Old 03-06-2013, 12:03 AM   #169
brillo
Drives: 2013 Firestorm FR-S
Originally Posted by ATL BRZ View Post
Perrin did extensive testing and posted results in their blog: http://blog.perrinperformance.com/pe...-s-oil-cooler/
They measured a loss in power as the oil temps went past 100C
That was my reason for asking, wanted to see if another party could confirm the same issue in the real world
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 03-06-2013, 08:46 PM   #170
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
lol its over 100 almost as soon as you turn the car on.
Surok is offline   Reply With Quote
Old 03-06-2013, 08:57 PM   #171
circuithero
Drives: 2006 Infiniti M45S
I have a suspicion that that test was done on the car running the Vortech. If so, then the heat loss is a bit inflated due to the heat soak from the forced induction. I would like to know exactly what car they did those tests on.
circuithero is offline   Reply With Quote
Old 03-06-2013, 09:27 PM   #172
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
What are you talking about or referring to, can you please clarify?
Huehuecoyotl is offline   Reply With Quote
Old 03-06-2013, 09:53 PM   #173
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
Sadly heat soak shouldn't be a major issue for the Vortech kits:
1) The heat given to the intake air by compression is inherent in all FI setups.
2) The amount of heat delivered to the block via conduction is pretty low. The Vortech kit has one thick aluminum mounting bracket and one very thin support to the block. Initially, I was skeptical of the design, but the more I've looked at it... it seems to be just enough to support the supercharger, isolate it thermally, and help dissipate the heat it generates. I still won't be buying one, but I tip my hat to their engineers for finding an elegant compromise.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 03-06-2013, 10:24 PM   #174
Surok
Wise old man
Surok's Avatar
Drives: 86 GTS
anyway!! yes you do need an oil cooler. damn australia!
Old 03-07-2013, 12:05 AM   #175
robispec
Drives: Black frs project
yes in the real world at the race track top speeds were reduced ten miles per hour...i could feel the lack of top end power...
robispec is offline   Reply With Quote
Old 06-21-2013, 03:36 PM   #176
brillo
Setting the power loss issue aside for the moment (not saying it isn't important) is there any reason other than power loss that a non FI FRS needs an oil cooler for HPDE days? I've been asking around on bobstheoilguy forums about oil temps and 260-270 doesn't seem to concern folks as far as lubrication with a good synthetic oil.
Old 06-21-2013, 05:11 PM   #177
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
We are seeing 290-300 degrees on STOCK engines at the track, how are you only seeing 260-270??
I don't worry about 270 though, hell the endurance race car does 290-300+ (gauge stops at 300) for 14-24 hours. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-21-2013, 05:14 PM   #178
p00mba
p00mba's Avatar
Drives: FR-S :)
if i'm using my car as a daily driver as well as some track duty, and running an oil cooler would you say it would also benefit me to run 5w30 oil instead of the 0w20 or what would you guys recommend?
p00mba is offline   Reply With Quote
Old 06-21-2013, 05:31 PM   #179
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I run 0w30/5w30 because I noticed low (er than I wanted) oil pressure near redline.
Occasional track use.. I probably wouldn't bother.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-21-2013, 05:52 PM   #180
brillo
thanks Dave, I thought I read stock cars were seeing 260-270 without a cooler, temps that higher make me more concerned.
Old 06-21-2013, 06:31 PM   #181
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
I took my stock BRZ, 1k miles on the odometer, only mod was Hawk pads, to Sebring the first weekend in June and using a ScangaugeII OBDII port reader, I saw oil temps stay consistently in the mid to high 290s during the session on Day 1, and at one point touch 300*f. For some reason the second day the temps stayed around the high 280s to the low 290s, but the ambient temp was the same.
Granted, that is from the stock oil temp sensor, and I am not sure where the stock oil temp sensor is mounted, which may/may not have an effect on the temps that are being read.
Water temp however was perfectly fine. If I didn't have the scangauge, I would have no idea that the oil temps were that dangerously high.
smbstyle is offline   Reply With Quote
Old 06-21-2013, 11:14 PM   #182
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
I have the Perrin oil cooler.
At the track in 80ºF I saw 249ºF tops.
BatStig is offline   Reply With Quote
Oil Cooler wootwoot Engine, Exhaust, Transmission 92 12-27-2014 08:10 PM
ARC Oil Cooler ill86 Engine, Exhaust, Transmission 19 10-18-2014 04:30 PM
One-Off Oil Cooler? wootwoot Engine, Exhaust, Transmission 37 07-18-2014 05:42 PM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
Cooler than drifting! Rampage Other Vehicles & General Automotive Discussions 8 04-03-2012 12:55 AM
