Old 11-07-2014, 12:26 PM   #169
Levi
Drives: Toyota
If Cosworth is overpriced, what about Volk Racing? Can't you get cheaper wheels no worse? Why the hate against Rota?
Pathetic.
Levi is offline   Reply With Quote
Old 11-07-2014, 02:43 PM   #170
ajc209
Drives: GT86 Cosworth
I don't have the sprintex but I have witnessed the issue demonstrated. The person whom demonstrated the issue also helped develop the kit.
The original sprintex tune I believe doesnt measure intake air temps (charged temps) so heaven knows how hot the IATs are getting. The sprintex kits in the uk are using a map sensor with temp sensor. The tune pulls timing before IATs get to 70C. Its fact not an assumption.
Twin screw sc are less efficient and generate more heat which is properly why the cosworth kit has two large (bigger than sprintex) heat exhangers in the intake manifold to stop the intake temps getting damagingly high on track.
I was set on the kraftwerks as the centrifugal SCs don't increase charge temps significantly but this cossy kit my have swayed it for me.
Cost are very similar here in the uk.
This cossy kit is running at 70% capacity so it look like this has been engineered for higher power but probably requires internals and oiling changes.
ajc209 is offline   Reply With Quote
Old 11-07-2014, 02:45 PM   #171
tennisfreak
Drives: 2018 BMW M240i
Pathetic.
Well your example is not a good one.
Rota's are not a rebrand of Volks they are an entirely different wheel made to look like a Volk.
Part of the Cosworth packages are other manufacturer parts rebranded and not something they manufactured themselves.
So not a equivalent comparison.
Old 11-07-2014, 02:55 PM   #172
Jesse@JDLAutodesign
Jesse@JDLAutodesign's Avatar
Drives: 2013 Raven Black FRS
Pathetic.
I hope you're calling your own comparison "pathetic"
Jesse@JDLAutodesign is offline   Reply With Quote
Old 11-08-2014, 02:03 AM   #173
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
So.....question is...
What vendor or person is getting this kit to provide some real data??
Old 11-08-2014, 04:34 AM   #174
stonenewt
Drives: BMW 120d
^^ This A quick search comes with the following prices (to the nearest £50)
Cosworth - £4800 + £550 fitting
Sprintex Stage 2 - £5200 inc fitting
Litchfield SC - £4200 + fitting
I couldn't quickly find fitting costs for the Sprintex & Litchfield setup. This is important because the Litchfield is using a centrifugal (rotrex) supercharger, it should be cheaper on parts but more complicated, thus expensive, to install.
stonenewt is offline   Reply With Quote
Old 11-08-2014, 11:58 AM   #175
350matt
Drives: toyota mr2/ Toyota GT86
its a funny thing isn't it?
a reputable company posts results for their product using a calibrated dyno that uses air conditioned air to to feed the engine, controls the fluid temperatures to ISO standards and holds everything at a steady state to allow the power figures to settle and provide repeatable results
but this isn't 'real' data
unless its a quick blast up a set of rollers with no fluid temperature control, and no means of correcting air temperature and god knows what standard the rollers are calibrated to
those are the results we believe....
350matt is offline   Reply With Quote
Old 11-08-2014, 12:15 PM   #176
OICU812
Just a dude
OICU812's Avatar
Well how many times have pre public releases shown inaccurate #s etc? ...Often
Old 11-08-2014, 12:43 PM   #177
CSG Mike
CSG Mike's Avatar
We're chatting with Cosworth, as well as another (very large) company that is developing another FI solution for the FA20.
All numbers published by Cosworth are on 93 octane (MON+RON)/2
Old 11-08-2014, 01:23 PM   #178
Model Citizen
Lacking brains
Drives: frz
how is this which basically amounts to slapping some brackets and dangly spinny bits onto the front of the engine. (litchfield pic)
more "complicated" and thus more labor intensive than removing the intake manifold and all that process entails?
bumper is being pulled for the ic either way far as i know.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 11-09-2014, 02:54 AM   #179
OICU812
Just a dude
OICU812's Avatar
What's official (spill the beans day) on this other (LARGE) company developing another FI solution for the twins??
Old 11-09-2014, 06:45 AM   #180
CSG Mike
CSG Mike's Avatar
Whenever they're ready... check out our IG for a hint
Old 11-09-2014, 02:05 PM   #181
Murseman27
Drives: Volvo S60R
I am very excited to hear what a old "big engine" company will come out with
Murseman27 is offline   Reply With Quote
Old 11-09-2014, 02:35 PM   #182
xwd
So any more detail on what the S/C model and capacity is? I'm still guessing the Eaton TVS900.
Wish I could buy just the heat exchanger, it's actually quad-pass which isn't something you see in off the shelf applications, not to mention it bolts right up to the car. Maybe one of the dealers can get ahold of just one of them.
http://www.cosworth.com/products/pow...ture-radiator/
Cosworth FA20 Stage 1 Power Package DaDr00 Engine, Exhaust, Transmission 84 06-10-2016 03:02 AM
Cosworth Stage 1.1-1.3 Power Package BRZ 2013-2014 / FR-S 2013-2014 With Videos! RallySport Direct Engine, Exhaust, Bolt-Ons 104 07-02-2015 10:10 AM
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Stage 1.1 Cosworth FRS FR-S89 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 17 12-22-2014 01:23 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
