#183 |
Drives: Toyota 86 GTS
Compare EL and UEL maps from 2.06 and you'll see which tables are different.
#184 |
Drives: 86 EL full exhaust, takeda intake
You mean I then ignore those? That doesn't sounds right.
#185 |
The avcs tables are the only difference between headers and i haven't modified them.
#186 |
OK I see, so that means I can just copy all the tables right.
thanks so much |
#187 |
Drives: 2012 86
Noob in need of some help:
http://datazap.me/u/akyp/20150721-st...1&zoom=246-493 How can I get rid of the AFR fluctuation between 2200 and 3600 rpm? Looked at MAF scaling table and it's covered by all but 2 cells. Above 3600 rpm it seems good. The LTFT also seems too much. |
#188 | |
It looks like you have a MT with EL headers on petrol? |
| The Following User Says Thank You to Wayno For This Useful Post: | akyp (07-22-2015) |
#189 | |
Drives: 2012 86
Yes MT and I have P&L Motorsports 4-1 EL catted header and on crappy 98 RON. Been using OTS Stage 2 EL maps with neutered Base Timing B for a while, and not happy at all about the power. Now with v76 A01G MAF scaling it begins to feel better. What about the LTFT? Do I need to drive more than 20 mins (my home to where I did the WoT pulls) after flashing a new map, to give it time to settle down? Thanks again. |
#190 |
It's not so much how long you drive, it's how much you can drive above 2.2 MAFV while staying in closed loop, as to how long it takes to learn trims
#191 |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
#192 |
Fast enough
Drives: 2013 Subaru BRZ AT
Wayno, would the difference in power soley be a result of the cars running leaner? On the AT car I only see a difference of 0.5* of timing.
For the E85 NA cars with full bolt ons, what kind of timing are you finding optimal? I instinctively want to add more, but on E85 I feel it would be easy to overshoot MBT. My guess is the OTS maps for E85 already run quite close to optimal timing. |
#193 |
Which difference in power are you talking about exactly?
Don't go adding timing to e85 maps without a dyno. |
#194 | |
Fast enough
I haven't added any timing yet. I've leaned it out to about 12.5 gas equiv AFR on E85 from about 11.5 it was running with the OTS map. It feels MUCH stronger there. No knock. I need to get some good logs. I'll do that tomorrow. I want to make sure my head is on straight here though. Let's hypothetically take a car with only headers (rest of exhaust stock) running on E85 at a nice 12.5 AFR, at MBT timing, at say 4000 RPM. If you increase the VE by changing the entire rest of the exhaust out for a free flowing catless system, then you would need LESS timing to achieve MBT at the same RPM and AFR right? |
#195 |
I don't know. I haven't changed the timing for e85 at WoT because shivs timing is already at mbt. I only smoothed it and modified it at cruising speeds where it's now at stoichiometric.
AT generally hit different load columns than MT and that's why the timing would be different. |
#196 |
Drives: FR-S 10 #103 AT
Where are these tables?
- Engine Load Limiter A (NOTE: TABLE AXIS IS RESCALED, AT AND MT ARE DIFFERENT) - Engine Load Limiter B (NOTE: TABLE AXIS IS RESCALED, AT AND MT ARE DIFFERENT)
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
| Help uploading 2.06 tunes to OFT | Jimmy817 | Software Tuning | 3 | 12-28-2014 10:06 PM |
| Custom Az Tunes | Juggles | Arizona | 13 | 11-08-2014 11:15 AM |
| EcuTek Tunes | Rio | Engine, Exhaust, Transmission | 1 | 04-29-2014 01:10 AM |
| How long until *other tunes? | ScionFrsFan | Engine, Exhaust, Transmission | 61 | 12-07-2012 06:34 PM |
| Speedhunters - TRD TUNES THE 86 | quik1987 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 69 | 05-22-2012 05:26 PM |
