Old 08-13-2012, 12:23 PM   #197
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
Kind of reminds me of the age-old way of "troubleshooting" computers -- beep codes. That was one of the few things that learning in early 2003 that still applies today. The rest as far as IRQ and interrupts don't ever really come up as potential issues nowadays.
It always irked me because beep codes (like CELs) vary from manufacturer and some aren't even used at all anymore. Newer motherboards are starting to feature a double-digit (seven segment LEDs) code that tells you what is going on. I upgraded my brother's PC recently and got a board with this feature, REALLY helpful.
Most things are going towards being more open, the car manufacturers should embrace it a bit more. They don't need to have everything exposed, but most cars should be able to at least display the CEL on the radio or another screen (like all those ones Hondas come with now). It's stupid that you even need to pay somebody $X to get that code for you, just a grotesque rip-off.
eriktherod is offline   Reply With Quote
Old 08-13-2012, 12:24 PM   #198
2pt5RS
Berz
Car had a rough idle on start up this morning. I attributed it to the cooler weather this morning.
Regardless, I'm going to watch it more closely.
last 4 of my VIN is 1034.
2pt5RS is offline   Reply With Quote
Old 08-13-2012, 12:37 PM   #199
Propaganda
Diamonds & Cadillacs
Drives: '13 fr-s, 1974 911s
Have you been living under a rock?
Go to an autoparts store (in my experience, Advance)... Ask to borrow an OBD2 scanner..... plug it in, find code, clear if necessary, walk back in to store 2 minutes later.... diagnosis for free.
Propaganda is offline   Reply With Quote
Old 08-13-2012, 12:47 PM   #200
enigmaaron
enigmaaron's Avatar
Drives: '13 Firestorm FR-S MT, '04 Tacoma
Buy a $20-30 code reader one time. Problem solved. The fraction of car buyers that would want or even comprehend that functionality has got to be so miniscule it's probably never even been considered by a car manufacturer.
EDIT: Or what he said above.
enigmaaron is offline   Reply With Quote
Old 08-13-2012, 12:55 PM   #201
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Since when does a code reader diagnose the problem? It simply tells you where to look...doesn't tell you what caused the problem...or how to fix it.
On subject...I've complained about a rough/low idle concern since day one. It doesn't seem to affect the performance but it doesn't seem right. Mine gets so low at times it seems like the engine is going to stall but it is very intermittent. No CEL's yet...but I hope there is a reflash/TSB in the works to get it "corrected".
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 2 Users Say Thank You to Opie For This Useful Post:
20valvewynn83 (08-14-2012), 2pt5RS (08-13-2012)
Old 08-13-2012, 01:51 PM   #202
Propaganda
True... I shouldn't have been so quick to choose my words.
The Following User Says Thank You to Propaganda For This Useful Post:
Opie (08-13-2012)
Old 08-13-2012, 03:01 PM   #203
brufleth
Drives: 2007 WRX
Oddly enough on my wife's 2005 Legacy you can open a panel by the driver's knee and connect two cables, with that done you can get it to display codes on the dash display. It was strange.
Other cars sometimes have similar things. Some require pressing the trip reset right after turning the ignition or something like that. It still only gets you as far as the codes. Often times several things get OR'ed into a given code and even obvious seeming codes (like a knock sensor code) could mean anything from a sensor problem to something more obnoxious.
brufleth is offline   Reply With Quote
Old 08-13-2012, 03:20 PM   #204
tintumz22
tintumz22's Avatar
Drives: 2013 Scion FR-S Toyota 86
Update:
Car checked in the dealer today. Had them also know about a clunking noise when releasing the clutch when in neutral, when in reverse and 1st gear.( More audible on those circumstances) Checked the parts and saw the same as the pictures shown earlier on this thread. New ECU confirmed last 3 digit #811. Overheard from the parts rep that it is really in testing mode for all these parts came in for the repair. (The feeling I'm having with the variety of VIN #s having this problem is a Recall SOON) But we'll standby for that! I'll post whenever I get an update from my Service Rep. Hopefully the fix will do it cuz I'm really eager to drive my car! It's really a sad feeling just looking at the car inside the garage!
For now.. More forum reading and exploring while waiting until tomorrow or Wednesday until they give me a call. Also, they gave a a Camry loaner! Told them that I was expecting a corolla but yeah they gave me a special treat I guess.
tintumz22 is offline   Reply With Quote
Old 08-13-2012, 04:42 PM   #205
Shizzaw
Shizzaw's Avatar
Drives: Whiteout FR-S
Just thought I'd add that this exact problem happened to me too. I bought my FR-S on Wednesday. The problem occurred Thursday. Took it back to the dealer Friday, and there it sits. They are telling me that it needs a new ECU and oil control valve. Coincidentally, both parts are backordered with no estimated shipping date. I bought a car, drove it for a day, and havent seen it since. Can I invoke the California Lemon Law on this? The car had less than 200 miles on it when it happened.
Shizzaw is offline   Reply With Quote
Old 08-13-2012, 08:01 PM   #206
fistpoint
Drives: Supercharged Golf Cart
Lemon laws may vary from state to state, google it for yours. I recently read it for Texas and it mentions specific timeframes and/or mileage for the vehicle to qualify.
Basically if it gets fixed for the same problem X amount of times in X amount of miles it's a lemon. There is also a section dealing with safety issues which is slightly more lenient when declaring the vehicle a lemon.
This section here should cover the idle issues if it keeps coming back:
"(3) the vehicle is out of service for repair for a cumulative total of 30 or more days in the 24 months or 24,000 miles, whichever occurs first, and at least two repair attempts were made in the first 12 months or 12,000 miles immediately following the date of original delivery to an owner and a nonconformity still exists that substantially impairs the vehicle's use or market value. The initial 12-month period or 12,000 mile limit, the subsequent 12-month period or 12,000 mile limit, and the 30-day period shall be extended by any period of time during which repair services are not available to the owner because of a war, invasion, strike or fire, flood, or other natural disaster. During any period of time that the manufacturer or distributor lends a comparable motor vehicle to the owner during the time the vehicle is being repaired by a franchised dealer, the 30-day period provided for in this subsection is tolled."
fistpoint is offline   Reply With Quote
Old 08-13-2012, 09:01 PM   #207
eriktherod
I have an OBD2 reader, I'm just saying in the generality of things. I know they're maybe not expensive anymore but with how technology has come.. it's silly not to have that as part of the diagnostics now.
Old 08-13-2012, 09:04 PM   #208
alrashwa
alrashwa's Avatar
Drives: '12 370Z Monterey Blue
Update
So I called Corporate again, and by now I have a case number. They attempted to get in touch with the service tech working on my car to no avail.
I then called the dealership directly. They never received the parts needed for the repair. Their best estimate puts them in on Thursday, with another day required for the install at the least. So I probably won't see my car until next Monday.
Looks like I'll be a total of 18 days without the car, a dirty Hyundai Elantra as my replacement, and no firm idea as to when my car will be fixed or if it will even work right when I get it back. Only had the damn thing for 24 hours since I purchased it. Extremely frustrating experience so far.
alrashwa is offline   Reply With Quote
Old 08-13-2012, 09:52 PM   #209
tintumz22
tintumz22's Avatar
I was in touch w/ my service rep. I got to see the parts in person so stating that I feel bad for you that they did not get the parts yet. But hopefully they'll get it to you ASAP! But today not doing anything went back to the dealer to check on my car and it is there waiting for it to be touch. They were saying that they still waiting for Toyota for recommendations on what they will do. (hearing that made me rest assured that they don't want to mess anything up) So, mostly by wednesday or thursday for me to get the car back.
Same here man. Frustrating not having the car for long time and things happen.
The Following User Says Thank You to tintumz22 For This Useful Post:
alrashwa (08-13-2012)
Old 08-13-2012, 10:08 PM   #210
Yruyur
Yruyur's Avatar
Originally Posted by siXXtoes View Post
my vin is 6645 and i threw a CEL. I had the new ecu and still had issues with the cam. The dealership replace the bad part and ecu.
based on that, i dont believe if u have the old ecu it is the sole issue...
So you had the 811 and not the 810?
Sent from my PH44100 using Tapatalk 2
My car is in and still 1,304 miles away! joshua BRZ First-Gen (2012+) — General Topics 16 06-28-2012 09:02 PM
Some Miles White_OUT_FR-S Scion FR-S / Toyota 86 GT86 General Forum 0 06-22-2012 03:00 PM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 10:50 PM
Check Engine Light directly after pickup Stu L Tissimus BRZ First-Gen (2012+) — General Topics 27 06-15-2012 06:07 PM
Check engine light code reader FRSCoupe Engine, Exhaust, Transmission 14 06-13-2012 06:06 PM
