Old 08-31-2014, 12:40 PM   #155
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by FirestormFRS View Post
No one said that. Emissions check at in inspection would fail. Tuning eliminates the CEL.
Read it again. He's not disabling the CEL code.
rb6freak is offline   Reply With Quote
The Following User Says Thank You to rb6freak For This Useful Post:
ptuning (08-31-2014)
Old 08-31-2014, 12:48 PM   #156
FirestormFRS
Originally Posted by Ernie L View Post
Then what do you suppose they meant by this "More importantly though, you'll be able to complete the OBD-2 readiness checks"
That just means you won't throw OBD-II readiness flags if you get a simple OBD-II port scan instead of a tail pipe inspection. Depending on what your local inspection entails.
FirestormFRS is offline   Reply With Quote
Old 08-31-2014, 05:20 PM   #157
ptuning
ptuning's Avatar
Drives: White FR-S
Am I reading this correctly ..the front cat delete would not produce a fault code on an emissions check...if so ..would you take the time to explain how is this possible/accomplished... ?...thanks
The primary job of a secondary O2 sensor on a modern day car is to detect the presence of a cat. The ECU gets a reading from both the primary and secondary O2 sensors and compares their values with parameters set within the ECU by the factory. It's looking for a differential reading between the two to determine whether the cat is in place and functioning properly. It's also used to apply fuel trims too, but to a lesser degree than the primary O2.
The location of our two O2 sensors creates a natural differential that is acceptable to the ECU. We DO NOT need to disable the P0420 code. All of the factory DTC codes remain intact. This is the only way you'll be able to satisfy the cat and O2 readiness checks.
We've been able to test our header design NA and with our turbo system in place and the ECU has been happy so far with no CEL's. This design beats trying to spoof the secondary O2 sensor using spacers, restrictor tubes, goosenecks, emulators, etc. These tricks may have worked with earlier OBDII cars, but they are totally hit or miss with modern day cars.
- Toan
ptuning is offline   Reply With Quote
The Following 4 Users Say Thank You to ptuning For This Useful Post:
MDSubarubrz (09-01-2014), rb6freak (08-31-2014), Snowball (09-01-2014), Wepeel (08-31-2014)
Old 08-31-2014, 06:25 PM   #158
Ernie L
Ernie L's Avatar
Drives: 2014 BRZ black premium
............with modern day cars.
- Toan
Thanks for taking the time duing this holiday weekend to explain your method...I appreciate it. Seems like a well thought out and clever solution...as you stated earlier you put a lot of thought and effort into these headers...
Ernie L is offline   Reply With Quote
The Following User Says Thank You to Ernie L For This Useful Post:
ptuning (09-03-2014)
Old 09-04-2014, 12:12 AM   #159
ptuning
ptuning's Avatar
Drives: White FR-S
I just wanted to answer a few common PM questions we've received recently regarding tuning with our header. Although in-house dyno tuning will always be the preferred method to extract every last ounce of power from your mods, we'll likely offer ETuning for customers who are not local to us and are planning on running our header with the stock airbox or possibly a few other popular air intake systems.
For those that have purchased our header and wish to get their cars tuned by their local ECUTek tuner, we'll provide our dyno tested cam timing maps to get you started. This will reduce the dyno time needed to get you dialed in. Your tuner can then focus on targeting his ideal AFR's, MBT/knock limited timing values, etc.
If we get at least half a dozen customers, who have purchased our header, expressing interest in an OFT OTS map, we'll look into possibly purchasing an OFT and creating either a base map or possibly even offer an ETuning service.
For those that are looking to use our header for an NA application for now while you wait to save up for our turbo system, this will be the go to header as we've already tested it with our GTX3076R turbo to 500+whp on E67.
- Toan
- Toan
buddy32 (09-04-2014), phobos512 (09-04-2014), rb6freak (09-10-2014), Snowball (09-04-2014)
Old 09-04-2014, 01:02 AM   #160
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm interested. If you'll be offering the OFT maps, would that be free of charge when we purchase the header?
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Old 09-04-2014, 09:56 AM   #161
Snowball
Snowball's Avatar
Drives: 2013 Whiteout Scion FR-S
PTUNING 4-1 Full T304 SS Equal Length Double-Slip Race Header (200+whp 93 pum...
I'm also planning to get an OFT soon, this is great to hear guys!
Btw: Any word on if the headers will be on time to ship next week? (That will be roughly 5 weeks). Just curious
Snowball is offline   Reply With Quote
Old 09-04-2014, 11:32 AM   #162
TStafford
TStafford's Avatar
Drives: 2015 FR-S Ultramarine Metallic
Can we get a pic from inside the collector where the pipes meet?
TStafford is offline   Reply With Quote
The Following User Says Thank You to TStafford For This Useful Post:
calmtigers (09-04-2014)
Old 09-05-2014, 11:01 AM   #163
Peace@Ptuning
Peace@Ptuning's Avatar
Drives: 86 86 86 86 86
Hey there,
We are expecting an end of the month first week of October Shipment. If anything changes we'll post it up right away!
-Peace
_____________________
PTUNING.COM | 9432 Center Point Lane | Manassas, VA 20110 | Local: 703-257-1728 | Toll Free: 1-877-788-6464 | www.ptuning.com | PTUNING on Facebook | ECUtek Master Tuner | Dyno Dynamics Dyno Facility
PTUNING V-band Low-Mount Turbo System (300+ whp & 400+ whp) | PTUNING DS-325 Modular Polished T304SS V-Band Cat-back Dual Muffler Exhaust System
Peace@Ptuning is offline   Reply With Quote
The Following 2 Users Say Thank You to Peace@Ptuning For This Useful Post:
kanundrum (09-05-2014), Snowball (09-05-2014)
Old 09-05-2014, 11:05 AM   #164
kanundrum
Drives: 2013 Whiteout FR-S
Originally Posted by Peace@Ptuning View Post
Hey there,
-Peace
Welcome Aboard!
Old 09-05-2014, 11:06 AM   #165
Shady195
Drives: '13 10 Series FRS #1203
I'm also interested in knowing if the OFT tune will be free with purchase of the header or an additional cost.
Shady195 is offline   Reply With Quote
Old 09-06-2014, 04:11 PM   #166
ptuning
ptuning's Avatar
Drives: White FR-S
If we're able to develop an OTS map for the OFT that doesn't require further ETuning, then I'm sure it will be something that we can offer to our header customers for free. It will likely only be available for customers running a stock airbox. Unfortunately, we you bolt on an aftermarket intake system. The AFR's end up all over the place and would require either dyno or ETuning.
- Toan
The Following User Says Thank You to ptuning For This Useful Post:
jflogerzi (09-11-2014)
Old 09-06-2014, 05:26 PM   #167
Shady195
It may be worth speaking with shiv, while I know they make their own header were talking two different price classes might be willing to work with you
Sent from my SM-G900A using Tapatalk
Old 09-07-2014, 04:02 PM   #168
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
I already ordered my header and would like to add interest in the OFT map.
G-Man is offline   Reply With Quote
200hp na, 4-1 full, merge collector, ptuning, race header
WTB: Equal-length (EL) catted header ck-GT86 Engine, Exhaust, Bolt-Ons 1 04-10-2014 07:31 PM
PRE Stepped diameter 4 to 1 double slip collector Header Jmonty Engine, Exhaust, Transmission 9 02-28-2014 09:24 AM
BRZ/FR-S/GT86 – 4-1 Equal Length Header Group Buy P&L Motorsports Groupbuys 634 12-03-2013 05:36 PM
*PHASTEK* DC Sports Equal Length Header PhastekSport Engine, Exhaust, Bolt-Ons 3 11-14-2013 10:17 PM
