Old 12-28-2018, 04:59 PM   #183
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
Originally Posted by tomm.brz View Post
Cool happy for You
I m waiting to install the hks v2 (the new one with black housing arrived to me last week) with 44mm
Can you please post the dyno of Your hks kit You had here for me? Are those wheel hp right?
Yes whp.
You can use 44mm-45mm with stock fuel system.
-HKS supercharger V2 with 43.5mm
-100 ron
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 12-28-2018, 06:15 PM   #184
tomm.brz
Drives: brz 2017 hksv2
Thanks
That afr is so because it is measured with an external sensor at the tail pipe? Or you can keep really that lean and then lower timings?
Old 12-28-2018, 07:41 PM   #185
Yobiwan
Yobiwan's Avatar
Thanks
Afr is from external sensor at tail pipe.
Afr from o2 sensor is about 11.6-7
The Following User Says Thank You to Yobiwan For This Useful Post:
tomm.brz (12-28-2018)
Old 07-10-2019, 02:29 AM   #186
madpir8
madpir8's Avatar
Drives: Manual 86 GTS
98RON Australia
Edelbrock SC
Tomei UEL Headers
Perrin 2.5 CB
1050 Injectors
DW Fuel Pump
Exedy Button Clutch
Dyno Dynamics Dyno
Would appreciate your thoughts on the torque/hp gains & curve.
Does the tuning look right to those with expertise?
Cheers.
madpir8 is offline   Reply With Quote
Old 08-23-2019, 11:28 PM   #187
Suparu
Drives: 2013 BRZ Limited
Originally Posted by xwd View Post
Nice job! 👍
What conical filter is that? Do you have a model or part #?
Suparu is offline   Reply With Quote
Old 08-24-2019, 01:05 AM   #188
byun
byun's Avatar
Drives: 2015 BRZ CWP
Brandon/byun
- Harrop w/85mm pulley
- E60
- 13psi
- Ace A350 header and Ace front pipe, stock catback
- Very Hot day, 100f in the shop. Tuner: Zach CSG
byun is offline   Reply With Quote
Old 09-06-2019, 03:41 AM   #189
86MLR
86MLR's Avatar
Tuned by Pulse Racing
https://pulseracing.com.au/
Tweaked AVO, 8 psi, 2.5" overpipe, 2.5" resonated front pipe, stock cat back, stock fuel system, 98 RON
Pre was from NA tune early March 19, pre had full 2.5" decated, and snorkel mod, from the original 115 kwatw it ended up making 145kwatw NA on 98 RON.
Add turbo for another 60kwatw.
Car is now WOW
Old 10-11-2019, 12:01 PM   #190
IRitzCrackerzI
IRitzCrackerzI's Avatar
Drives: Whiteout FRS
FI Dyno thread
FullBlown Stage 1 Turbo Kit
GTX3076R
1000cc Injectors
340lph AEM fuel pump
3in Turboback exhaust
E85
(Stock Block)
341/300 @11psi
465/350 @16psi
512/392 @19psi
(5200ft Elevation)
IRitzCrackerzI is offline   Reply With Quote
Old 10-11-2019, 12:12 PM   #191
StraightOuttaCanadaEh
Wes
GTX3076R
1000cc Injectors
E85
(Stock Block)
341/300 @11psi
465/350 @16psi
512/392 @19psi
man you're brave doing those pulls on a stock block!
Instagram: @gt86ws
Old 10-11-2019, 12:15 PM   #192
IRitzCrackerzI
Have faith in your tuner.
I’ve been running it at 19psi for the past year. It’s not a daily driver but when it does leave the garage it gets used and abused. It won’t last forever, but hopefully long enough to get a built block and heads in.
Old 10-11-2019, 12:22 PM   #193
Wes
Mine is dailied all year round (keeping in mind extreme temperature variations here in Canada) and I would rather avoid the expense of having to swap the block, but the tuner I'll be going to is seemingly extremely capable, so hopes are high. Just have to decide on which FI product to go with.
Instagram: @gt86ws
Old 10-11-2019, 12:36 PM   #194
IRitzCrackerzI
I maybe a little bias. I would go with FULLBLOWN Motorsports Kit. The kit shipped fast, and they were more than happy to assist on any questions i had. I’ve assisted installing multiple kits(RP400, FBM, JDL, AVO) FBM has had little to no problems and was the easiest to install. I haven’t had any problems at all. I would recommend you talk to LJ at FBM. He is super knowledgeable on what setup would suit your needs and he gives some killer deals.
The Following User Says Thank You to IRitzCrackerzI For This Useful Post:
StraightOuttaCanadaEh (10-11-2019)
Old 11-14-2019, 03:25 PM   #195
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Stock exhaust
Cxracing manifold and intercooler
Cxracing $120 basic T3/T04e journal bearing turbo .60ar
440cc stock WRX injectors
ECUtek w/Racerom using full closed loop fueling on speed density.
10psi increasing to 15 by redline for a smooth powerband.
With UEL headers, catless frontpipe and a dynotune with ECUtek before it made this on the same dyno at around the same air temp-
Joveen (11-14-2019)
Old 12-29-2019, 06:18 PM   #196
Steveiam
Drives: 86
JDL V2 UEL Manifold, GTX2860R, Recirculated
93 octane
7 psi
2.5'' JDL Ultraquiet frontpipe/overpipe combo, MXP SP Catback
James at HRI
[ame]https://www.youtube.com/watch?v=vhUrT0GLctw[/ame]
Steveiam is offline   Reply With Quote
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Bolt-ons dyno comparisons thread? seven Engine, Exhaust, Transmission 6 11-25-2012 10:28 PM
Base line dyno figure (dynapak Hub dyno) gtauto AUSTRALIA 16 10-08-2012 08:06 AM
