Old 12-16-2013, 07:08 AM   #1989
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
Originally Posted by AirborneDeth View Post
I cant wrap my head around the whole backspacing thing for some reason. The lower the offset, say +30 instead of +48, equals more poke?
I would like to know if a square +30 backspaced 18x8.5 rims with 235/40/18 tires will sit flush...and if not what do I need to make it fit so? Will I need to roll the fenders more than they are from the factory?
As of now, the suspension is stock.
I am not looking for the 'hella' flush look either.
That will look something like this http://www.ft86club.com/forums/showp...1&postcount=75
I would not do it unless you lower the car aswell, as it will look offroadish otherwise -> http://www.ft86club.com/forums/showt...t=22222&page=5
If you're interessted in the basic calculations on how wheels and offset work, try this http://www.ft86club.com/forums/showp...&postcount=995
Killerbee is offline   Reply With Quote
Old 12-16-2013, 12:22 PM   #1990
*LongFella
*LongFella's Avatar
Drives: 2014 Scion FR-S|Whiteout
Will this fit?
Rim: 19x8.5 +45 (squared), back spacing = 6.44"
Tire: 235/35-19 (or is a 225/35-19 better)
Lowered about 1"-1.2"
Thanks!
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt
*LongFella is offline   Reply With Quote
Old 12-16-2013, 01:18 PM   #1991
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
Originally Posted by *LongFella View Post
Will this fit?
Thanks!
Yup you're more than good out back and a little closer up front but you'll still clear perfectly fine (assuming using lowering springs and not coils). You'll have plennnnty of room if you're running coilovers.
And I'd run the 235's over the 225's
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
Old 12-16-2013, 01:20 PM   #1992
*LongFella
*LongFella's Avatar
Sent from my HTC One using Tapatalk
Flush or a little sunk in?
Old 12-16-2013, 11:29 PM   #1993
AirborneDeth
Regular Guy
AirborneDeth's Avatar
Drives: '13 FRS '97 Jeep Cherokee
You have clarified my confusion. I finally understand the whole offset thing.
You sir, have a very nice looking 86. I usually don't like big wings, but it looks sexy on your vehicle. Not to mention, I would love to be in Germany again to cruise the Autobahn. I spent 1994-1996 in Wuerzburg. Sadly, I never made it to Switzerland. I am sure my future ex-wife lives there though!
AirborneDeth is offline   Reply With Quote
Old 12-17-2013, 01:28 AM   #1994
gabeg86
gabeg86's Avatar
Fronts will be fairly flush, but rear will be sunken in a bit. It's not going to be a lot, but won't be as flush as in the front. Most people run staggered (8.5 F and 9.5 R) because it makes the front and rear pretty even
Old 12-17-2013, 08:59 AM   #1995
*LongFella
*LongFella's Avatar
Thanks! I ran staggered on my last car (BMW). It looked great, but I like the idea of rotating and tire longevity these days :-)
Old 12-17-2013, 12:48 PM   #1996
gabeg86
gabeg86's Avatar
Yup I'm with you there! That's why I'm running 17x9 +38 57dr's front and rear
Old 12-17-2013, 01:35 PM   #1997
kjdd787
Drives:
Originally Posted by kjdd787 View Post
What's up guys I am wondering if 18x8.75 xxr 527's will fit with no coils but eibach sportline springs will these fit without any rub? Will I need camber? The come in an et 20 and et 35 I would like a bit of poke
So would this set up have both poke in the rear and front
Sent from my SCH-I545 using Tapatalk
kjdd787 is offline   Reply With Quote
Old 12-19-2013, 02:44 PM   #1998
*LongFella
*LongFella's Avatar
Which is more flush and fits (or not)?
18x8 +35 (sq)
255/35-18
Or
18x8 +45 (sq)
255/35-18
I'm liking the wider 255 tire, but not sure if it's too much and I should look at a 245? Thanks!
Old 12-19-2013, 02:53 PM   #1999
Killerbee
Killerbee's Avatar
18x8 +35 (sq)
255/35-18
Or
18x8 +45 (sq)
255/35-18
18x8 +35 (sq)
255/35-18
About flush
18x8 +45 (sq)
255/35-18
About 10mm tucked in
Not sure if the front will fit without coilovers, as you may have clearance issues with the struits/inner Fender
Old 12-19-2013, 03:05 PM   #2000
*LongFella
*LongFella's Avatar
18x8 +35 (sq)
255/35-18
About flush
18x8 +45 (sq)
255/35-18
So the +35 is the route to go with a 255 tire without rubbing the strut?
Old 12-19-2013, 03:32 PM   #2001
Killerbee
Killerbee's Avatar
With that wheel setup, yes
Old 12-19-2013, 03:37 PM   #2002
*LongFella
*LongFella's Avatar
Hopefully, the 255 doesn't look too massive and over power the 18x8 rim... LOL!
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
