#169 |
Drives: 86
Ordered mine a couple days ago. Planning to pair this with a Tomei overpipe, everything else stock. Plan to have the car tuned for 91 by Church in SoCal...
#170 |
Drives: FR-S Whiteout
Jealous. Would like to see the results you get on 91. Why not a catless front pipe or a front pipe with high flow cat as well? Not enough points to spend?
#171 |
Drives: 86
The potential performance bump of a full exhaust over just a header is not worth the increase in NVH to me. A quiet car also draws less attention from law enforcement and neighbors.
My car is not built for any time trial class in particular, so I'm not concerned about points. |
#172 |
But will it be auto friendly this is the question.
#173 | |
Drives: 2013 Whiteout Scion FR-S
I'm totally in the same mindset with regards to NVH, but I have expressed interest in the upcoming front pipe ptuning is developing to combo with the header. Other than that, everything else is staying stock. I'll be getting e-tuned (ECUtek) via ptuning directly. Sent from my iPhone using Tapatalk |
#174 | |
Drives: Toyota
These numbers should be questioned... Why? 1. The "few 200whp dynos on NA cars" have ALL been on dynojets, which read very high, with stock baselines at 170-175whp. Which makes these past instances around 230bhp at the crank. 200bhp / 173whp = x x * 200whp = 231bhp at crank 2. This Ptuning header with their matching tune reads 200whp with a low baseline of about 159whp. Making this 252bhp at the crank.....which sounds a bit unbelievably high. 200bhp / 159 = x x * 200whp = 252bhp at crank ...if their peak dynos and their stock baseline runs are correct, matching and true...then, this is by far the highest record of any tune, any header, or any NA car on pump gas really, that I have seen so far. Correct me if I am wrong. Very beautiful looking header though. I hope those numbers and baselines are true. If so, then these would be the headers to get. But, 3rd party dynos with baselines is always the best to go by. Btw...do you offer the matching 200whp e-tune that you were using on those dyno runs, to go with the header?
#175 |
I hope the numbers are legit too. The rotational firing order collector sounds magical. I've seen some incredible gains made on other engines with extremely well tuned headers before, so this is not that far fetched.
#176 |
I am looking forward to independent dynos. Being that i am going to stay NA this plus a good e85 tune looks to be good
2013 Series 10 FRS #553
#177 | |
#178 |
Drives: subaru brz satin white
is your header fit for automatic RHD?
#179 |
#180 |
if you are interested i can unmarry my oft and send it to you guys to use for your ots map development.
#181 |
Drives: '13 10 Series FRS #1203
Has anyone picked on up yet and if so plans on getting a tune and dyno tested?
I REALLY want one of these but I REALLY want to see some independent dynos before I do. |
#182 |
^I'm pretty sure nobody has one yet Shady, the first shipment for these headers is set for last week of September or first week of October. Exciting times! Almost there!
| Tags |
| 200hp na, 4-1 full, merge collector, ptuning, race header |
| WTB: Equal-length (EL) catted header | ck-GT86 | Engine, Exhaust, Bolt-Ons | 1 | 04-10-2014 07:31 PM |
| PRE Stepped diameter 4 to 1 double slip collector Header | Jmonty | Engine, Exhaust, Transmission | 9 | 02-28-2014 09:24 AM |
| BRZ/FR-S/GT86 4-1 Equal Length Header Group Buy | P&L Motorsports | Groupbuys | 634 | 12-03-2013 05:36 PM |
| *PHASTEK* DC Sports Equal Length Header | PhastekSport | Engine, Exhaust, Bolt-Ons | 3 | 11-14-2013 10:17 PM |
