Old 07-21-2015, 12:39 AM   #183
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Compare EL and UEL maps from 2.06 and you'll see which tables are different.
Old 07-21-2015, 03:21 AM   #184
jcywong
Drives: 86 EL full exhaust, takeda intake
You mean I then ignore those? That doesn't sounds right.
jcywong is offline   Reply With Quote
Old 07-21-2015, 06:49 AM   #185
Wayno
Wayno's Avatar
The avcs tables are the only difference between headers and i haven't modified them.
Old 07-21-2015, 08:15 AM   #186
jcywong
OK I see, so that means I can just copy all the tables right.
thanks so much
Old 07-22-2015, 05:13 AM   #187
akyp
Drives: 2012 86
Noob in need of some help:
http://datazap.me/u/akyp/20150721-st...1&zoom=246-493
How can I get rid of the AFR fluctuation between 2200 and 3600 rpm? Looked at MAF scaling table and it's covered by all but 2 cells. Above 3600 rpm it seems good. The LTFT also seems too much.
akyp is offline   Reply With Quote
Old 07-22-2015, 08:09 AM   #188
Wayno
Wayno's Avatar
You can use some load limit tweaking. Basically when your engine goes over the load limit, the ECU will make the fuel much leaner. So if you lower the load limit in that area you should be able to get fuel into the correct ballpark while keeping the MAF scale smooth.
It looks like you have a MT with EL headers on petrol?
The Following User Says Thank You to Wayno For This Useful Post:
akyp (07-22-2015)
Old 07-22-2015, 09:20 AM   #189
akyp
Drives: 2012 86
Thanks. Ok didn't notice the load limit tables you added until now. Will modify my XML and give that a go.
Yes MT and I have P&L Motorsports 4-1 EL catted header and on crappy 98 RON. Been using OTS Stage 2 EL maps with neutered Base Timing B for a while, and not happy at all about the power. Now with v76 A01G MAF scaling it begins to feel better.
What about the LTFT? Do I need to drive more than 20 mins (my home to where I did the WoT pulls) after flashing a new map, to give it time to settle down? Thanks again.
Old 07-22-2015, 09:24 AM   #190
Wayno
Wayno's Avatar
It's not so much how long you drive, it's how much you can drive above 2.2 MAFV while staying in closed loop, as to how long it takes to learn trims
akyp (07-22-2015)
Old 07-22-2015, 09:33 AM   #191
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@Wayno @steve99
Thanks for all the details you guys have put up on this forum. Very helpful!!!!
I have recently just flashed the v79 tables on my Stage 1 B01D A/T tune.
Took a 45 km drive to work and I think the trims have finally learned and will report back (hopefully with some decent logs)
drewbot is offline   Reply With Quote
The Following 2 Users Say Thank You to drewbot For This Useful Post:
D_Thissen (07-22-2015), Lonewolf (07-23-2015)
Old 07-22-2015, 08:55 PM   #192
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
Wayno, would the difference in power soley be a result of the cars running leaner? On the AT car I only see a difference of 0.5* of timing.
For the E85 NA cars with full bolt ons, what kind of timing are you finding optimal? I instinctively want to add more, but on E85 I feel it would be easy to overshoot MBT. My guess is the OTS maps for E85 already run quite close to optimal timing.
xsnapshot is offline   Reply With Quote
Old 07-22-2015, 09:09 PM   #193
Wayno
Wayno's Avatar
Which difference in power are you talking about exactly?
Don't go adding timing to e85 maps without a dyno.
Old 07-22-2015, 09:22 PM   #194
xsnapshot
Fast enough
I am talking about those recent dyno's a couple posts up for the AT car. Seems to run about 33* up top vs 32.5* for OTS mapping.
I haven't added any timing yet. I've leaned it out to about 12.5 gas equiv AFR on E85 from about 11.5 it was running with the OTS map. It feels MUCH stronger there. No knock.
I need to get some good logs. I'll do that tomorrow.
I want to make sure my head is on straight here though. Let's hypothetically take a car with only headers (rest of exhaust stock) running on E85 at a nice 12.5 AFR, at MBT timing, at say 4000 RPM. If you increase the VE by changing the entire rest of the exhaust out for a free flowing catless system, then you would need LESS timing to achieve MBT at the same RPM and AFR right?
Old 07-22-2015, 10:11 PM   #195
Wayno
Wayno's Avatar
I don't know. I haven't changed the timing for e85 at WoT because shivs timing is already at mbt. I only smoothed it and modified it at cruising speeds where it's now at stoichiometric.
AT generally hit different load columns than MT and that's why the timing would be different.
Old 07-23-2015, 09:10 AM   #196
mid_life_crisis
Drives: FR-S 10 #103 AT
Where are these tables?
- Engine Load Limiter A (NOTE: TABLE AXIS IS RESCALED, AT AND MT ARE DIFFERENT)
- Engine Load Limiter B (NOTE: TABLE AXIS IS RESCALED, AT AND MT ARE DIFFERENT)
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
