZERO knock correction, so of course I have to say something. Being that I tuned our car on 92 fuel and they are running 93, it shouldn't be knocking.
You said... My experience was also on a mustang dyno, rather than a dynapack... if that makes a difference. I think given the... generous... nature of a dynapack, then that would make sense. Not sure what generous means, but my Dynapack reads like many Mustangs around. Also if anything it picks up on things more accurately than Mustangs, and doesn't hide things like knock or timing being pulled.I can see a 1 degree change or a a funny flat spot in a timing map, compared to where a Mustang deadens this due to the big heavy rollers. Also How long were the runs on the Phastek cars? I show 11 seconds running it to 7800, where we were running 12 seconds to 7500 making for more actual load on the engine. BTW, I only asked about "knock" because many onlookers may freakout about the word "knock" when its normal/safe to see 1-2 degrees of timing being pulled (ECU calls it knock correction) but there is no Audible knock happening. |
| The Following User Says Thank You to PERRIN_Jeff For This Useful Post: | Sonolin (03-14-2013) |
#208 | |
Your dyno is very generous. Nobody has gotten relatively near the numbers you have, even with your exhaust. You posted 247whp on the "stock" (6psi) pulley. Even Gem couldn't touch that with an 8.5 psi pulley. The 3 cars at Phasetek with your kit and tune, 225-230. Pete doesn't have your tune and he didn't get near it either. It's ok, not knocking your claims. Dynapacks are known to be 10-15% higher than Dynojets, which are 8-15% higher than Mustang Dynos. If your dyno read like mustang dynos, then the Phasetek dynos would have read near 300whp, lol. That's all I meant by that. |
#209 |
Drives: Scion FRS
So nothing is needed to run that 14psi kit other than the pulley? What size is that pulley compared to the stock 3.6 it comes with?
#210 | |
Drives: 2016 Subaru WRX
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD |
| Front pipe / Quad Tip Exhaust / Light Weight Race Exhaust / Unequal Length Headers | JonMotoring | Engine, Exhaust, Bolt-Ons | 314 | 01-22-2016 01:19 PM |
| Pete's Perrin Vortech build thread | Pete | Member's Car Journals | 91 | 06-04-2013 02:38 AM |
| *PHASTEK* Perrin Tuned Vortech Supercharger Install Thread (3 Vehicles, 3 Kits) | PhastekSport | Forced Induction | 425 | 04-26-2013 11:06 AM |
