#197 |
+40 17x9 should be good to over -4 camber, that's where I'm at, if I remove spacers I just try to be careful about not turning the wheel all the way.
| The Following User Says Thank You to strat61caster For This Useful Post: | Breezio (07-06-2020) |
#198 | |
Drives: 2017 BRZ series.yellow
I do not get any rubbing up front so far. I had a tiny bit over big bumps in the rear intially, but I raised the rear ride height a tad and none since then. Where does your tire touch the liner? |
#199 | |
Drives: 2017 BRZ w/PP
if you look at the 2nd pic i just barely touched the liner like this guy. i dont touch at the top. i assume that is from when i hit a turn too hard and understeer and keep going like a dumbass. only on my drivers side too which is why im guessing it is from what i think |
#200 | |
#201 |
Drives: 2016 Scion FRS
Alright.
It is time to put a lightweight battery in the car (after I raise the car and align it again). How long are people letting their cars sit between drives without issue/attention? |
#202 |
ive done 5 days with mine and had no issues. when going away for more than a week i disconnect it
#203 |
Over a week on Odyssey PC680 without issue (shutdown wfh life), coming up on three years old for that battery this fall. Not the lightest but it hasn't skipped a beat and it doesn't break the budget.
#204 |
Drives: 2013 Subaru BRZ Premium MT
The Antigravity ATX-12-HD in my car has gone two weeks without any issues. It's also only 3 lbs.
Sent from my SM-G973U using Tapatalk |
#205 |
I have Antigravity ATX-20 RS. I've had the car sit for a week + without issues.
I did kill it over the winter because I forgot to put it on a tender, and the restart tech on it is absolutely amazing. Talk to Bart.
Kyle H. - #89 STX
#206 |
mines the shori lfx36l3-bs1
#207 | |
No more full lock turns from now on... |
#208 | |
yep thats what happens when you run 255 fatties. i originally thought it was because i bent something on my driver side going off track but it is on both sides. i probably did bend something but after the alignment they are even |
#209 |
i just rubbed some more yesterday with my REs. I guess the way to fix this besides dont go near full lock is get a wheel with more offset?
edit:im dumb i want less offset and i have 3mm spacers ill toss on to see if they hit full lock Last edited by Breadman; 07-10-2020 at 11:42 AM. |
#210 |
Drives: 2013 FRS
Some of these may do it.
https://www.amazon.com/dp/B01M6238ZD..._HXicFbGYZSW40 Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 11:27 AM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
| Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
