#183 | |
Drives: Toyota 86 Turbo, Lexus NX300H
You can use 44mm-45mm with stock fuel system. -HKS supercharger V2 with 43.5mm -100 ron
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
#184 |
Drives: brz 2017 hksv2
Thanks
That afr is so because it is measured with an external sensor at the tail pipe? Or you can keep really that lean and then lower timings? |
#185 | |
Afr from o2 sensor is about 11.6-7
| The Following User Says Thank You to Yobiwan For This Useful Post: | tomm.brz (12-28-2018) |
#186 |
Drives: Manual 86 GTS
98RON Australia
Edelbrock SC Tomei UEL Headers Perrin 2.5 CB 1050 Injectors DW Fuel Pump Exedy Button Clutch Dyno Dynamics Dyno Would appreciate your thoughts on the torque/hp gains & curve. Does the tuning look right to those with expertise? Cheers. |
#187 |
Drives: 2013 BRZ Limited
Nice job! 👍
What conical filter is that? Do you have a model or part #?
#188 |
Drives: 2015 BRZ CWP
Brandon/byun
- Harrop w/85mm pulley - E60 - 13psi - Ace A350 header and Ace front pipe, stock catback - Very Hot day, 100f in the shop. Tuner: Zach CSG ![]() ![]() Sent from my iPhone using Tapatalk |
#189 |
Tuned by Pulse Racing
https://pulseracing.com.au/ Tweaked AVO, 8 psi, 2.5" overpipe, 2.5" resonated front pipe, stock cat back, stock fuel system, 98 RON Pre was from NA tune early March 19, pre had full 2.5" decated, and snorkel mod, from the original 115 kwatw it ended up making 145kwatw NA on 98 RON. Add turbo for another 60kwatw. Car is now WOW
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#190 |
Drives: Whiteout FRS
FI Dyno thread
FullBlown Stage 1 Turbo Kit
GTX3076R 1000cc Injectors 340lph AEM fuel pump 3in Turboback exhaust E85 (Stock Block) 341/300 @11psi 465/350 @16psi 512/392 @19psi (5200ft Elevation) ![]() ![]() Sent from my iPhone using Tapatalk Last edited by IRitzCrackerzI; 10-11-2019 at 02:22 PM. |
#191 |
Wes
man you're brave doing those pulls on a stock block!
Instagram: @gt86ws
#192 | |
Have faith in your tuner. I’ve been running it at 19psi for the past year. It’s not a daily driver but when it does leave the garage it gets used and abused. It won’t last forever, but hopefully long enough to get a built block and heads in. Sent from my iPhone using Tapatalk |
#193 | |
Wes
Instagram: @gt86ws
#194 | |
I maybe a little bias. I would go with FULLBLOWN Motorsports Kit. The kit shipped fast, and they were more than happy to assist on any questions i had. I’ve assisted installing multiple kits(RP400, FBM, JDL, AVO) FBM has had little to no problems and was the easiest to install. I haven’t had any problems at all. I would recommend you talk to LJ at FBM. He is super knowledgeable on what setup would suit your needs and he gives some killer deals. Sent from my iPhone using Tapatalk |
| The Following User Says Thank You to IRitzCrackerzI For This Useful Post: | StraightOuttaCanadaEh (10-11-2019) |
#195 |
Rust bucket enthusiast
Stock exhaust
Cxracing manifold and intercooler Cxracing $120 basic T3/T04e journal bearing turbo .60ar 440cc stock WRX injectors ECUtek w/Racerom using full closed loop fueling on speed density. 10psi increasing to 15 by redline for a smooth powerband. ![]() With UEL headers, catless frontpipe and a dynotune with ECUtek before it made this on the same dyno at around the same air temp-
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Joveen (11-14-2019) |
#196 |
Drives: 86
JDL V2 UEL Manifold, GTX2860R, Recirculated
93 octane 7 psi 2.5'' JDL Ultraquiet frontpipe/overpipe combo, MXP SP Catback James at HRI [ame]https://www.youtube.com/watch?v=vhUrT0GLctw[/ame]
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Bolt-ons dyno comparisons thread? | seven | Engine, Exhaust, Transmission | 6 | 11-25-2012 11:28 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
