#169 | |
Drives: 2013 Scion FR-S Ultramarine
Not trying to be a ****, I'm genuinely curious if this is something that any of us can reasonably expect to encounter in a performance application or if this is something thats mathematically possible but very unlikely given our platform.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
| The Following User Says Thank You to Xinshadow For This Useful Post: | cdrazic93 (02-18-2015) |
#170 |
Drives: frs
Golly this is a fun read!
#171 | |
Junior
Drives: a car
You are 100% more likely to twist the shaft from the resulting torque of the motor, or break the transmission. When a driveshaft reaches critical speed; it reaches the natural frequency of the material it's made out of, making it unbalanced and you will quickly lose control of the car. Not something you want to have happen at that critical speed. Folks who engine swap or build the piss out of this car end up replacing the stock unit with a stronger one anyway (in this case, a faster spinning one).
Last edited by cdrazic93; 02-18-2015 at 12:31 AM. Reason: Mathematically possible, highly unlikely |
#172 | |
Junior
Drives: a car
Bu....but the guys on hondatech said....
| The Following 3 Users Say Thank You to cdrazic93 For This Useful Post: |
#173 |
Junior
Drives: a car
Oh, he let em have it alright.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | Koa (02-18-2015) |
#174 |
Because compromise ®
Drives: Red Herring
Acceleration ∝ mass of shit.
#175 | |
Junior
Drives: a car
#176 |
Kuruma Otaku
Err...
I did his big formula comparing the baseline 2800lbs (1272kg) to 100 mph (44.8 m/s)(I got 1279866.76 J total of system plus driveshaft and 79004.12 J/sec) vs a 15 lbs driveshaft reduction so 2785 lbs (1265.9kg) (1272059.76 system plus driveshaft). 1272059.76/79004.12 = 16.101 sec. One millisecond shy of an entire tenth. That seems like a big difference, and more significant than your 44 milliseconds zero mass driveshaft. What's wrong with my math? Edit: Would that be just over an entire car length ahead (174 inches)?
Because titanium. Last edited by Dimman; 02-18-2015 at 02:01 AM. Reason: edit |
#177 | |
Like at work, I just enjoy sitting back and letting the engineers argue and then tell the winner he can't do what he wants anyway since the ROI is under 2 years!
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (02-18-2015) |
#178 | |
Drives: Raven Black
Go back and read all my posts in this thread, and tell me I am wrong about anything. Please do.Again, my point was simply that one is better than the other when considering an equal amount of weight.... Put it in the perspective of the racing community. Do they all ignore reducing rotational mass because its effects are minimal? No. In the racing world milliseconds count, and racing teams like to add all these milliseconds up so that they may have the best advantage. I really hope that we can all just get along... When I say it is "clear-cut-obvious" I am talking about the physics of it, not the butt dyno feel of the drive shaft. Take two completely stock cars, made the EXACT same, all conditions are the exact same, all variables are the exact same, the driver input is the exact same, but, reduce the over all weight of one car by 15lbs, and then put a driveshaft in the other car that is 15lbs lighter. Put them in a 1/4 mile drag race. The one with the light weight drive shaft wins every time. Even if you have to measure the win by nanometers, it still wins every time. Am I missing something here? And the 600rr is a blast
#179 | |
Add lightness!
Drives: 17' WRX
#180 |
Drives: 2018 BMW M240i
An easy real world test that any of us can do to help better understand rotating mass, weight, circumference, etc..
Go to your local playground (must be one with a merry-go-round). Now you can spin it yourself and hop on or have a friend spin it while you are on it. The merry-go-round when spinning is rotating around in a circle. Start out at the very center. As the merry-go-round is spinning slowly try and work your way out from the center to the edge. Note how in the center you feel little if any forces pulling you out toward the edge. As you work your way out towards the edge not how the forces gradually then rapidly increase. If your friend is spinning the merry-go-round he should notice as you work your way to the edge it requires more force to keep the merry-go-round rotating at the same speed. It may not be a perfect test but it is an easy one to see the correlation between the mass and relationship to the center/perimeter of rotation. The point of the test is to show how even at the same weight there is a significant difference in the amount of force required to rotate something as weight moves from the center to the perimeter. Another valid test is to spin the merry-go-round with nothing on it. Then have someone stand dead center on the merry-go-round and spin it. You will be surprised to notice that it requires very close to the same amount of force to spin it with someone on the merry-go-round as with someone off even though there is a big difference in weight. |
#181 | |
Worth of expenditure and 'feel' are subjective. Physics and the laws of motion are not. Notice we're not saying the 15 pounds savings isn't worth ANYTHING. We're saying the cost per benefit is absurd for something that Rrealistically cannot be felt by those who are incapable of feeling the power increase that amounts to 44 milliseconds through a typical 0-100 run. That is an opinion. Definitely. So there's that... you can indeed prove with mathematics what nature PROVES of this mod's worth. The real issue is that you come here saying you can actually feel a performance gain because unless you're a superhuman capable of feeling 44 milliseconds throughout a 0-100 run, you are just placebo tricking your mind. Probably NVH. There's that. Come back with some "real world" track data to back up your claims and prove us, including physics, wrong. That you really won the race against yourself at the end of the day. -- Here's the fatal blow to your position: A FUNDAMENTAL grounding principle of the scientific method: If the trial is not able to control all variables, which in this case would be driver error, it is no good. Show me a driver that is consistent to less than 100 milliseconds and I'll show you a liar. Prove me wrong in this. THEREFORE, With such a minuscule gain, this is an untestable claim that the driveline provides a perceived, "felt", benefit. Facts only become facts after artefacts and claims are subject to trials of strength, by various actors and laboratories and anti-laboratories. Only after the fact-to-be is able to be championed by those willing to test the claim, and survive the onslaught of trials of strength (testing), can the artefact become a FACT. Then, the fact can be altered and moved 'downstream' via positive modalities, or called out via negative modalities. Those are important themes to what's happening here. You're taking a fact that this type of reduction produces a gain, NO MATTER HOW MINISCULE, and moving that forward, via a positive modality, to "one is able to feel this gain throughout the driving experience- not just an increase of NVH, but an actual felt increase in power". Bruno Latour, father of the discipline Science and Technology Studies, an increasingly important scientific discipline under the STEM cirricula, wrote at length about this in his landmark 1984 work, "Science in Action". I recommend you read this to understand the absurdity of your claims of real-world versus conceptual facts surrounding this case. Conceptually, it's un-perceptible. It is supported by hundreds of years of scientific studies that humans' margins of errors in time tests exceed the milliseconds we're talking about here. Does that not ring a bell for you? Because that's a VERY important part of this discussion. Can't argue with the scientific method. |
#182 | |
Add lightness!
Drives: 17' WRX
| The Following User Says Thank You to industrial For This Useful Post: | Koa (02-18-2015) |
| Lightweight aluminum drive shaft installed. | stockysnail | Northwest | 18 | 02-05-2020 12:18 AM |
| Driveshaft Shop Aluminum Drive Shaft. | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 40 | 10-15-2015 10:11 PM |
| Invidia N1 interference with Driveshaft Shop aluminum shaft. | xkalelx | Engine, Exhaust, Transmission | 6 | 03-03-2015 10:43 AM |
| Scion FR-S / Subaru BRZ Drive Shaft Shop Carbon Fiber Drive Shafts In Stock | Anthony@RWHP | Transmission and Driveline | 4 | 12-25-2013 09:09 PM |
