Old 12-09-2013, 03:22 AM   #1975
ft86me
ft86me's Avatar
Drives: 2013 FRS
Originally Posted by Freshfrs86 View Post
Ok thanks! That does give me an idea though.
Oh and the camber! -1.3 front and -1.8 rear. Plenty of room with +44 and a good amount on the +38. Hope this helps!
ft86me is offline   Reply With Quote
Old 12-09-2013, 03:23 AM   #1976
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
Even better! @ft86me
Freshfrs86 is offline   Reply With Quote
Old 12-09-2013, 03:24 AM   #1977
ft86me
ft86me's Avatar
Drives: 2013 FRS
Good luck dude. Ask @RavSpec for fitment. Dude mark knows everything!!
Old 12-09-2013, 03:25 AM   #1978
Freshfrs86
Freshfrs86's Avatar
Drives: Scion FRS
Lol that is next
Old 12-15-2013, 12:43 PM   #1979
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
18x9.5 +45 wheels
Hankook Ventus V12 265/35 square (10.7" section width, 9.1" tread width which is about 0.5" to 1" narrower than other tires/more rounded shoulders)
Only concerned about the front: 1.25" coilover drop, -2.0 camber
Will the front rub the inner fender liner at full lock?
Old 12-15-2013, 06:29 PM   #1980
kjdd787
Drives:
What's up guys I am wondering if 18x8.75 xxr 527's will fit with no coils but eibach sportline springs will these fit without any rub? Will I need camber? The come in an et 20 and et 35 I would like a bit of poke
kjdd787 is offline   Reply With Quote
Old 12-15-2013, 06:51 PM   #1981
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
Everything would be fine. Ide just use 225/40s or 245/35s though. ET20s poke like crazy.
Old 12-15-2013, 08:02 PM   #1982
kjdd787
Drives:
If you were to take a guess how many mm of poke will there be and I would like slight camber but cannot afford it atm
Sent from my SCH-I545 using Tapatalk
Old 12-15-2013, 09:06 PM   #1983
AirborneDeth
Regular Guy
AirborneDeth's Avatar
Drives: '13 FRS '97 Jeep Cherokee
I cant wrap my head around the whole backspacing thing for some reason. The lower the offset, say +30 instead of +48, equals more poke?
I would like to know if a square +30 backspaced 18x8.5 rims with 235/40/18 tires will sit flush...and if not what do I need to make it fit so? Will I need to roll the fenders more than they are from the factory?
As of now, the suspension is stock.
I am not looking for the 'hella' flush look either.
AirborneDeth is offline   Reply With Quote
Old 12-15-2013, 09:16 PM   #1984
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
I honestly don't know how accurate this tool is but I play around on it pretty often.
http://www.frsproject.com/tire_size.php
Also
http://rimsntires.com/specs.jsp
Sent from SAMSUNG GALAXY NOTE. KEEP CALM AND CHIVE ON.
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Old 12-15-2013, 10:16 PM   #1985
AirborneDeth
Regular Guy
Depending on the margin of error, it looks like it will fit. Hopefully it does, because the rims I want only come in this offset. Thanks for the link, Flip.
Old 12-16-2013, 05:33 AM   #1986
FRSGeek
Drives: UltraMarine 6 Spd MT
I just had installed this week:
18x8.5/ET44 White RT5 Rota's on
245/35/18's Hankook V12's... So far all is nice, I am enjoying the ride and responsiveness in the handling.
They even poked out a tad more than I'd have suspected be ET44
'13 Ultra Marine 6MT:AVO Stg 1.5 T, Berk Tech Cat'd FP, Perrin OP & 2.5" cat back, WinMax W3F/W2R, 18x8.5et44 Rota, 245/35R18's, Drift-Office EcuTek Tune, Cusco Strt Twr & Rear brace and Grimspeed hood struts.
FRSGeek is offline   Reply With Quote
Old 12-16-2013, 06:57 AM   #1987
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
I run 18x8.75 +35 with 245/35/18, with eibach pro kit, and front pokes about 3-5mm, rear is about flush. +20 offsett will be another 15mm poke added to the above. Thats all with about 0° camber front and about 0.5° camber rear.
Pictures on stock suspension here (last two pics): http://www.ft86club.com/forums/showp...1&postcount=75
Pictures with eibach pro here (Pic nr 6): http://www.ft86club.com/forums/showp...&postcount=143
More pictures of this setup in my Car journal (see link in my sig)
Killerbee is offline   Reply With Quote
Old 12-16-2013, 07:01 AM   #1988
Killerbee
Killerbee's Avatar
Can you post a pic of that. In my book that setup should be flush/ a bit inside the fender. Just curious
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
