Old 07-27-2014, 07:14 AM   #2003
Deckhand
Drives: 2013 DMG BRZ
Just waiting on FBM rad and shroud...
Deckhand is offline   Reply With Quote
Old 07-27-2014, 04:12 PM   #2004
John Rambo
John Rambo's Avatar
Drives: Turbo BRZ Limited 6MT
Originally Posted by limitedblkwrx View Post
Did you reuse the stock collar with the o-rings?
Looking at the below video and forum looks like that part can be an issue for many.
There may be air getting sucked up instead of fuel, because the o-rings aren't sitting right, which would make sense if your pump isn't full submerged in gas while on a hill. Hope this helps.
http://www.ft86club.com/forums/showthread.php?t=41770
See, I saw this post first, so I thought that using 3 would be correct, and the white spacer didn't really want to go on.
Originally Posted by DriftEm View Post
It looks like Deatschwerks has revised the bump, as you can see below the output shaft has these teeth like thingy now. The white washer does not fit on this new output shaft anymore. But the kit now comes with 3 of the black O-rings.
And why wouldn't I have fuel issues when I'm already going up the hill if the pump wasn't being submerged completely in the gas tank? Aargh. So confused. Thanks for the help; I'm just trying to figure out what exactly I'm doing before I take it apart again, rather than keep going through a cycle of troubleshooting.
John Rambo is offline   Reply With Quote
Old 07-28-2014, 02:03 PM   #2005
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Generally the O rings only fix issues when you lose fuel pressure and lean out at WOT. If you take it apart again, make sure you take pictures of it before it so we can try and pinpoint what is wrong. Does this happen even with a full tank? The only thing that makes sense if it only occurs when on a hill is the fuel pump install itself.
Old 07-28-2014, 03:20 PM   #2006
John Rambo
John Rambo's Avatar
So there's no way it's a tune issue? The car bucks both on hills and on flat ground... I supposee slightly more often on hills...
Yes I just filled up the tank and the random bucking and afr jumps are still happening, but I haven't tried starting up from a steep hill from a stop yet.
Old 07-28-2014, 03:23 PM   #2007
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It can always be the tune, but not when the only variable is being on a hill or not. LJ supplies a basemap not an off the shelf tune. It is designed to get the car to the tuner of your choice to tune your setup.
Old 07-28-2014, 10:39 PM   #2008
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Sounds like me. Turned out to be a squished regulator line. Caused issues when the voltage to the pump fluctuated(this is a voltage controlled pump) and the reg couldn't adjust. Also caused issues with the oem venturi.
Old 07-29-2014, 12:07 AM   #2009
mashal
DADA
mashal's Avatar
Drives: 2013
Just to add to the list of issues..
When I'm driving and coming to a stop or slowing down for any reason and I downshift to a lower gear and go into neutral , the car shuts off .. Still rolling .. Completely dies, the fuel cuts off , doesn't matter clutch in or out, the only way I have been able to stop it from stalling is to blip it and prevent it from going under 1000rpm until I come to the stop.. going for a retune in a week .. Any thoughts?
mashal is offline   Reply With Quote
Old 07-29-2014, 12:16 AM   #2010
Reaper
Reaper's Avatar
Drives: violent
Sounds like fuel pressure problems. See my above post. Kinked regulator line inside the pump housing.
Old 07-29-2014, 02:44 AM   #2011
John Rambo
John Rambo's Avatar
Dropped it off at evasive motorsports today and told them about it, I'll let everyone know what it was after I pick it up at the end of the week
Old 07-29-2014, 02:30 PM   #2012
King Tut
NASA SpecE30 Racer
King Tut's Avatar
My guess would be the BOV opening up or a poor tune. Lightweight flywheel?
Old 07-29-2014, 03:17 PM   #2013
mashal
DADA
mashal's Avatar
Drives: 2013
No stock
Old 07-29-2014, 11:35 PM   #2014
mashal
DADA
mashal's Avatar
Drives: 2013
I dont think so, original install never gave me an issue, only after retune it started doing this
Old 07-31-2014, 01:53 PM   #2015
Reaper
Reaper's Avatar
Drives: violent
oh well damn....
Old 07-31-2014, 01:55 PM   #2016
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Need a better tune. Fuel trims must be crazy on that low MAF range, close to idle and thus it dies on you.
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
