#169 |
Snow Don't Hurt!
Ah thanks! You're right. When I opened it up I knew I needed more than one, so when I ordered them from the dealership and was quoted less than a buck each I excitedly ordered a few just in case. I went off my erroneous memory after I installed the screws needed. I appreciate the correction!
#170 |
86 Owners of New England
Drives: Toyota GT86
where is the cheapest place to buy the Speaker Grills and the Rings? Nigel is $130.
Any help would be great. I have the speaker panels already Thank you |
#171 | |
1337
Drives: 2013 BRZ WRB S/C
I ordered mine from www.japanparts.com, they shipped very quickly and price was good. Not sure if it's better or worse than Nigel, just another option for you. |
| The Following User Says Thank You to djdnz For This Useful Post: | AG3NT_5CARFAC3 (08-22-2013) |
#172 | |
Drives: Toyota GT86
#173 |
Shorter of breath
Drives: a soft bargain
The japanparts site has the part numbers; there's a 'kit' under Subaru interior (other) that has all three pieces, and lists the part numbers for each.
#174 |
Dances with Cones
Drives: 2013 Scion FR-S Raven
I just ordered these from Toyota. Much easier since they are standard on the 2014's now.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD |
#175 | |
Drives: 13 BRZ Limited 6MT GBS
Reach behind the start button trim piece, and pop out the USB/Aux ports. It's a single rectangular assembly, and it pops out if you push it from behind. Once it pops out, pull it forward an inch or two, there's enough slack on the cable. Now, stick your finger in the hole for the USB/Aux port, and just pull the whole trim piece out. It took me 45 minutes of frustration following the DIY guides to figure it out, but once you know that trick, it's a piece of cake. I can have it apart in 10 seconds now.
| The Following User Says Thank You to nalc For This Useful Post: | Kimsey47 (08-23-2013) |
#176 | |
I've been thinking that I needed to wait til 2014 deliveries start in November to order the new parts from my dealership or a US parts website.
#177 | |
Drives: 2016 STI DGM
Subaru STI :![]() |
#178 | |
Subaru STI :![]() |
| The Following User Says Thank You to Kimsey47 For This Useful Post: | nalc (08-26-2013) |
#179 |
No rice, no life
Drives: 2013 Asphalt FR-S
We should rename this thread to "2014MY conversion"
#180 |
Shorter of breath
#181 |
Senior Addict
Drives: 86 GT
Does anyone know the part numbers for the door knee pads + grille cover + silver grille rings?
#182 | ||
Dances with Cones
(LH) SU003-04437 (RH) SU003-04436 Centre Console Knee Pads: (LH) SU003-01920 (RH) SU003-01919 Speaker Grilles: (LH) SU003-04433 (RH) SU003-04432 Speaker Grille Trim Rings: (LH) SU003-03287 (RH) SU003-03286 Speaker Grille Screws (Required for Installation of Pads): SU003-02917 (x6) You need all of the above to complete installation...well, that is if you want both the console and the door pads for both sides...
| The Following 6 Users Say Thank You to that_guy For This Useful Post: | bedabi (07-15-2015), chanomatik (08-31-2013), ethan160222 (08-18-2016), Fizz (08-31-2013), mx5 2nr (05-14-2014), unsurety (06-23-2014) |
| Toyota Japan 86, FRS, Air Bag, Frameless Mirror, Knee Pad, Sun Visor, Door sill, MOR | nigel-jdmparts | Interior Parts (Incl. Lighting) | 89 | 02-01-2013 05:00 PM |
| HID Retrofit Kit install | Jidonsu | NY / NJ / CT / PA | 1 | 08-04-2012 02:24 AM |
| How do you install the mud guards? | Moshpit37 | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 07-28-2012 12:13 AM |
| FS: console knee foam pads | 86_ZN6 | Interior Parts (Incl. Lighting) | 9 | 07-21-2012 10:46 AM |
| Spoiler Install | CharlieChaos | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-07-2012 11:43 AM |
