Old 06-02-2020, 01:26 AM   #18453
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
how do we convince the rest of the population to start using clear bra's?
Show by example!
MS, CSCS, TSAC-F, CPT
The Following User Says Thank You to weederr33 For This Useful Post:
NoHaveMSG (06-02-2020)
Old 06-02-2020, 02:22 AM   #18454
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
Originally Posted by Stephen W. View Post
I'm sorry, I know I'm old and not as bright as I once was but... You have a 2018 BRZ with what looks to be the exact same head unit that is in my tS. That unit comes with Apple CarPlay and Android Auto. So, why the need for the phone dash mount?
Kenwood looks good and if you like it better than that's money well spent for you. However, I fail to see why you'd change when the stock unit does the same thing.
Does the one piece dash trim have the same size cutout as the stock piece? I installed an aftermarket 6.95in Sony AX5000 and had to get a bracket to fill the gaps. Looks a lot cleaner with your one piece!
Oxyg3n is offline   Reply With Quote
Old 06-02-2020, 02:31 AM   #18455
BA9092
Captain Slow
BA9092's Avatar
Drives: '18 BRZ Limited PP 6MT ISM
The single piece dash trim has the cutout to accommodate the 200mm head units without the need for the side brackets to fill the gaps. But you must search for the 200mm head units specifically if you don't want to use the brackets.
BA9092 is offline   Reply With Quote
The Following User Says Thank You to BA9092 For This Useful Post:
Oxyg3n (06-02-2020)
Old 06-02-2020, 02:43 AM   #18456
whiskeyfox
Drives: 2015 BRZ
installed coilovers and 18x9.5 +38 ambit wheels with nankang NS-25 265/35/18 tires. rides way better than my old setup can't believe it was $900 for the wheels and tires. rides better than my stock suspension with some bridgestone tires. need an alignment but honestly can't tell while driving. drives straight and no change from before I installed the coilovers....probably have some messed up toe or something though.
whiskeyfox is offline   Reply With Quote
Old 06-02-2020, 05:21 AM   #18457
ItsReiko
ItsReiko's Avatar
Drives: 2017 subaru brz
Ended up also swapping in the STI push to start button I bought in Japan last month (excuse the dust.. I just aircan sprayed it last week ):
Do you feel this piece was worth the high price? Also do you know which model you got? There are close to 6 different ones on ft86speedfactory and they all look basically the same but some has a status light and others do not.
Been tempted to get this for a long time..
ItsReiko is offline   Reply With Quote
Old 06-02-2020, 08:23 AM   #18458
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
Got mine for ~$96 shipped from a dealer. Should have seen if my dealer would price match another and got it for $85.
83031CA023
dragoontwo is offline   Reply With Quote
The Following User Says Thank You to dragoontwo For This Useful Post:
ItsReiko (06-02-2020)
Old 06-02-2020, 10:16 AM   #18459
grumpysnapper
grumpysnapper's Avatar
Ive got two sets of Rays CE 28 (16 x 7 J+33) , one set is powder coated in a titanium finish, but my favourite now is these that have just arrived back....
grumpysnapper is offline   Reply With Quote
The Following 3 Users Say Thank You to grumpysnapper For This Useful Post:
MJones_RB (06-02-2020), new2subaru (06-09-2020), soundman98 (06-03-2020)
Old 06-02-2020, 12:56 PM   #18460
MotoX16
MotoX16's Avatar
Drives: 2017 Subaru BRZ
Installed a GrimmSpeed pulley cover and strut bar, also got a new catch can filter
2017 Subaru BRZ PP
FBM Turbo Kit: GTX3076R - HRI FlexFuel Tune - 3" Turboback Exhaust - ID1000cc Injectors - Walbro 485 Fuel Pump - FBM Oil Pan - FBM Oil Cooler - Killer B Oil Pickup - FBM Catch Can - FBM Radiator w/Fan Shroud - Clutch Masters FX400 - Verus Clutch Fork/Pivot - IRP Shifter - Cusco Engine/Trans Mounts - RCE Yellow Springs - PS4S 245/40/17
MotoX16 is offline   Reply With Quote
The Following User Says Thank You to MotoX16 For This Useful Post:
Old 06-02-2020, 02:58 PM   #18461
ItsReiko
ItsReiko's Avatar
83031CA023
Wow that is quite a bit cheaper than what is found on Ft86speedfactory. Is it the same product? I noticed your product code leads me to information saying it is only compatible with 2018-2020 cars, but I would think nothing has changed in the model years as far as the push button goes. And on ft86speedfactory the item code is SOA31CA023.
Do all the wordings on your button light up as well?
Old 06-02-2020, 03:12 PM   #18462
dragoontwo
dragoontwo's Avatar
I suspect it should be the same as all models. The words do light up. It looks to me like they replaced the first 3 numbers of the part number I gave with SOA. Ignore the shift knob.....
Old 06-02-2020, 03:16 PM   #18463
BA9092
Captain Slow
BA9092's Avatar
Washed it and went for a drive. Then updated my FB cover photo with a new pic.
The Following 5 Users Say Thank You to BA9092 For This Useful Post:
MotoX16 (06-02-2020), tintumz22 (06-03-2020), weederr33 (06-02-2020), wolffbite (06-03-2020), x1UP (06-03-2020)
Old 06-02-2020, 03:19 PM   #18464
CBRZY
CBRZY's Avatar
Drives: 2017 BRZ PP (White)
Today I took it to a repair shop because I heard a clunking noise while braking at low speeds.
Not the most exciting thing, but it's a thing.
CBRZY is offline   Reply With Quote
Old 06-02-2020, 04:00 PM   #18465
MotoX16
MotoX16's Avatar
Looks great! What lip kit are you running? Also wondering what spacers youre using on them stock wheels?
2017 Subaru BRZ PP
Old 06-02-2020, 04:33 PM   #18466
BA9092
Captain Slow
BA9092's Avatar
Thank you!
I'm running the Bayson R MPX lip and 20mm H&R Trak+ spacers all around.
