#183 |
Senior Addict
Drives: 86 GT
The part numbers for the door panel knee pads, those are the padded type with red stitching yes?
#184 |
Drives: 2013 Scion FR-S Raven
Thank you for the DIY, and a special thank you to JPM Coachworks for the parking brake boot and the Kneepads.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#185 |
Poor College Kid
Drives: ~.~
Looks nice
#186 |
Dances with Cones
The part numbers I posted above are for the synthetic leather with red stitch...aka, the "JDM" ones that everyone wants. These come standard on the 2014's, so they can be ordered from your local dealer using the numbers above.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
#187 |
Drives: 2013 FR-S Ultrmarine MT
For Center Console Knee-pad & Armrest Installation - Simultaneously - Remove the Console, then Drill for Armrest Installation.
You actually get to the point where the console is nearly loose anyway to install the knee-pads, so just 4 more screws around the base of the gear shifter + 2 more larger screws at the bottom of the console below the arm rest cavity and the console comes out free and clear. Once the console is out as one large piece of plastic, adjusting the template fit conveniently, drilling the console perimeter accurately, cleaning the drilled holes thoroughly, then setting and re-installing the armrest is a much easier process than doing it when the console is still wedged between seats in the car. You save considerable time and effort on installing the Armrest, once you pull the console out as part of installation process for the knee-pads. Sorry, I did not take photos, but it was a very clean and smooth installation that way. Last edited by Zagmeister; 09-04-2013 at 02:51 PM. |
#188 |
Drives: 2016 WRX Limited
Does anyone know how to access the bottom screws of the center console in a limited with the dual climate control? I can't figure out if the whole piece pops out or not but I'm not about to pry on it to find out..
#189 |
Drives: Ultramarine 86 - 6MT
Do people get bloody knees while driving this car or something? :0
#190 |
Yes
#191 |
Snow Don't Hurt!
#192 | |
Drives: 13 Whiteout
Sent from my yotaru
2013 Scion FR-S (Whiteout) GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned. Less parking more racing |
#193 |
Damn I should start test "crash" driving my car from now on. Apparently I am missing out on a number of thrills and hooker encounters... :[
#194 |
Drives: BRZ Limited
so you need to buy this in order for the knee pads to work ?
http://www.ebay.com/itm/TOYOTA-JAPAN...37c6f0&vxp=mtr |
#195 |
Senior Addict
Drives: 86 GT
If you want to install the padded door kneepads....then yes.
#196 | |
Drives: FR-S 10 #103 AT
So who has the best prices online?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
| Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR | nigel-jdmparts | Interior Parts (Incl. Lighting) | 89 | 02-01-2013 04:00 PM |
| HID Retrofit Kit install | Jidonsu | NY / NJ / CT / PA | 1 | 08-04-2012 01:24 AM |
| How do you install the mud guards? | Moshpit37 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-27-2012 11:13 PM |
| FS: console knee foam pads | 86_ZN6 | Interior Parts (Incl. Lighting) | 9 | 07-21-2012 09:46 AM |
| Spoiler Install | CharlieChaos | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-07-2012 10:43 AM |
