11-07-2014, 12:26 PM | #169 |
Drives: Toyota
If Cosworth is overpriced, what about Volk Racing? Can't you get cheaper wheels no worse? Why the hate against Rota?
Pathetic. |
The Following User Says Thank You to Levi For This Useful Post: | illmatic (11-08-2014) |
11-07-2014, 02:43 PM | #170 |
Drives: GT86 Cosworth
I don't have the sprintex but I have witnessed the issue demonstrated. The person whom demonstrated the issue also helped develop the kit.
The original sprintex tune I believe doesnt measure intake air temps (charged temps) so heaven knows how hot the IATs are getting. The sprintex kits in the uk are using a map sensor with temp sensor. The tune pulls timing before IATs get to 70C. Its fact not an assumption. Twin screw sc are less efficient and generate more heat which is properly why the cosworth kit has two large (bigger than sprintex) heat exhangers in the intake manifold to stop the intake temps getting damagingly high on track. I was set on the kraftwerks as the centrifugal SCs don't increase charge temps significantly but this cossy kit my have swayed it for me. Cost are very similar here in the uk. This cossy kit is running at 70% capacity so it look like this has been engineered for higher power but probably requires internals and oiling changes. |
The Following User Says Thank You to ajc209 For This Useful Post: | stonenewt (11-08-2014) |
11-07-2014, 02:45 PM | #171 | |
Drives: 2018 BMW M240i
Rota's are not a rebrand of Volks they are an entirely different wheel made to look like a Volk. Part of the Cosworth packages are other manufacturer parts rebranded and not something they manufactured themselves. So not a equivalent comparison. |
11-07-2014, 02:55 PM | #172 |
Drives: 2013 Raven Black FRS
11-08-2014, 02:03 AM | #173 |
Just a dude
Drives: Scion FR-S 2013
So.....question is...
What vendor or person is getting this kit to provide some real data??
11-08-2014, 04:34 AM | #174 |
Drives: BMW 120d
^^ This A quick search comes with the following prices (to the nearest £50)
Cosworth - £4800 + £550 fitting Sprintex Stage 2 - £5200 inc fitting Litchfield SC - £4200 + fitting I couldn't quickly find fitting costs for the Sprintex & Litchfield setup. This is important because the Litchfield is using a centrifugal (rotrex) supercharger, it should be cheaper on parts but more complicated, thus expensive, to install. |
11-08-2014, 11:58 AM | #175 | |
Drives: toyota mr2/ Toyota GT86
its a funny thing isn't it? a reputable company posts results for their product using a calibrated dyno that uses air conditioned air to to feed the engine, controls the fluid temperatures to ISO standards and holds everything at a steady state to allow the power figures to settle and provide repeatable results but this isn't 'real' data unless its a quick blast up a set of rollers with no fluid temperature control, and no means of correcting air temperature and god knows what standard the rollers are calibrated to those are the results we believe.... Last edited by 350matt; 11-08-2014 at 12:02 PM. Reason: correction |
The Following User Says Thank You to 350matt For This Useful Post: | qqfob (11-08-2014) |
11-08-2014, 12:15 PM | #176 | |
Just a dude
11-08-2014, 12:43 PM | #177 | |
All numbers published by Cosworth are on 93 octane (MON+RON)/2 |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | mokinbird87 (11-11-2014), OICU812 (11-08-2014) |
11-08-2014, 01:23 PM | #178 | |
Lacking brains
Drives: frz
more "complicated" and thus more labor intensive than removing the intake manifold and all that process entails? bumper is being pulled for the ic either way far as i know. |
11-09-2014, 02:54 AM | #179 |
Just a dude
What's official (spill the beans day) on this other (LARGE) company developing another FI solution for the twins??
11-09-2014, 06:45 AM | #180 |
11-09-2014, 02:05 PM | #181 |
Drives: Volvo S60R
11-09-2014, 02:35 PM | #182 |
So any more detail on what the S/C model and capacity is? I'm still guessing the Eaton TVS900.
Wish I could buy just the heat exchanger, it's actually quad-pass which isn't something you see in off the shelf applications, not to mention it bolts right up to the car. Maybe one of the dealers can get ahold of just one of them. http://www.cosworth.com/products/pow...ture-radiator/ |
Similar Threads | ||||
Cosworth FA20 Stage 1 Power Package | DaDr00 | Engine, Exhaust, Transmission | 84 | 06-10-2016 03:02 AM |
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! | RallySport Direct | Engine, Exhaust, Bolt-Ons | 104 | 07-02-2015 10:10 AM |
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! | FullBlown | Forced Induction | 119 | 03-24-2015 10:16 PM |
Stage 1.1 Cosworth FRS | FR-S89 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 12-22-2014 01:23 PM |
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 | Astroboy | Forced Induction | 4 | 03-01-2014 07:29 PM |
