Old 10-26-2013, 02:38 AM   #15
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Idk they are all cheap, the o-rings and spacers that is, but the sun isnt even near its highest point in the Twins Aftermarket life, so there isnt a science to it yet.
killerkid08 is offline   Reply With Quote
Old 10-28-2013, 09:12 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by DriftEm View Post
what's part number for the o-ring?
@xjohnx has a part number from Napa for them, he'll chime in.
Originally Posted by pheoxs View Post
I still don't understand this hole stacking orings, it just doesn't make sense to me why it'd be like that.
Great write up though! I'm installing this pump next week and really appreciate the pics
The available FP's are universal, so their height is different than OEM pump, thus the need to play around with O rings to make the pump seal inside the canister and not loose REALLY important fuel pressure and prevent the motor from BOOM.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
pheoxs (10-28-2013)
Old 10-28-2013, 09:15 AM   #17
xjohnx
Grip>Slip
xjohnx's Avatar
NAPA part 2-12093 for 2 of them.
The Following 3 Users Say Thank You to xjohnx For This Useful Post:
Bramick (09-01-2015), DriftEm (10-28-2013), Sportsguy83 (10-28-2013)
Old 10-28-2013, 09:16 AM   #18
Sportsguy83
Drives: Limited BRZ
Thanks man.
@xxscaxx add these to OP
Old 10-28-2013, 12:12 PM   #19
xxscaxx
Drives: 2013 SWP BRZ
Thanks man.
NP, added it under step 11 where it mentions the o-ring installation.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
Old 10-28-2013, 08:54 PM   #20
DriftEm
DriftEm's Avatar
It looks like Deatschwerks has revised the bump, as you can see below the output shaft has these teeth like thingy now. The white washer does not fit on this new output shaft anymore. But the kit now comes with 3 of the black O-rings.
DriftEm is offline   Reply With Quote
The Following User Says Thank You to DriftEm For This Useful Post:
Old 03-18-2014, 04:26 AM   #21
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Thanks to the OP for the DIY! I'm about to install the DW65c fuel pump in my car, and this thread is extremely helpful. However, I have a couple of questions. It looks like DW has revised the pump nipple as posted by DrifEm. They now include 3 o-rings and their instructions tell you to install the three o-rings or alternatively, the white spacer (cut on one side so it will expand and slip into the revised nipple) and one o-ring. Whoch method is better?
The local tuner here who installed the same pump on their 450hp 86 shop car advised me not to cut the spacer and just use a file to enlarge the hole on the white spacer and use one o-ring. What do you guys think?
HRTROB is offline   Reply With Quote
Old 03-18-2014, 12:13 PM   #22
xxscaxx
Yeah, I wouldn't cut the white spacer. Over time it may crack the spacer on the opposite side.
I'd just install the 3 o-rings, or you could file the spacer as well. Its more or less the same thing, just take the 3 o-rings and make sure they are the same height as the white spacer + 1 o ring. I mean any modification you make to that spacer you are losing some of the integrity of it, so I am not sure how comfortable I would feel having to drill that out or cut it.
Why did DW do that?
Sportsguy83 (04-06-2014)
Old 09-19-2014, 07:50 PM   #23
Turbowned
Turbowned's Avatar
Thanks for the DIY; it helped a lot!
I have the revised pump as well and I cut the spacer personally; it appears to be made of delrin so it should stay solid. I used the white spacer and two o-rings as pictured; though... hope it doesn't cause an issue...
Old 09-25-2014, 01:59 PM   #24
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Just installed mine today. Installed it with four o-rings first per instructions. Car started and idled fine. After a street tune, we parked the car for a few hours, when we tried to start it again it would not fire. We took the pump out and put the spacer on with one o-ring, the car started up again.
Tye300 is offline   Reply With Quote
Old 08-20-2015, 11:56 AM   #25
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I hate to ask such a stupid question. I'm wanting to get the DW65c fuel pump, so that I won't starve my engine when driving hard. But, during regular DD, would having a larger fuel pump result in a decrease in MPG?
MS, CSCS, TSAC-F, CPT
Old 09-04-2015, 05:57 AM   #26
ajc209
Drives: GT86 Cosworth
Hello,
Have you had any issues with fuel staration?
As I understand it, the stock pump is capable of supplying enough fuel to a Cossie stage 2?
ajc209 is offline   Reply With Quote
Old 09-04-2015, 12:36 PM   #27
weederr33
weederr33's Avatar
Originally Posted by ajc209 View Post
Hello,
I have not, but I was considering upgrading it eventually.
Old 11-18-2015, 09:33 PM   #28
dj2020
DIY: Deastchwerks 265c Fuel Pump Install
@xxscaxx Thanks for this DIY. It made the fuel pump install fairly straightforward.
I do have a few questions about my install and if I did everything correctly. I ended up installing the Denso 260lph from Chris over at Speed by Design and purchasing a DW adapter kit from Summit Racing. The wiring harness worked perfectly and I used the OEM white collar with 2 o-rings. Everything seemed to be plug in play except for the fuel sock. The DW adapter kit from Summit Racing came with a short yellow sock that had a rigid plastic backbone inside of it that prevented me from bending/fitting it into the fuel canister assembly. However it did allow for the metal barbed ring and rubber black end cap to be used to secure the sock to the end of the fuel pump as per this DIY. On the other hand, the longer, white sock that came with the actual Denso fuel pump allowed me to fit the fuel pump assembly back into the canister assembly because the sock was much more flexible. But this longer, white Denso sock did not allow me to secure it to the new Denso fuel pump with the barbed metal ring and black rubber end cap. It is simply pressure fitted into the hole at the end of the fuel pump. It seems secure because I had to push fairly hard to get it pressure fitted but I'm concerned that it will eventually work itself loose. Also, since we've removed the clipping mechanism that held the OE fuel pump to the fuel pump assembly, how does our aftermarket pumps stay secured in the fuel pump assembly? I just sent Chris an email to ask him his thoughts but I thought I'd pick your collective brains as well. How did everyone else do theirs?
dj2020 is offline   Reply With Quote
Fuel pump upgrade install (Visconti 290lph) jet86 DIY (Do-It-Yourself) Guides 44 01-04-2018 07:56 PM
PSA: Tips on what needs to be payed close attention on Fuel Pump install Sportsguy83 Engine, Exhaust, Transmission 34 04-25-2014 11:24 PM
Fuel pump issue. sevi21 Issues | Warranty | Recalls / TSB 13 02-01-2013 09:57 AM
Car fuel pump on... Genomaxter Engine, Exhaust, Transmission 5 11-29-2012 10:06 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
