Old 11-21-2015, 10:19 PM   #169
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
Originally Posted by travisb View Post
I'm using torque on Android. It did not say which sensor.
Sent from my Nexus 10 using Tapatalk
Check the connections for the sensors, you probably disconnected one on accident. Those should only trigger a code if the ecu isn't receiving signal at all.
YouShallKnow is offline   Reply With Quote
Old 11-21-2015, 10:21 PM   #170
travisb
travisb's Avatar
Drives: N/A
Where is the connection? Is it just where the wire end and goes to the sensor in the hole?
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
travisb is offline   Reply With Quote
Old 11-23-2015, 01:44 PM   #171
travisb
travisb's Avatar
Drives: N/A
So I found the issue with the wheel speed sensor. See the two pictures below.
On the left side of each picture is the bad sensor and sensor hole. The right side is the good sensor.
When we were taking off the left wheel, the first one we attempted, we had a ton of difficutly removing the hub. My dad tried several ways of prying it off. Apparently he bent the thin silver metal ring/shield on the axle. You can see it is bent in the bottom left picture. The right side shows the same piece towards the back of the hole and not bent.
The left sensor got chewed up by the rotating bent silver ring. So now it looks like I need a new sensor and to get that piece straightened out.
Old 11-23-2015, 01:54 PM   #172
YouShallKnow
Drives: Man
Thanks for the follow up, you're sure to help tons of people with a similar issue in the future. Good luck getting it fixed.
Old 01-10-2016, 06:32 PM   #173
Malcolm Lawson
Drives: Scion FRS 2014
Originally Posted by Rosticles View Post
If you are referring to the entire hub and bearing assembly: I had to wack it with a hammer on the brake hat to get it to come loose from the rust holding it.
If you are referring to the brake hat: I had to thread a bolt into the one of the two holes to get it to de-seat from the hub assembly.
I cant get the rotor off. I will try bolts in the 2 holes in the rotor tomorrow. Are they M7 x 1.0?
Does this mean I will also have trouble with the hub?
I am installing APR studs front and rear.
Malcolm Lawson is offline   Reply With Quote
Old 01-10-2016, 08:00 PM   #174
stevesnj
stevesnj's Avatar
you removing the rear rotor?
My 2016 Build thread
Old 01-10-2016, 08:30 PM   #175
Malcolm Lawson
Yes, I is an M8. I made one by running a suitable screw through an M8 die. Screwed it in and off popped the rotor. Am now trying to get the nut off the 1/2 shaft. So far all of my 220 lb at the end of a 2.5 ft breaker bar won't shift it
Sent from my SM-G900V using Tapatalk
Old 01-11-2016, 09:41 AM   #176
stevesnj
stevesnj's Avatar
Getting the rotor back on will be harder, when you remove the rear rotor you need to loosen the brake shoes adjuster to relieve the tension against the drum. You need to loosen the shoes before putting the rotor back on. There is an adjuster hole on the surface of the rotor hub area. For the hub nut make sure you release the hub nut stake and use a 3/4" breaker bar or 1/2".
Old 01-11-2016, 10:21 PM   #177
Malcolm Lawson
Sucess on one side. The answer to the stuck axel nut was to borrow a compressor and impact driver. For the other side I will remove the brake shoes getting the hub back on was difficult, the shoes were in the way.
Old 01-20-2016, 06:15 PM   #178
philooo
Drives: 13' Scion FRS Track car
ARP stud quality problem
I am so mad right now... I have finished my rear wheels and right when it comes to mount the wheels back on ... It seems that i have a full set of APR stud with quality defect.
If I use a simple lug nut (short cheap one) they mount 'ok', but if I use the longer Muteki models, I get a huge amount of resistance when they are 3/4 in.
The Muteki screw in like butter on the other wheel, but on that set, there seem to be a problem with the screw steps or something.
Did anybody ever had this problem ?? I am so bummer I'm gonna have to redo the whole thing again.
FYI, I removed the hub fully and installed with a press, so they where in perfect condition, none of the yellow coating was removed or dinged.
Now I tried to screw the Muteki nuts and the yellow coating is coming off with some metal shaving, so clearly something is wrong on my APR stud set... and all the studs on this set have the same problem
I double checked and they are the same part number, ordered on amazon.com and all
I am crying !!
UPDATE ...Seems like ARP is aware of some bad stud batch... be carefull, test the studs with long open ended nuts BEFORE installing !!
philooo is offline   Reply With Quote
Old 01-20-2016, 08:31 PM   #179
Ozzman
Drives: old
More than likely your aftermarket lugnuts are the problem.
Ozzman is offline   Reply With Quote
Old 01-20-2016, 09:45 PM   #180
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
I have Muteki open ended lugnuts and they work great with my APR
fantah is offline   Reply With Quote
Old 01-20-2016, 10:41 PM   #181
thien
Drives: Scion FRS
Originally Posted by philooo View Post
APR duds ....
I am crying !!
I had same problem.. it was my lugnuts not the studs
Sent from my SM-G920T using Tapatalk
thien is offline   Reply With Quote
Old 01-21-2016, 04:56 PM   #182
philooo
The weird thing is that I tired the same lug nuts on the other APR stud sets and they screwed themselves in all the way with my fingers...
I am in contact with APR, we'll see what they say. I'll report back.
sucks, it is such a pain to remove the rear studs :S
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
