Old 02-28-2014, 07:50 PM   #183
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Getting ready to do this on my car. along with a new LSD...
Bill
Scooby South is offline   Reply With Quote
Old 03-04-2014, 04:58 PM   #184
FrSleeper
Drives: Firestorm 6MT
So has anyone experienced problems with using a GL-4 synthetic trans fluid???
FrSleeper is offline   Reply With Quote
Old 03-04-2014, 07:53 PM   #185
roddy
roddy's Avatar
Drives: '13 Ultramarine
No. Most manual trans fluids are GL-4. GL-3 is actually an obsolete spec and hard to find. GL-5 is the one you want to avoid for use in the transmission.
Old 03-12-2014, 11:33 AM   #186
brad fischer
Drives: 2013 BRZ Premium Blue Manual
Someone asked what other cars had a similar Aisin transmission. The Genesis Coupe has a Aisin as well and has most of the same issues that I read hear. I have a 2010 Genisis bought in 2009 and a BRZ bought in 2013. 2nd gear cold shift difficult and occasional grind upshift to 2nd.
brad fischer is offline   Reply With Quote
Old 03-13-2014, 01:44 AM   #187
JB86'd
JB86'd's Avatar
Drives: JAWS
The exception to that is motul 300..which is gl-5 and gl-4
Old 03-13-2014, 02:48 AM   #188
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by rice_classic View Post
By the way, because of our awesome engine bay, you all realized that you can fill your tranny with a tube and funnel from above the car right?
Of course you did... using a pump from underneath the car would be silly. :wink:
Originally Posted by Kostamojen View Post
I filled with a tube from the top. But I still had to lift the car to drain it and get the plugs off and the skidplates off, all that jazz.
What diameter OD tube to fit the fill hole?
Old 03-13-2014, 06:36 AM   #189
roddy
roddy's Avatar
You're right, there are a few that have GL-4 and GL-5 ratings on the label. I should have mentioned that. My point though was to not use a full on GL-5 in the transmission.
Old 06-04-2014, 10:14 PM   #190
funbeatsfast
funbeatsfast's Avatar
Drives: '13 FR-S
I replaced the factory transmission oil at 5K miles. It was brown with a few shavings, but nothing that alarmed me. Put in Redline MTF. That felt a little better, but still had to 1-2 shift deliberately.
Of course I filled it from below, because I love pushing heavy oils through a fluid transfer pump for 30 minutes. Definitely not because I'm an idiot...
I read about Motocraft fluid on one of these threads, and remembered hearing about it from a Miata guy. I work for a Ford franchise, so decided I should give it a try. At 11K (early May) I put in 2.5 quarts of Motocraft XT-M5-QS GL-4. Cost $17 per qt with employee discount. Twenty something without.
It's awesome. Borderline magical. In less than a mile I could tell it was better than Redline MTF. Two auto crosses later it still feels great. In 5K more miles I'll buy 3 more qts of this stuff. I might buy them tomorrow just to have on hand. You should all go out and buy some too.
funbeatsfast is offline   Reply With Quote
Old 06-30-2014, 10:36 PM   #191
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Hey guys I wanted to update that I switch from pentosin to redline with 1 quart of shockproof. 5th gear grind is completely gone and its shifts like butter.
Rocket.BRZ is offline   Reply With Quote
Old 06-30-2014, 10:58 PM   #192
White64Goat
Which Redline products specifically? There are several in the trans fluid line and the Shockproof line. Thanks
Old 07-03-2014, 02:10 AM   #193
Rocket.BRZ
it was 75W90 NS GL-5 redline gear oil with 1 quart of lightweight shockproof.
fixed 2nd gear grind and my 5th to 6th grind. Shifts like butter much better than pentosin which was my last fluid.
(updated for more info)
Old 07-03-2014, 02:10 AM   #194
Rocket.BRZ
reply to your post is above.
Old 07-03-2014, 07:58 AM   #195
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
... so basically 40% of your tranny fluid is shockproof product correct?? Curious why you did this or rather how you came up with idea on the blend? Not too familiar with shockproof from RL and it's safe margins..
Old 07-03-2014, 08:34 AM   #196
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Isn't GL-5 the one that's bad for our tranny? Even if it seems to work, wouldn't it void your transmission warranty, since Subaru/Toyota only recommends GL-4?
xxBrun0xx is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
